		JonathanMilbank
  Joined: 14 Apr 2012 Posts: 397 Location: Aberdeen area
				 Posted: Sat Jan 14, 2017 2:41 pm    Post subject: 1.5 degrees right? |
				I'm converting my Classic to XS firewall forward and the instructions for mounting the engine call for the 4 washers on each lord mount to be arranged so that the engine is angled 1.5 degrees to the right.
 The Classic build manual didn't give this stipulation and so mine was pointing straight ahead. What effect will there likely be when I start flying in the new configuration. Up until now there has been a tendency for the aircraft to roll gently to the right in the cruise.
 Will angling the engine to the right make the right roll tendency better or worse? Please give me the aerodynamic logic for this 1.5 degree offset.
 Thanks.
 Jonathan
		dpark748(at)icloud.com Guest
				 Posted: Sat Jan 14, 2017 2:52 pm    Post subject: 1.5 degrees right? |
				Was the XS Fin offset?
 Dave Park
  	  | Quote: | 	 		   On 14 Jan 2017, at 22:41, jonathanmilbank <jdmilbank(at)yahoo.co.uk> wrote:
  Thanks.
  Jonathan
  http://forums.matronics.com/viewtopic.php?p=465078#465078
		JonathanMilbank
				 Posted: Sat Jan 14, 2017 3:14 pm    Post subject: Re: 1.5 degrees right? |
				Sorry but I don't know. Perhaps the esteemed Bud or another guru might know the answer to that.
		spcialeffects
				 Posted: Sun Jan 15, 2017 1:06 am    Post subject: Re: 1.5 degrees right? |
				Hello Jonathan, Frank Xuereb here. If you watch 'a plane is born' when he gets the engine delivered Mark gives quite a good explanation as to the reason for the offset. Basically on full throttle the wind wash created by the prop would hit the port side of the fin and give a tendency to push you to the left. This is of course easily corrected by right rudder input but to help reduce this effect the back of the engine is offset by 27mm but keeps the prop flange at 90 degrees.
 Good luck, Frank kit 165
				 Posted: Sun Jan 15, 2017 3:39 am    Post subject: 1.5 degrees right? |
				Jonathan, I suspect you are dealing with two distinct effects here. The tendency to roll to the right suggests to me that you have slightly different effective angles of attack on the two wings, either because of how the wings were constructed or because of how they were attached to the fuselage. This seems to be very common and a small piece of triangular section wood, length adjusted for effect, under (in your case ) the port aileron will correct it. As previously stated the engine offset is there to correct the tendency for the clockwise spiral propwash around the fuselage impinging on the left side of the fin and tending to produce a left turn. This effect is most noticeable on take off (and probably also in monos) when at max power and lowish speed with limited rudder authority, when a significant amount of Right rudder is needed to keep in a straight line. It is also noticeable in a full power lowish speed climb. I believe that the amount of offset is designed to allow hands off balanced straight flight at typical cruise speeds/power, whilst also helping to maintain control authority on take off. Regards, David Joyce,GXSDJ
 On 2017-01-14 22:41, jonathanmilbank wrote:  	  | Quote: | 	 		    	  | Quote: | 	 		  --> Europa-List message posted by: "jonathanmilbank" <jdmilbank(at)yahoo.co.uk (jdmilbank(at)yahoo.co.uk)>
 Thanks.
 Jonathan
  Of how they are mounted on the fuselage. This is very common and can be readily corrected with a small trangular section of wood stuck under the (in your case)  port aileron
 ics.com
 .com
 .matronics.com/contribution
		rogersheridan(at)mac.com Guest
				 Posted: Sun Jan 15, 2017 3:52 am    Post subject: 1.5 degrees right? |
				Further info here for bookworms!
 https://dl.dropboxusercontent.com/u/246742/TailWheel1.pdf
  	  | Quote: | 	 		  On 15 Jan 2017, at 11:38, davidjoyce(at)doctors.org.uk (davidjoyce(at)doctors.org.uk) wrote:
 Thanks.
 Jonathan
 ics.com
 .com
		nigel_graham(at)m-tecque. Guest
				 Posted: Sun Jan 15, 2017 2:09 pm    Post subject: 1.5 degrees right? |
				Jonathan,
 I think you have provided the answer to your own question.
