Posted: Thu Dec 15, 2016 8:53 am Post subject: Door seals |
I set up the doors and they open and close fine...nice tight fit and flush.
Without the seal.
With the seal (without transparency) i have to lean most of my weight down to get the shoot bolts in. This is obviously going to be hard with the windows in and my concern is not engaging the rear bolt by mistake causing the door to depart.
Had anybody had the same problem? I am thinking of finding an alternative seal.
Will
jglazener
Joined: 14 Apr 2010 Posts: 76 Location: Schoonhoven, Netherlands
Posted: Fri Dec 16, 2016 1:13 am Post subject: Re: Door seals |
Had exactly the same issue. The doors were nearly impossible to close from the outside, totally impossible from the inside. Found out though that if you leave them locked for a few weeks, the seals settle and compact. No problem now! Will still bolt a wooden knob on the inside back to be able to pull the back end in.
_________________ Jeroen
http://www.europaowners.org/main.php?g2_itemId=44165 |
Posted: Fri Dec 16, 2016 12:02 pm Post subject: Door seals |
Excellent thanks so much. Very helpful
thanks everyone
Will
William Daniell
LONGPORT
+57 310 295 0744
On Fri, Dec 16, 2016 at 4:13 AM, jglazener <j.glazener(at)planet.nl (j.glazener(at)planet.nl)> wrote:
| Quote: | --> Europa-List message posted by: "jglazener" <j.glazener(at)planet.nl (j.glazener(at)planet.nl)>
Jeroen
http://forums.matronics.com/viewtopic.php?p=463962#463962
br> fts!)
r> > com" rel="noreferrer" target="_blank">www.aeroelectric.com
w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com
p.com" rel="noreferrer" target="_blank">www.homebuilthelp.com
e.com" rel="noreferrer" target="_blank">www.mypilotstore.com
" rel="noreferrer" target="_blank">www.mrrace.com
-Matt Dralle, List Admin.
FORUMS -
WIKI -
b Site -
