gilles.thesee(at)free.fr Guest
Posted: Sun Jan 01, 2017 10:49 am Post subject: Best dimensions for conduits |
Hi all,
Best wishes for 2017.
What could be the dimensions of the conduit for the (nav/strobe lights,
magnetometer, etc.) wires in the wing of a a composite aircraft ?
There is plenty of room in the empty leading edge, but obviously the
passage is too large and some means of attaching the wires seems in order.
Any opinions on a practical way to use this long empty passage for wires ?
Thanks in advance for your input,
Best regards,
Gilles
http://contrails.free.fr
kjashton(at)vnet.net Guest
Posted: Sun Jan 01, 2017 12:15 pm Post subject: Best dimensions for conduits |
Looking at your wings, I think I'd put some 1/2” to 3/4” auto wire loom protector in the wings, with zip ties so the wire does not work itself out of the split in the loom protector. Leave a nylon string in the protector that you can later use to pull wires. Later on, you can push a stiff wire through the loom protector and use it to pull wires. The loom protector is lightweight but will protect them from abrasion.
-Kent
Cozy & Long-EZ builder
Quote: | On Jan 1, 2017, at 1:44 PM, GTH <gilles.thesee(at)free.fr> wrote:
Hi all,
What could be the dimensions of the conduit for the (nav/strobe lights, magnetometer, etc.) wires in the wing of a a composite aircraft ?
There is plenty of room in the empty leading edge, but obviously the passage is too large and some means of attaching the wires seems in order.
Best regards,
Gilles
ceengland7(at)gmail.com Guest
Posted: Sun Jan 01, 2017 2:05 pm Post subject: Best dimensions for conduits |
Virtually everyone complains of running out of wire path volume at some
point, so 'go big'.
For choices, the split loom stuff does work. I like this stuff:
https://www.techflex.com/prod_ccp.asp
and
https://www.techflex.com/prod_f6w.asp
Very light weight and very flexible. The unsplit stuff works like the
old 'Chinese finger cuffs' we played with as kids; the 1" stuff will
expand to close to 1 1/2" if you push it together (make it shorter). And
it will shrink to about 1/2" if you stretch it. You could install the
max size with enough length for max diameter, and when you know
everything is in, just pull on the ends to tighten it up (if you feel
it's needed; I don't).
Only downside to the closed stuff is that you'll need a smooth, more or
less ball shaped end on whatever you pull through it, to avoid snagging
on the weave.
Charlie
On 1/1/2017 2:08 PM, Kent or Jackie Ashton wrote:
-Kent
> Hi all,
> Best regards,
> Gilles
donvansanten(at)gmail.com Guest
Posted: Sun Jan 01, 2017 2:23 pm Post subject: Best dimensions for conduits |
Try these for pulling wire thru conduit.
http://www.techtoolsupply.com/ProductDetails.asp?ProductCode=85-901
On Sun, Jan 1, 2017 at 2:05 PM, Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
Quote: | --> AeroElectric-List message posted by: Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)>
Virtually everyone complains of running out of wire path volume at some point, so 'go big'.
and
Very light weight and very flexible. The unsplit stuff works like the old 'Chinese finger cuffs' we played with as kids; the 1" stuff will expand to close to 1 1/2" if you push it together (make it shorter). And it will shrink to about 1/2" if you stretch it. You could install the max size with enough length for max diameter, and when you know everything is in, just pull on the ends to tighten it up (if you feel it's needed; I don't).
Only downside to the closed stuff is that you'll need a smooth, more or less ball shaped end on whatever you pull through it, to avoid snagging on the weave.