 The fact that you have run your Classic with no engine offset and
 noticed no asymmetric flying characteristics speaks volumes.
 The whole idea of canting an engine sideways and forcing the propeller
 disc through the air at anything other than normal to the oncoming
 airstream is daft.
 The theory that canting the engine sideways will counter the yaw
 effect of the prop wash seems to be based on a misunderstanding of
 what is really happening and it’s done because “that’s how it’s always
 been done”!
 On your Classic, you sensibly mounted your engine head on to the wind
 and you set you propeller blades pitch to the recommended angle. Each
 time the blades rotate their angles of attack remain equal to each
 other and constant to the oncoming wind and each blade generates the
 same thrust throughout each revolution of the prop.
 Now consider what happens when you follow the XS build instructions
 and cant the engine 1.5 degrees to the right.
 If you’re flying straight-and-level behind a right-hand tractor (Rotax
 912, 914), each time a blade passes over the top of the ark, its pitch
 is effectively reduced by 1.5 degrees and as it swings through the
 bottom of the ark, its effective pitch is increased by 1.5 degrees.
 This means that your propeller is producing significantly more thrust
 from the bottom half of the propeller disc than the top half – and
 that produces a pitch up change in attitude – and not the sideways
 thrust you had hoped to achieve by mounting the engine sideways.
 “So if that’s true, why has nobody noticed this pitch up attitude?” –
 a good question (even though I asked it myself).
 All Europa’s are fitted with a pitch trimmer – so these effects are
 unconsciously trimmed out by the pilot during different phases of
 flight.
 “Ah, but what about the propensity to swing to the left on take-off?”
 - Same thing, different plane.
 The  Monowheel sits on the ground at a deck angle of (is it about 12
 degrees? I forget) so the engine is now canted up at the front by this
 amount. At the beginning of the take-off run, the upcoming blade on
 the left hand side has 12 degrees wound off its effective pitch, while
 the down going blade on the right has 12 degrees added to its pitch.
 This produces significantly more thrust on the right hand side of the
 disc than the left, resulting in a turning moment to the left. It's a
 potential problem with all tail-draggers
 The Tri-Gear variant of course sits horizontally on the ground, so has
 none of this asymmetric thrust – so is less prone to dive off to the
 left on take off; another reason why the Tri-Gear is perceived to be
 more benign than the Mono.
 Canting an engine is a very crude way of addressing a relatively
 transient problem – Fitting a rudder trimmer would be a far more
 elegant solution – should it be necessary.
 Hope that wasn’t too long winded!
 Nigel
 PS the roll issue has nothing to do with engine position.
 Quoting jonathanmilbank <jdmilbank(at)yahoo.co.uk>:
  to the right.
  degree offset.
  Thanks.
  Jonathan
		JonathanMilbank
				 Posted: Sun Jan 15, 2017 3:03 pm    Post subject: Re: 1.5 degrees right? |
				Wow and what a plethora of replies! Thanks very much to all of you.
 Shortly after I posted this topic and before any replies came in, a fellow Europa pilot confirmed in advance much of what you guys have explained and your responses are excellent.
 He mentioned that when he let someone else have a go on the Europa's controls, the guy was caught out by the amount of left yaw during the go-around at low speed from a missed approach. My friend had to assist, so clearly some people would benefit from the engine being offset by 1.5 degrees.
 I suppose that once anyone gets used to the aircraft, then applying right pedal when increasing power becomes instinctive.
		rlborger(at)mac.com Guest
				 Posted: Sun Jan 15, 2017 3:07 pm    Post subject: 1.5 degrees right? |
				Nigel,
 Thanks for the detailed description.  I have often wondered about the effectiveness of the offset.  It just didn’t seem right to me.  At some point in the future I’ll have to unbolt the engine for something.  When I do, I’ll remove the offset and see what difference it makes.
