		docclv(at)windstream.net Guest
				 Posted: Sat Dec 03, 2016 12:27 pm    Post subject: Max RPM on D4A5 Lycoming |
				Carlos:  You are right.  The D4A5 is rated at 260hp at 2750rpm.  I had
 the same problem with the engine reving to only 2500 rpm with the
 initial Hartzel governor Van's sent.  We tried adjusting the stop on the
 governor, etc. to no avail.  I finally checked what governor was
 recommended for a Hartzel prop (in our case) and found out Van's sent
 the wrong governor!  Make sure you have a S-1-32 governor.  Doc N123CV
 #41087
		Kelly McMullen
				 Posted: Sat Dec 03, 2016 2:58 pm    Post subject: Max RPM on D4A5 Lycoming |
				Actually the redline is 2700, NOT 2750. The last 125 rpm only get you from 250 to 260 hp.
 -sent from the I-droid implanted in my forearm
 On Sat, Dec 3, 2016 at 1:26 PM, Doc <docclv(at)windstream.net (docclv(at)windstream.net)> wrote:
  	  | Quote: | 	 		  --> RV10-List message posted by: Doc <docclv(at)windstream.net (docclv(at)windstream.net)>
  Carlos:  You are right.  The D4A5 is rated at 260hp at 2750rpm.  I had the same problem with the engine reving to only 2500 rpm with the initial Hartzel governor Van's sent.  We tried adjusting the stop on the governor, etc. to no avail.  I finally checked what governor was recommended for a Hartzel prop (in our case) and found out Van's sent the wrong governor!  Make sure you have a S-1-32 governor.  Doc N123CV #41087
  br> fts!)
  r> > /www.aeroelectric.com" rel="noreferrer" target="_blank">www.aeroelectric.com
  w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com
  p.com" rel="noreferrer" target="_blank">www.homebuilthelp.com
  e.com" rel="noreferrer" target="_blank">www.mypilotstore.com
  " rel="noreferrer" target="_blank">www.mrrace.com
            -Matt Dralle, List Admin.
   FORUMS -
  WIKI -
  b Site -
A&P/IA, EAA Tech Counselor
KCHD |
				 Posted: Sun Dec 04, 2016 6:51 am    Post subject: Max RPM on D4A5 Lycoming |
				Yes, 2700.  I have the stock setup as       well.
        I can't be specific here but my very experienced and totally       'anal' Tech Counselor, who I have immense respect for, identified       an issue with the throttle assembly during prep for the first       starts and flight.  He considered it important enough to insist       that we drill a new hole in the throttle arm so that the throw was       adequate (I was not happy with such a mod to the stock Vans setup       but he insisted).
        I thought it was a low RPM issue but I know that a new hole in the       arm would change the entire range - that's as much as I can say       with any actual understanding.  It performed perfectly after that       slight mod - low idle to 2700 though I recall making a small       adjustment at the governor.  While I have to assume it was       something specific to my build - it was all stock from my       perspective.
        So, the stock setup is not dead nuts perfect.
        Background - my TC inspected my work annually or as requested and       seemed to be satisfied enough with this first time builder's       efforts to leave me alone.   He NEVER put hands on or insisted on       changes EXCEPT for the stock throttle linkage.  I never completely       understood the problem but he insisted and I knew enough to       follow.  He drilled the hole.
        Bill "hope that helps a bit" Watson
        On 12/3/2016 5:58 PM, Kelly McMullen wrote:
       	  | Quote: | 	 		         Actually the redline is 2700, NOT 2750. The last         125 rpm only get you from 250 to 260 hp.
              br>             fts!)
              rel="noreferrer"             target="_blank">http://www.matronics.com/contribution
              FORUMS -
              WIKI -
              b Site -
 www.avast.com
