Aero Classic Leak guard inner tubes - do not purchase
AirMike
PostPosted: Fri Oct 14, 2016 8:54 am    Post subject: Aero Classic Leak guard inner tubes - do not purchase Reply with quote
After struggling with the straight tube OEM Vans inner tube, I decided to go to the Aero Classic from Desser Tire TU15/600-6. My experience with this tube has been awful. I went to this tube due to the nice 90 degree bend in the stem that allows easier filling with air. By removing a small bit of metal on the wheel bearing cover, you can easily fill this tube with air. My left side failed after only 6 weeks leaving me with a flat tire when I was ready to dispatch the plane for an important flight. Since I was inside of 90 days, Desser gave me an RMA and I got a credit (not refund) on the defective tube. My second tube failed just this last week after about 5 months of flying. These tubes (made in Thailand) are just no good. I reinstalled my old Vans tube on the new Michelin tire on the left side, but I have yet to put the old tube back on the right side. These tubes are just crap. Any suggestions or comments on this issue will be appreciated.
See you OSH '18
Q/B - sold.
kdb.rv10(at)gmail.com
PostPosted: Fri Oct 14, 2016 9:07 am    Post subject: Aero Classic Leak guard inner tubes - do not purchase Reply with quote
That's odd- I've used these same tubes for three years without any problems.
See you OSH '15
Q/B - flying 6 yrs.
http://forums.matronics.com/viewtopic.php?p=461260#461260
flying-nut(at)cfl.rr.com
PostPosted: Fri Oct 14, 2016 9:22 am    Post subject: Aero Classic Leak guard inner tubes - do not purchase Reply with quote
I'd like to know what/where the failures were. I suspect poor assembly
rather than inherent failures of the tubes. Or poor assumptions
relating to the mod. If you used the same hole in the wheel that was
used for the straight stem .... there's your problem. The 90* stems
line up with the parting line in the wheel and require a hole in the
parting line and another hole in the side of the outside wheel half. I
converted my Vans wheels to 90* stems. I flared the inside and outside
of the original stem hole and filled it with flox. Not flying yet so
don't know if my 'mod' is successful.
Linn
See you OSH '15
Q/B - flying 6 yrs.
recapen(at)earthlink.net
PostPosted: Fri Oct 14, 2016 9:23 am    Post subject: Aero Classic Leak guard inner tubes - do not purchase Reply with quote
I had an issue where an inspection sticker inside the tire wore a hole in
the tube - I thought I got a bad tube...until I wore a hole through the
patch as I put it back together the same way it came apart.....
rv10flyer(at)live.com
PostPosted: Fri Oct 14, 2016 9:30 am    Post subject: Aero Classic Leak guard inner tubes - do not purchase Reply with quote
I have the same TU15 Desser tubes, and probably have the longest life on mine as I got some of the first ones released. I have gone against the" replace tubes with tires" minds and reinstalled the tubes on the new Monster tires, to date I have had no issues of leaking at all, that's is after 4 years of flying.
I'll assume the tire pressure is more than 42psi? I run mine at 48psi and never let them get below 44psi, I am concerned with lower pressures pinching the tires or rubbing and my pressures seems to work as my tires look pretty good for tread, I have no shutter (unbalanced rim still) with solid traction.
I can only think they changed manufacturer since I got my tubes. Unfortunately, I really like mine thus far and would buy them again. How are the Vans tubes working out? Was it only on the left side? Both times? What about the right? Is that side fine? If so, there may be something on the left causing the issues, and your Vans tube may be the next to go on that side... just thinking....
Tim Olson
PostPosted: Fri Oct 14, 2016 10:17 am    Post subject: Aero Classic Leak guard inner tubes - do not purchase Reply with quote
I had 2 tubes fail from Desser, not all that many flying hours apart,
also. But, mine weren't the 90 degree valve stem tubes.
One of them was a pinhole leak that just came out of nowhere.
The other was a leak that was along a little slice-like
scrape, that I have no idea how it got there. Admittedly,
I didn't thoroughly inspect the tube when I pulled it out of
the bag. I wasn't happy in either case.
Both wheels now have new-ish 90 degree stem tubes in them.
I've always run my pressues at the standard 42/40 rear/front
pressures that Van's put in the original manual, however I
think I will start raising the pressure slightly just
because we have such large temperature swings here, so if
I check them in the fall I'll go maybe 48.
Linn, I think you're mistaking his issue for the nosewheel
tube. Yes, on that one Van's sends the wrong wheel, and
then they have to re-machine the hole on the other side,
and all the things you said. But he's talking about the
15/6.00-6 main tubes. Those don't require any drilling
or anything else.
Other than these 2 tubes, I've had good luck over the past
10 years. I've replaced tires a few times and always put in
new tubes. So I'm not sure I'm ready to ditch them
yet. I WOULD be interested to see what the BEST tube
available is. I would prefer to buy a US made tube if
at all possible, and would pay a small premium for that
ability if it's a quality tube.
-------- See you OSH '15 Q/B - flying 6 yrs.
PostPosted: Fri Oct 14, 2016 10:28 am    Post subject: Aero Classic Leak guard inner tubes - do not purchase Reply with quote
Tim, I had to machine both my mains. That might be due to the tube
manufacturer being different. I'm guessing from your post that you used
the same hole as the straight stem??
Linn
or anything else.