 Blue skies & tailwinds,Bob BorgerEuropa XS Tri, Rotax 914, Airmaster C/S Prop (75 hrs).Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP3705 Lynchburg Dr.Corinth, TX  76208-5331Cel: 817-992-1117rlborger(at)mac.com (rlborger(at)mac.com)
 On Jan 15, 2017, at 4:08 PM, nigel_graham(at)m-tecque.co.uk (nigel_graham(at)m-tecque.co.uk) wrote:
 --> Europa-List message posted by: nigel_graham(at)m-tecque.co.uk (nigel_graham(at)m-tecque.co.uk)Jonathan,I think you have provided the answer to your own question.The fact that you have run your Classic with no engine offset and noticed no asymmetric flying characteristics speaks volumes.The whole idea of canting an engine sideways and forcing the propeller disc through the air at anything other than normal to the oncoming airstream is daft.The theory that canting the engine sideways will counter the yaw effect of the prop wash seems to be based on a misunderstanding of what is really happening and it’s done because “that’s how it’s always been done”!On your Classic, you sensibly mounted your engine head on to the wind and you set you propeller blades pitch to the recommended angle. Each time the blades rotate their angles of attack remain equal to each other and constant to the oncoming wind and each blade generates the same thrust throughout each revolution of the prop.Now consider what happens when you follow the XS build instructions and cant the engine 1.5 degrees to the right.If you’re flying straight-and-level behind a right-hand tractor (Rotax 912, 914), each time a blade passes over the top of the ark, its pitch is effectively reduced by 1.5 degrees and as it swings through the bottom of the ark, its effective pitch is increased by 1.5 degrees.  This means that your propeller is producing significantly more thrust from the bottom half of the propeller disc than the top half – and that produces a pitch up change in attitude – and not the sideways thrust you had hoped to achieve by mounting the engine sideways.“So if that’s true, why has nobody noticed this pitch up attitude?” – a good question (even though I asked it myself).All Europa’s are fitted with a pitch trimmer – so these effects are unconsciously trimmed out by the pilot during different phases of flight.“Ah, but what about the propensity to swing to the left on take-off?”  - Same thing, different plane.The  Monowheel sits on the ground at a deck angle of (is it about 12 degrees? I forget) so the engine is now canted up at the front by this amount. At the beginning of the take-off run, the upcoming blade on the left hand side has 12 degrees wound off its effective pitch, while the down going blade on the right has 12 degrees added to its pitch. This produces significantly more thrust on the right hand side of the disc than the left, resulting in a turning moment to the left. It's a potential problem with all tail-draggersThe Tri-Gear variant of course sits horizontally on the ground, so has none of this asymmetric thrust – so is less prone to dive off to the left on take off; another reason why the Tri-Gear is perceived to be more benign than the Mono.Canting an engine is a very crude way of addressing a relatively transient problem – Fitting a rudder trimmer would be a far more elegant solution – should it be necessary.Hope that wasn’t too long winded!NigelPS the roll issue has nothing to do with engine position.
		pjeffers(at)talktalk.net Guest
				 Posted: Mon Jan 16, 2017 1:34 am    Post subject: 1.5 degrees right? |
				Hi all,
 Just for the record.  In the early pre history build of the classic Europa  the instructions said that the correct setup for the engine would be achieved if the 'washers' were adjusted such that the spinner lined up with the cowling. That supposedly gave us the 1.5 degree right offset. Nothing further was said on this issue.  My only comment is that it was a bit crude but seemed to work.
 A word of advice for Bob is that if you change your current setup for the engine mount then your spinner will not line up with your cowling. It is possible to address this misalignment but not simple.
 Pete J
 From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Robert Borger
 Sent: 15 January 2017 23:07
 Subject: Re: 1.5 degrees right?
 Nigel,
 Bob Borger
 3705 Lynchburg Dr.
 Cel: 817-992-1117
 Jonathan,
 Nigel
 Checked by AVG - www.avg.com
 Version: 01/15/17
		JonSmith
				 Posted: Mon Jan 16, 2017 1:58 am    Post subject: Re: 1.5 degrees right? |
				Hi Graham, I found your posting most interesting and thought provoking.  You go beyond my old "pilot book"!   We are all familiar to a certain extent with the old classic theories of propeller effects; torque, asymmetric blade, gyroscopic etc but I'd never considered detrimental effects caused by an engine offset.
 I remember quite well the famous diagram of the propeller slipstream helix spiralling around the fuselage and whacking the fin on one side or the other depending on direction of engine rotation - in our Rotax-Europa case the left side of the fin causing the nose to yaw more and more to the left with increasing power.  Certainly in my aircraft on the rare perfectly calm and smooth day with no other influencing factors I notice on take off that at the point of lift off a considerable amount of right rudder input is required at that point, nearly half I'd say.
