10 inch Dynon in a Mono
MJKTuck(at)cs.com
PostPosted: Thu Dec 01, 2016 6:45 pm    Post subject: 10 inch Dynon in a Mono Reply with quote
Hi,
I'm still determined to upgrade my Europa monowheel to an EFIS and have
pretty much settled on the 10 inch Dynon display.
So I'm in my early stages of panel planning I have determined that the
standard mono panel moulding is not quite wide enough for the 10 in screen.
It needs building up to the left by maybe 1/2 inch which starts to
encroach into the recess for the gear/flap handle.
My question is, has anyone else already done this and if so, did you
make some kind of gear/flap handle extension that would make it easier
to push and pull the handle up and down?
I'd be interested in any solutions along with any pictures.
Martin Tuck
Wichita, Kansas
Fred Klein
PostPosted: Thu Dec 01, 2016 7:57 pm    Post subject: 10 inch Dynon in a Mono Reply with quote
Martin…though I opted for the 7” Skyview, principally because I have a stand-alone EMS and will not have to split-screen the Dynon to get that data, because of associated layout decisions regarding back up steam gauges, I too needed to decrease the width of the recess for the gear/flap handle by approx. 1/2”…a bit of handy hacksaw work is all it took…I’ll send pixs directly to you…Fred
On Dec 1, 2016, at 6:44 PM, Martin Tuck <MJKTuck(at)cs.com (MJKTuck(at)cs.com)> wrote:
I'm still determined to upgrade my Europa monowheel to an EFIS and have pretty much settled on the 10 inch Dynon display.So I'm in my early stages of panel planning I have determined that the standard mono panel moulding is not quite wide enough for the 10 in screen.It needs building up to the left by maybe 1/2 inch which starts to encroach into the recess for the gear/flap handle.
JonathanMilbank
PostPosted: Fri Dec 02, 2016 3:27 am    Post subject: Re: 10 inch Dynon in a Mono Reply with quote
Here's my solution. Really all I wanted to do was to replace the old dead electric A/H, but for not much more money this is perfect for VFR only.
 Filesize:  1.85 MB
 Viewed:  7960 Time(s)
davidjoyce(at)doctors.org
PostPosted: Fri Dec 02, 2016 5:16 am    Post subject: 10 inch Dynon in a Mono Reply with quote
Martin, Have you looked at the Garmin G3X Touch system, which I have found very impressive in demonstration. Am in the middle of fitting an 8" EFIS with a G5 acting as back up for altimeter, ASI horizon and lots else, tying in with my old (not very) GNC255A Nav/com system. Both the 8" EFIS and the G5 are beautifully readable in any light and I am not clear that a 10" one would offer any extra benefit. Doing away with the steam driven back up instruments means there is plenty of room on the panel for all the extras I want. I am also fitting a remote transponder and small certified GPS so that it will all work for ADSB in and out. The LAA historically insisted on steam back up instruments, but they have recently relaxed this edict and I have just heard that the G% is acceptable acting as back up ASI and altimeter
Regards, David Joyce, G-XSDJ
On 2016-12-02 02:44, Martin Tuck wrote:
--> Europa-List message posted by: Martin Tuck <MJKTuck(at)cs.com (MJKTuck(at)cs.com)>
Hi,
My question is, has anyone else already done this and if so, did you make some kind of gear/flap handle extension that would make it easier to push and pull the handle up and down?
Martin Tuck
Wichita, Kansas
w.aeroelectric.com
">www.buildersbooks.com
builthelp.com
lotstore.com
m
.matronics.com/contribution
ttp://www.matronics.com/Navigator?Europa-List
ics.com
.com
SPURPURA
PostPosted: Fri Dec 02, 2016 9:27 am    Post subject: Re: 10 inch Dynon in a Mono Reply with quote
Here is a pic of the 8 1/2" GRT Sport SX in my Tri-gear. Very happy with the unit.
 Filesize:  284.47 KB
 Viewed:  7938 Time(s)
N951EU - Tri-gear & 912ULS, N77EU- Tri-gear & 914
I'D RATHER HAVE A BOTTLE IN FRONT OF ME THAN A FRONTAL LABOTAMY.
MJKTuck(at)cs.com
PostPosted: Fri Dec 02, 2016 10:36 am    Post subject: 10 inch Dynon in a Mono Reply with quote
Thanks David, yes that was another I looked at but is quite a bit more expensive. I still look st it from time to time.
Martin
On Dec 2, 2016, at 7:15 AM, davidjoyce(at)doctors.org.uk (davidjoyce(at)doctors.org.uk) wrote:
Hi,
Martin Tuck
Wichita, Kansas
w.aeroelectric.com
builthelp.com
lotstore.com
m
ics.com
.com
spcialeffects
PostPosted: Fri Dec 02, 2016 11:48 am    Post subject: Re: 10 inch Dynon in a Mono Reply with quote
Dynon is an excellent choice.........I have 2. The only modification to the panel needed is to chop out a bit small bit of the panel moulding for the top left of the screen to allow you to get it into position
 Filesize:  381.42 KB
 Viewed:  7927 Time(s)
erichdtrombley(at)juno.co
PostPosted: Fri Dec 02, 2016 12:05 pm    Post subject: 10 inch Dynon in a Mono Reply with quote
Hi Martin,
I installed the 10 inch Dynon in my mono.
____________________________________________________________
Avoid Botox: How To Remove Lip Lines & Wrinkles In 2 Minutes
Fit Mom Daily
http://thirdpartyoffers.juno.com/TGL3131/5841d36d35fa3533e1102st01vuc
It is a tight flight, however, the modification to the panel was minimal and does not encroach on the gear retract space.
Erich Trombley
N28ET Classic Mono
 Filesize:  864.7 KB
 Viewed:  7924 Time(s)