Tim Olson
PostPosted: Fri Oct 14, 2016 10:49 am    Post subject: Aero Classic Leak guard inner tubes - do not purchase Reply with quote
Yes, same holes. You have Cleveland?
That's what mine are.
On Oct 14, 2016, at 1:27 PM, Linn Walters <flying-nut(at)cfl.rr.com> wrote:
Tim, I had to machine both my mains. That might be due to the tube manufacturer being different. I'm guessing from your post that you used the same hole as the straight stem??
Linn
> or anything else.
> Tim
PostPosted: Fri Oct 14, 2016 11:28 am    Post subject: Aero Classic Leak guard inner tubes - do not purchase Reply with quote
Yes, they're Cleveland. However I have a tube with 90* stem in my shop
that has the offset to fit the straight stem wheel. It would point to
the outside of the wheel, not parallel with the axle. I think the tubes
I have came from Desser, but were not the Leak Guard. The stem is in
the center of the inside of the tube, and when mounted the stem is
naturally parallel to the axle, so that drove my mod.
Linn
> Linn
>> or anything else.
>> Tim
AirMike
PostPosted: Fri Oct 14, 2016 12:51 pm    Post subject: Response - Aero Classic Leak guard inner tubes Reply with quote
I did not put a new hole in the rim as the tube stem lined up fine when installed. The leak on the left tube that I returned to Desser was in the side wall of the tube. There was no abrasion on the tube, but it appeared as a "casting" flaw in the tube where the leak originated. I have not taken the leaking right tire tube off yet to diagnose the issue. Desser will not give me a refund after 90 days.
Has anyone ever used that slime stuff to stop a leak??
See you OSH '18
Q/B - sold.
Tim Olson
PostPosted: Fri Oct 14, 2016 2:01 pm    Post subject: Aero Classic Leak guard inner tubes - do not purchase Reply with quote
I didn't yet but am interested now.
Jesse, you had a cirrus part that looked good. Any pics or details on that?
On Oct 14, 2016, at 4:27 PM, AirMike <Mikeabel(at)Pacbell.net> wrote:
Good thoughts on the subject. Gotta get my patch kit. Yes, you definitely want to turn the tire to distribute the material.
Another thought is that if you cannot spin the tire vigorously as in jacking and spinning then you want to taxi quite a bit to distribute the stuff and see that it covers the interior of the tube.
In the mean time, it looks like "Aero Classics" has changed vendors and the QC is not so great, or that I just got a bum batch. Either way, it is a pain to mess around with the tires that much after spending $400 on new mounts.
PS did you or anyone else put air access doors in their wheel pants?
See you OSH '15
Q/B - flying 6 yrs.
http://forums.matronics.com/viewtopic.php?p=461289#461289
jesse(at)saintaviation.co
PostPosted: Fri Oct 14, 2016 2:37 pm    Post subject: Aero Classic Leak guard inner tubes - do not purchase Reply with quote
Any cirrus parts house (service center) will sell you a plastic wheel pant plug. It's 2" in diameter and made out if white plastic. It can be painted. Center of the hole works well 2-2.5" aft of the axle screw and 1/2" down. Pretty simple mod.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
C: 352-427-0285
F: 815-377-3694
> See you OSH '15
> Q/B - flying 6 yrs.
cooprv7(at)yahoo.com
PostPosted: Fri Oct 14, 2016 2:52 pm    Post subject: Aero Classic Leak guard inner tubes - do not purchase Reply with quote
Lowes also sells metal plugs of various sizes that work great. In the hardware section in the specialty bins.
Marcus
Jesse Saint
C: 352-427-0285
F: 815-377-3694
> See you OSH '15
> Q/B - flying 6 yrs.
bwestfall
PostPosted: Fri Oct 14, 2016 3:48 pm    Post subject: Aero Classic Leak guard inner tubes - do not purchase Reply with quote
I'll chime in and offer up what Mark Cooper did. Here's his blog entry
about it.
https://myrv10factory.wordpress.com/2014/02/04/wheel-pant-modification-cowl-
hinge-pin-retainer-and-an-unexpected-surprise/
More pics here.
https://myrv10factory.wordpress.com/2014/02/05/wheel-pants-are-wrapped-up-pr
eparing-cowling-and-additional-fiberglass-finese/
-Ben
Kelly McMullen
PostPosted: Fri Oct 14, 2016 6:29 pm    Post subject: Aero Classic Leak guard inner tubes - do not purchase Reply with quote
I have to think you got a bad pair of tubes. I bought the exact tubes that were recommended on Tim's web page, probably around 3 years ago when I was mounting the gear legs. They are the Desser Leakguard variety, inside Desser standard recaps. I have been flying since April, and most add air every 6 wks or so, which is aggravated by our major temp changes. I suppose I should get a patch kit to put in the airplane spares kit.
-sent from the I-droid implanted in my forearm
On Fri, Oct 14, 2016 at 11:48 AM, Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote:
--> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)>
> On Oct 14, 2016, at 1:27 PM, Linn Walters <flying-nut(at)cfl.rr.com (flying-nut(at)cfl.rr.com)> wrote:
> --> RV10-List message posted by: Linn Walters <flying-nut(at)cfl.rr.com (flying-nut(at)cfl.rr.com)>
> Linn
>> or anything else.
>> Tim
>>> --> RV10-List message posted by: "AirMike" <Mikeabel(at)Pacbell.net>
FORUMS -
WIKI -
b Site -
          -Matt Dralle, List Admin.
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