 I suppose that aircraft design is always a compromise and there are various solutions to counter this problem, engine offsets, rudder trims (fixed and inflight adjustable), offset fins etc, all designed to help make life easier for the poor pilot who has to cope with the cacophony of forces his machine is constantly bombarded with!  Our Europa is as basic as you can get in it's standard form with the options of an offset engine mounting and/ or fixed rudder trim tab or nothing!
 I note and accept what you say about an engine offset causing inefficiencies and undesirable handling tendencies and that from a perfect performance point of view it would be absolutely the best for the engine to be mounted square on to the airflow but wouldn't the overall effect of the thrust vector being offset completely outweigh these minor undesirable tendencies and make life easier for the pilot?  My instinct tells me that the unwanted effects would be relatively insignificant but I genuinely don't know....!
 I've always considered that aircraft compromised by simplicity would in the ideal world be set up to fly perfectly straight and balanced with hands and feet off in the cruise as that's what we spend most of the time doing.  Thus in a perfect aircraft with the engine correctly offset this should be achieved without any extra trim tabs, assuming the designer got his sums correct with the offset!  (I'm lucky I think because my aircraft seems to achieve this quite nicely!).  I also note that you believe a rudder trim tab to be a better solution than an engine offset.  Do you consider that having the rudder permanently offset into the airflow to keep the aircraft balanced to be more efficient than the minor unwanted propeller blade effects caused by having an engine offset?  Again I'm only asking the question because I genuinely don't know..!
 I believe that a correctly offset engine will assist the pilot during take off by reducing the amount of right rudder deflection required throughout.  Without any offset to help, surely more right rudder deflection would be needed to keep straight thus effectively reducing the maximum crosswind component from the left that the aircraft itself could cope with?  A rudder trim would not help this situation of course - it might make reduce the load on the pilot's leg but the actual rudder deflection is still required.
 As I say, an interesting post, I'm very open minded but am yet to be convinced that I have made a mistake by following the manual and building mine WITH the quoted 1.5 degree offset....!
  _________________ G-TERN
Classic Mono |
		JonSmith
				 Posted: Mon Jan 16, 2017 2:22 am    Post subject: Re: 1.5 degrees right? |
				NIGEL - Doh - I'm very sorry to get your name the wrong way round in my post above.   I woke up early and it was still far too early when I wrote it.....!  That plus old age!
 Cheers, Jon
Classic Mono |
				 Posted: Mon Jan 16, 2017 2:45 am    Post subject: 1.5 degrees right? |
				Nigel, following on from this, I am most reluctant to believe that Ivan Shaw and Don Dykins (one of the outstanding aerodynamicists of our time!) got it wrong, or for that matter generations of designers of Spitfire/Hurricane era aircraft - which I believe al had engine offset and  fin offset incorporated, but even so were close to unmanageable if full power was used on take off. Performance then was very much a matter of life and death and an immense amount of research went into optimising performance - I certainly don't buy the notion that folk have always done it because  someone did it back in the dark ages and no-one has thought rationally about it since!
     Offsetting the engine 1.5 degrees makes negligible difference to forward thrust - actually reduces it by just 0.03%, but using permanent right rudder induces extra drag which must be  an appreciably greater amount.
     Regards, David Joyce, GXSDJ
 On 2017-01-16 09:58, JonSmith wrote:  	  | Quote: | 	 		    	  | Quote: | 	 		  --> Europa-List message posted by: "JonSmith" <jonsmitheuropa(at)tiscali.co.uk (jonsmitheuropa(at)tiscali.co.uk)>
 G-TERN
 Classic Mono
 http://forums.matronics.com/viewtopic.php?p=465129#465129
 ics.com
 .com
		ptag.dev(at)talktalk.net Guest
				 Posted: Mon Jan 16, 2017 6:23 am    Post subject: 1.5 degrees right? |
				Hi! Pete  and in response to all .....and when all is done and said don’t forget to allow for “prop-wash” when doing all your theorising .
 The mono would be uncontrolled in a “full chat” turbo wide open takeoff situation with my CS Woodcomp  selected  in “take off” .Even in trike configuration it requires full Rudder to remain straight ahead. Then add a considerable cross wind and you are set for a ground loop immediately the rear wheel brakes clear of the runway. Without differential braking the Fin and rudder don’t have adequate authority .......IMHO ! Having said that I have landed at Marehamn against a 35 Knot wind from the Port side with rotor effect from trees 200 yards to the port side. Thank the lord for trike differential braking in that event.