Charlie
Quote: | --> AeroElectric-List message posted by: Kent or Jackie Ashton <kjashton(at)vnet.net (kjashton(at)vnet.net)>
-Kent
Quote: | On Jan 1, 2017, at 1:44 PM, GTH <gilles.thesee(at)free.fr (gilles.thesee(at)free.fr)> wrote:
--> AeroElectric-List message posted by: GTH <gilles.thesee(at)free.fr (gilles.thesee(at)free.fr)>
Hi all,
Best regards,
Gilles
br> fts!)
r> > /www.aeroelectric.com" rel="noreferrer" target="_blank">www.aeroelectric.com
w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com
p.com" rel="noreferrer" target="_blank">www.homebuilthelp.com
e.com" rel="noreferrer" target="_blank">www.mypilotstore.com
" rel="noreferrer" target="_blank">www.mrrace.com
-Matt Dralle, List Admin.
FORUMS -
WIKI -
b Site -
user9253
Joined: 28 Mar 2008 Posts: 1938 Location: Riley TWP Michigan
Posted: Sun Jan 01, 2017 3:35 pm Post subject: Re: Best dimensions for conduits |
I have not tried this but builders on another forum recommend using lawn sprinkler tubing available at home improvement stores.
_________________ Joe Gores |
rick(at)beebe.org Guest
Posted: Mon Jan 02, 2017 9:17 am Post subject: Best dimensions for conduits |
I wouldn't. I'd use smooth conduit. Either regular plastic electrical
conduit or, as Joe suggested, something like lightweight plumbing
tubing. I'd suggest 3/4" or 1" if it'll fit. The corrugated stuff is
good for wrapping around wires that are already in place but I find
trying to feed wires through it later to be a pain. The reason for the
larger pipe is not necessarily so you can cram more wires in but because
the extra space also makes it easier to pull or replace wires later.
--Rick
On 1/1/2017 3:08 PM, Kent or Jackie Ashton wrote:
-Kent
> Hi all,
> Best regards,
> Gilles
jim(at)PoogieBearRanch.co Guest
Posted: Mon Jan 02, 2017 10:38 am Post subject: Best dimensions for conduits |
Leaving a "tied-off" line in the conduit to help pull a new wire through
is a great idea. But remember that when you use that line to pull the
next wire through, you need to also pull through another "spare" line to
tie off, awaiting your inevitable "next" wire pull...
Of course, I learned this the hard way... (Long story involving a
lengthy conduit run from house to workshop, and a new welding circuit
for the shop... Sigh.)
Jim Parker
jan_de_jong(at)casema.nl Guest
Posted: Mon Jan 02, 2017 11:54 am Post subject: Best dimensions for conduits |
I found that the black 25mm OD HDPE sprinkler system tubing by Gardena
(2718) is very lightweight.
Fixing it inside a finished wing would be a problem. Wouldn't want it
free to move.
Jan de Jong
because the extra space also makes it easier to pull or replace wires
later.
--Rick
> <kjashton(at)vnet.net>
> abrasion.
> -Kent
>> Hi all,
>> aircraft ?
>> order.
>> wires ?
>> Best regards,
>> Gilles
edpav8r(at)yahoo.com Guest
Posted: Mon Jan 02, 2017 12:16 pm Post subject: Best dimensions for conduits |
If you have a solid conduit with no pull string, you can send one through by tying it around a wad of cotton balls and using either compressed air to blow it through or a shop vac to suck it through. This works best in conduit under a couple of inches in diameter, and where the conduit isn't already stuffed full of wires. It definitely won't work in a split loom.
Another alternative is to disconnect a wire that's already installed and use it to pull through a replacement for itself along with the new wires (and a pull string for the future).
Eric
Quote: | On Jan 2, 2017, at 10:36 AM, <jim(at)poogiebearranch.com> <jim(at)poogiebearranch.com> wrote:
Leaving a "tied-off" line in the conduit to help pull a new wire through is a great idea. But remember that when you use that line to pull the next wire through, you need to also pull through another "spare" line to tie off, awaiting your inevitable "next" wire pull...
Of course, I learned this the hard way... (Long story involving a lengthy conduit run from house to workshop, and a new welding circuit for the shop... Sigh.)
Jim Parker