 Regards to all
 Bob Harrison  G-PTAG.
 From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Peter Jeffers
 Sent: 16 January 2017 09:34
 Subject: RE: 1.5 degrees right?
 Hi all,
 Pete J
 From: owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com) [mailto:owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com)] On Behalf Of Robert Borger
 To: europa-list(at)matronics.com (europa-list(at)matronics.com)
 Nigel,
 Bob Borger
 3705 Lynchburg Dr.
 Cel: 817-992-1117
 Jonathan,
 Nigel
 Version: 01/15/17
 Version: 01/16/17
		budyerly(at)msn.com Guest
				 Posted: Mon Jan 16, 2017 7:35 am    Post subject: 1.5 degrees right? |
				To All,
 An airplane is 20,000 compromises flying in close formation. Each change we make affects others, and some are necessary to fine tune the aircraft for normal  operations.
 Off the very empty top of my head:
 From an aero standpoint, fuselage squareness, tail squareness, wing incidence differences in construction, etc. cause most of our trim problems at cruise in  the Europa.
 As for rudder/fin offset vs. engine offset to correct for P factor, drag due to tail area for an offset to counteract the slipstream and P factor affect is  small at cruise for each. However, in a full power 914 with Airmaster on takeoff and climb out, the rudder required to hold yaw in check is reduced with offset. Interesting to note is in propeller testing, if you trim a plane for perfect ball with a fixed  pitch, then put on a constant speed, a touch more right rudder is required to hold the wings level and the ball solidly in the center. Reduce power on the Constant Speed prop and suddenly left rudder is needed. I prefer engine offset myself as the offset  is really small (a degree or so) to accommodate P factor and slipstream yaw. Offsetting the rudder/fin on a short fuselage and induced drag becomes a factor. A one degree offset of the rudder is .01 Cd which is not much drag or about 5 pounds per degree  on a 15 sq ft fin/rudder, but it is drag, whereas prop offset drag is nill and the loss of thrust is nill also at such low angles. I agree with the Europa designers, as does David and others, drag is drag. On Classics in my shop, the offset on an 80HP fat  nosed Classic was very little. Let’s face it, the instructions said align the engine with the cowl. If you cut the cowl, who knows what you have without measuring. But on the Classic, that was not mentioned. Oh well, progress was made with the XS.
 The light propeller aircraft is trimmed for one airspeed and power setting. Change speed, weight (angle of attack), propeller length or pitch, or power setting  and the trim in pitch and roll due to yaw changes. Since the fuselage longitudinal axis and engine are at the same pitch setting, the small yaw offset of the engine is not going to be much, nor is a yaw due to fin trim. Normally, the 1 and 1/16 inch offset  is fine and if not, I decrease the length of the right/left rudder cable about ½ inch to spring the rudder over a bit on some aircraft to trim the ball. However, for any roll and yaw combined problem, I would look at a droopy flap. Somehow flaps sometimes  get leaned on and just a 1/16 of an inch flap droop is quite a bit of roll and yaw. Whereas changing the engine offset will be very little yaw (and small roll).
 Fly the plane and center the ball. If it is still rolling it is most likely your wing trim. Either a flap is drooping, or somehow spring has been built into  your ailerons. (Spring in the ailerons is seen when the stick does not stay exactly where it is put on the ground. Some builders build in problems that cause the aileron to spring one direction or the other.) Also look at your wing drag covers, and pants  on a Trigear for alignment. A droopy wheel pant due to rough field operations is quite a bit of drag as are the wing flap bracket covers if misaligned.
 When the ball can be centered and all roll stops (pat yourself on the back for well trimmed wings) your problem is most likely P factor. Shorten the cable  on the side of the rudder is depressed will normally fix it. If that is not enough, then a tab (or stronger spring) is necessary on that side. Keeping a plane well trimmed out is a constant problem. Every 5 years, look hard at the plane as due to wear and  tear, things get out of alignment. Any change from your original fly off trim settings must be investigated, as something has changed.
 Just my thoughts.
 Bud Yerly
 I’m pulling in 12AY soon for Sun n Fun prep. Join us this year in Lakeland and meet up with Club members and Europafiles alike at site N-55 again this year  and get away from the winter doldrums. Our display emphasis this year will be on the Airmaster propeller which was a game changer for transforming the Europa and many other aircraft into efficient cruising airplanes.
 From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of davidjoyce(at)doctors.org.uk
  Sent: Monday, January 16, 2017 5:42 AM
  Subject: Re: Europa-List: Re: 1.5 degrees right?
 Nigel, following on from this, I am most reluctant to believe that Ivan Shaw and Don Dykins (one of the outstanding aerodynamicists of our time!) got it wrong,or for that matter generations  of designers of Spitfire/Hurricane era aircraft - which I believe al had engine offset and fin offset incorporated, but even so were close to unmanageable if full power was used on take off. Performance then was very much a matter of life and death and an  immense amount of research went into optimising performance - I certainly don't buy the notion that folk have always done it because someone did it back in the dark ages and no-one has thought rationally about it since!
 On 2017-01-16 09:58, JonSmith wrote:  	  | Quote: | 	 		    	  | Quote: | 	 		  | --> Europa-List message posted by: "JonSmith" <jonsmitheuropa(at)tiscali.co.uk (jonsmitheuropa(at)tiscali.co.uk)>Hi Graham, I found your posting most interesting and thought provoking. You go beyond my old "pilot book"! We are all familiar to a certain extent with the old classic theories of propeller effects; torque, asymmetric blade, gyroscopic etc but I'd never considered detrimental effects caused by an engine offset.I remember quite well the famous diagram of the propeller slipstream helix spiralling around the fuselage and whacking the fin on one side or the other depending on direction of engine rotation - in our Rotax-Europa case the left side of the fin causing the nose to yaw more and more to the left with increasing power. Certainly in my aircraft on the rare perfectly calm and smooth day with no other influencing factors I notice on take off that at the point of lift off a considerable amount of right rudder input is required at that point, nearly half I'd say. I suppose that aircraft design is always a compromise and there are various solutions to counter this problem, engine offsets, rudder trims (fixed and inflight adjustable), offset fins etc, all designed to help make life easier for the poor pilot who has to cope with the cacophony of forces his machine is constantly bombarded with! Our Europa is as basic as you can get in it's standard form with the options of an offset engine mounting and/ or fixed rudder trim tab or nothing! I note and accept what you say about an engine offset causing inefficiencies and undesirable handling tendencies and that from a perfect performance point of view it would be absolutely the best for the engine to be mounted square on to the airflow but wouldn't the overall effect of the thrust vector being offset completely outweigh these minor undesirable tendencies and make life easier for the pilot? My instinct tells me that the unwanted effects would be relatively insignificant but I genuinely don't know....! | 	  0 1 2 3 4 5 6 7 8 9  	  | Quote: | 	 		  | Hi Graham, I found your posting most interesting and thought provoking. You go beyond my old "pilot book"! We are all familiar to a certain extent with the old classic theories of propeller effects; torque, asymmetric blade, gyroscopic etc but I'd never considered detrimental effects caused by an engine offset. | 	  0  	  | Quote: | 	 		  | Hi Graham, I found your posting most interesting and thought provoking. You go beyond my old "pilot book"! We are all familiar to a certain extent with the old classic theories of propeller effects; torque, asymmetric blade, gyroscopic etc but I'd never considered detrimental effects caused by an engine offset. | 	  1  	  | Quote: | 	 		  | Hi Graham, I found your posting most interesting and thought provoking. You go beyond my old "pilot book"! We are all familiar to a certain extent with the old classic theories of propeller effects; torque, asymmetric blade, gyroscopic etc but I'd never considered detrimental effects caused by an engine offset. | 	  2  	  | Quote: | 	 		  | Hi Graham, I found your posting most interesting and thought provoking. You go beyond my old "pilot book"! We are all familiar to a certain extent with the old classic theories of propeller effects; torque, asymmetric blade, gyroscopic etc but I'd never considered detrimental effects caused by an engine offset. | 	  3  	  | Quote: | 	 		  | Hi Graham, I found your posting most interesting and thought provoking. You go beyond my old "pilot book"! We are all familiar to a certain extent with the old classic theories of propeller effects; torque, asymmetric blade, gyroscopic etc but I'd never considered detrimental effects caused by an engine offset. | 	  4  	  | Quote: | 	 		  | Hi Graham, I found your posting most interesting and thought provoking. You go beyond my old "pilot book"! We are all familiar to a certain extent with the old classic theories of propeller effects; torque, asymmetric blade, gyroscopic etc but I'd never considered detrimental effects caused by an engine offset. | 	  5  	  | Quote: | 	 		  | Hi Graham, I found your posting most interesting and thought provoking. You go beyond my old "pilot book"! We are all familiar to a certain extent with the old classic theories of propeller effects; torque, asymmetric blade, gyroscopic etc but I'd never considered detrimental effects caused by an engine offset. | 	  6  	  | Quote: | 	 		  | Hi Graham, I found your posting most interesting and thought provoking. You go beyond my old "pilot book"! We are all familiar to a certain extent with the old classic theories of propeller effects; torque, asymmetric blade, gyroscopic etc but I'd never considered detrimental effects caused by an engine offset. | 	  7  	  | Quote: | 	 		  | Hi Graham, I found your posting most interesting and thought provoking. You go beyond my old "pilot book"! We are all familiar to a certain extent with the old classic theories of propeller effects; torque, asymmetric blade, gyroscopic etc but I'd never considered detrimental effects caused by an engine offset. | 	  8  	  | Quote: | 	 		  | Hi Graham, I found your posting most interesting and thought provoking. You go beyond my old "pilot book"! We are all familiar to a certain extent with the old classic theories of propeller effects; torque, asymmetric blade, gyroscopic etc but I'd never considered detrimental effects caused by an engine offset. | 	  9 0 1 2 3 4 5 6 7 8  |
				 Posted: Tue Jan 17, 2017 6:04 am    Post subject: 1.5 degrees right? |
				Hi Bud,
 Another gem of a post that will be copied into my burgeoning "Bud's
 Tips" folder.
 I agree with nearly all of what you say but as is always the case; a
 good explanation prompts another question.
 You have discussed the aerodynamic pros and cons, but of equal
 importance is the mechanical consequence of an offset engine.
 The apparent pitch difference of blade rotating around an offset
 engine will be double the engine offset.  A blade will experience a
 change from -1.5 to +1.5 – so a delta of 3 degrees. Now if a customer
 of yours came to you with a fixed pitch Warpdrive, and you discovered
 he had set one blade 3 degrees coarser than the rest – I’m pretty sure
 you would send him away with a flee in his ear and tell him to correct
 it. But we seem quite happy to accept the same degree of blade
 variance if we offset our engine – without question.
 The constantly fluctuating angle of attack introduces cyclic loading
 and unloading of the blades which can produce torsional vibration.
 This is then transmitted to the swash plate and drive pins of the
 constant speed unit – which is not a good thing.
 A good buddy of mine (and one of your fellow countrymen) has a
 successful business designing and building custom propellers and wings
 for the Formula 1 Reno boys. He showed me a picture of one of his
 custom two-blade fixed pitch props that had failed catastrophically
 during a race. It was unusual in that it had split from tip to root.
 All calculations indicated that it should have been more than strong
 enough to absorb the power; however the prop had failed due to extreme
 torsional oscillation along the blade length.  By working closely with
 the owner, he was able to establish that the plane builder had offset
 the engine.  A new (identical) prop was made, the engine offset zeroed
 out – and the racer went on to win gold – with no further problems. It
 was during one of our “sitting by the pool drinking beer and talking
 planes” sessions that he first asked what I was going to do regarding
 the offset of my then new Europa. …… it got me thinking.
 Now with regard to the suggestion of fitting a rudder trimmer (purely
 hypothetical as I have no plans to take a saw to my fin), I was a
 little surprised by the strength of reaction to this suggestion on the
 grounds of increased drag. I am also curious as to why our attitude to
 controlling yaw trim is so different to the way we control pitch trim.
 The pitch control system uses an all flying tailplane with a (very
 good) trim system. According to Don Dykins book, during the cruise,
 the tailplane is constantly “flying” the rear of the aircraft
 downwards to maintain level flight. This will be generating drag too –
 but we accept this without question!
 When considered against the cumulative drag created by the nose wheel
 , main gear, outriggers tailwheel, flap hinges, GPS antenna fuel
 vents, strobes and door handles, surely, the extra drag of a rudder
 trimmer would pail into insignificance but surely make life so much
 easier in the climb out or cruise.
 I have re-read my original response to Jonathan and I stand by
 everything I said. I think the explanation of the aerodynamics is
 accurate (certainly nobody has challenged it) and my advice that “if
 it ain broke, don’t fix it” also stands.
 For every pilot happily flying a Classic with no engine offset and
 reporting no problems, there seems to be another flying an XS with
 offset experiencing problems. I suspect that the real explanation is
 muscle memory. Experienced feet will move by themselves without the
 owner even being aware. Those with slower feet will find themselves
 “behind the curve”.
 Keep the thoughts coming.
 Nigel
 Quoting Bud Yerly <budyerly(at)msn.com>:
  	  | Quote: | 	 		   To All,
  Just my thoughts.
  Bud Yerly
  Subject: Re: Re: 1.5 degrees right?
  since!
  <jonsmitheuropa(at)tiscali.co.uk<mailto:jonsmitheuropa(at)tiscali.co.uk>>
  or nothing!
  G-TERN
  Classic Mono
  ics.com
  .com
				 Posted: Tue Jan 17, 2017 7:26 am    Post subject: 1.5 degrees right? |
				Hi Nigel,
 You obviously did not read either my message or the Classic build manual which states that the engine offset on the classic is achieved by adjusting the washers in order to align the prop with the cowlings.  Inference is that the cowlings had the offset built into them.
 Pete
				 Posted: Tue Jan 17, 2017 8:58 am    Post subject: 1.5 degrees right? |
				Hi Pete,
 I have read both.
 I've also seen cowlings that have had their firewall face trimmed to
 allow the aperture to align with the propeller hub.
 As you say "it was a bit crude but seemed to work".
 Nigel
 Quoting Peter Jeffers <pjeffers(at)talktalk.net>:
  Hi Nigel,
  into them.
  Pete
		JonathanMilbank
				 Posted: Tue Jan 17, 2017 1:13 pm    Post subject: Re: 1.5 degrees right? |
				I've read and re-read all of your comments with much interest and there's one observation I'd like to make. I'm fairly sure that the early Classic Europas had no engine offset and that the designers might have thought it unnecessary with only 80hp from a 912UL. The 912S wasn't available then.
 My reasons for thinking this are that the topic never got mentioned by anyone at any time. The brilliant Don Dykins makes no mention of it to my knowledge in his paper "Understanding the Aerodynamics of your Europa".
 Furthermore when I was building my aircraft over 20 years ago, the cowls needed at least as much trimming and fettling as do the XS cowls to get them to match the fuselage, which makes it seem unlikely that the cowls on the Classic were serving as datum for correct engine/propeller alignment.
 My final reason is of the "proof of the pudding" variety, in that my Classic has a very pronounced swing to the left when applying power at low speed. Not that I noticed it, but someone else who was unfamiliar with my Europa definitely did notice.
				 Posted: Tue Jan 17, 2017 1:50 pm    Post subject: 1.5 degrees right? |
				This is from the Rotax Installation Manual.
 Dave
 The engine mounting frame has been designed with the engine offset to the right by 1.5°. To check
 that this offset is correct, clamp a straight edge to the propeller flange horizontally and mark a point
 51 cm (20") each side of the engine centre line. Measure the distance from these points, parallel to the
 aircraft centre line, to the firewall. The difference between the two readings should be 26 mm
 (1 1/16"). If any correction is found necessary, shim between the landing gear frame and the
 appropriate cup washer using AN960-516L washers. In order to ensure that the split pin is correctly
 positioned relative to the castellated nut it will be necessary to use a total of at least 4 washers on each
 bolt. Any washers that are not needed to act as positioning shims should be placed immediately
 under the nut. Make a note of where and how many shim washers are used for later reference.
 Dave Park
  	  | Quote: | 	 		   On 17 Jan 2017, at 21:13, jonathanmilbank <jdmilbank(at)yahoo.co.uk> wrote:
  My reasons for thinking this are that the topic never got mentioned by anyone at any time. The brilliant Don Dykins makes no mention of it to my knowledge in his paper "Understandings the aerodynamics of your Europa".
  http://forums.matronics.com/viewtopic.php?p=465169#465169
