Posted: Sun Feb 12, 2017 11:05 am Post subject: Everything I Need To Know About Transponders |
At 09:58 PM 2/11/2017, you wrote:
| Quote: | Hi Bob,
Just wondering where I should begin looking for more information on transponders. Is there a source of information I could access that would answer questions, such as what are the minimum requirements for transponders? What are the equipment standards for transponders? What should I look for in a new transponders? Are there changes coming in the standardization? What is this ADB(?) all about? I will appreciate your comments and suggestions. If there are other questions I should be asking, please address them as well. Thank for considering my inquiry. |
I've not kept current with the requirements
or all the features/options in the transponder
world. I've posted this question to the
AeroElectric-List. There are folks on tha
service with a great deal more knowledge on
this topic.
Joined: 28 Mar 2008 Posts: 1946 Location: Riley TWP Michigan
Posted: Sun Feb 12, 2017 12:26 pm Post subject: Re: Everything I Need To Know About Transponders |
ADS-B will let you see other aircraft on a glass panel in your airplane. And other pilots will be able to see you. It is like having a radar screen in your cockpit.
ADS-B-OUT will be required in many areas in 2020. If buying a new transponder, you might as well make sure it has ADS-B. If you do not fly near big cities where ADS-B will be required, then you could buy a used transponder without ADS-B for well less than $1000. Lots of used transponders are available as more and more aircraft are upgrading to ADS-B-OUT to meet the 2020 mandate.
When shopping for a transponder with ADS-B, I recommend that you buy one that contains an internal 2020 compliant GPS receiver instead of two separate units. Here are some models to consider:
APPAREO STRATUS ESG
GARMIN GTX335
GARMIN GTX345
L-3 Avionics LYNX NGT-9000
Prices vary from $3000 to $9000
There are a lot more options and equipment to consider. Research before buying.
_________________ Joe Gores |
donvansanten(at)gmail.com Guest
Posted: Sun Feb 12, 2017 12:54 pm Post subject: Everything I Need To Know About Transponders |
One additional comment. The external waas certified gps must also be on the approved list for the mode S transponder that it is feeding location information. At this point the Garmin 430w/530w are not on any approved list. This may change with software updates. Garmin did noy mention the 480 so it is currently an unknown.
On Feb 12, 2017 12:36 PM, "Kelly McMullen" <kellym(at)aviating.com (kellym(at)aviating.com)> wrote: | Quote: | --> AeroElectric-List message posted by: Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
There is no change in the airspace requiring a transponder. However, there is a new requirement for ADS-B equipment. There are two ways to comply. You can either get a Mode S transponder that has software to give the data output needed, or you can get a UAT unit that is tied to your Mode C transponder. Either variety has to have either an internal GPS that meets requirements, or be connected to a certified WAAS IFR GPS. There are a number of sources for the information, including manufacturers. However, a lot will confuse the issue.
The requirements are only to transmit the required data stream.
There are no reception requirements, but that is another entire ball of wax, as to what traffic and weather you do or don't receive, and how you display it in the cockpit. Very useful, but not required.
Kelly
On 2/12/2017 11:59 AM, Robert L. Nuckolls, III wrote:
| Quote: | At 09:58 PM 2/11/2017, you wrote:
| Quote: | Hi Bob,
this topic.
ceengland7(at)gmail.com Guest
Posted: Sun Feb 12, 2017 1:14 pm Post subject: Everything I Need To Know About Transponders |
To be clear, there *will be* a new requirement. In 2020, but not at the moment. The FAA certainly held to its traditional Pro Grade Obfuscation in writing the upcoming regs, but basically you'll need ADSB out, with a Certifiable WAAS position source. *And* you'll need to keep a traditional transponder with encoder, unless you go with a Mode S with Extended Squitter (remember offuscation?).
Opinions vary widely on whether ADSB prices will continue to fall, or start to rise, as 2020 approaches.
On Sun, Feb 12, 2017 at 2:27 PM, Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)> wrote:
Kelly
| Quote: | Hi Bob,
this topic.
jim(at)PoogieBearRanch.co Guest
Posted: Sun Feb 12, 2017 1:47 pm Post subject: Everything I Need To Know About Transponders |
Dion said:
<< At this point the Garmin 430w/530w are not on any approved list. This
may change with software updates. >>
I don't believe that statement is true, as both of these WAAS-equipped
devices ARE approved GPS sources for any of the Garmin ADS-B Out
transponders. I had a GTX-330 upgraded to 330ES (around $1200) by
Garmin, then connected to my 430W (cost about $600 for the shop to
rewire to add the GPS connector to the 330ES). This was fully approved,
and passed all the FAA's ADS-B Out testing. And a friend who had a 530W
and 330 did the same with his plane, and likewise passed the FAA
testing. I also know of several people who have upgraded to Garmin 335
and 345 transponders and used their 430W/530W as the GPS-WAAS source for
their ADS-B installations.
One possible source of confusion might be that the older non-WAAS
4XX/5XX models are NOT approved because they lack the WAAS GPS
capability. A non-WAAS 430 (or 530) would need to be upgraded to 430W
(or 530W) to add the WAAS capability. This can only be done by Garmin,
and I think they charge something like $3,000 (IIRC) to upgrade the
units.
But the bigger issue for Garmin 430W/530W owners is working with
non-Garmin ADS-B transponders... I believe the issue is that (at least
at one time) the Trig ADS-B transponder (which is re-sold by Avidyne and
several others under their own company name) was NOT certified with the
430W/530W. Obviously, Garmin had no interest in pursuing certification
with someone else's equipment, and although I think Trig eventually
certified their own proprietary brand unit with the 430W/530W,
apparently the other companies that were re-selling the Trig unit did
not pursue certification with the Garmin either. But check into it,
because this stuff changes very rapidly.
Jim Parker
Posted: Sun Feb 12, 2017 2:12 pm Post subject: Everything I Need To Know About Transponders |
I don't believe there will be any "new" requirements in 2020 that aren't
already on the books. The current rules state that after Jan 1, 2020,
you will still need a Mode-C / Mode-S transponder anywhere you need one
today -- that's not changing. But you will also need to EITHER upgrade
to a 1090ES transponder (one that provides the "Extended Squitter"
capability), OR that you would need to add a UAT transmitter (978UAT) --
in addition to your Mode-C / Mode-S transponder. The UAT has to
integrate with your existing Mode-C / Mode-S transponder to pick up the
transponder squawk code (among other things) to include in the ADS-B OUT
data stream.
If you remain within the US borders, and never fly above 18,000 feet,
978UAT is "good enough". And since an "ab-initio" UAT solution
(including the WAAS GPS receiver) can be less expensive to install,
about 20-25% of the aircraft equipping for ADS-B are taking that option.
But, if you fly above 18,000 feet, you will be required to use the
1090ES version. And if you fly internationally (Canada, Mexico,
Carribean, etc.), the odds are pretty good that you will also need the
1090ES version. To this point, ICAO has not recognized 978 UAT as a
"standard", so it may wind up being a "US only" option. Thus far, the
vast majority of aircraft upgrading to ADS-B OUT seem to be doing 1090ES
upgrades -- something like 75-80% of the ADS-B OUT fleet is 1090ES,
depending on whose data you use. As for cost, those who already have a
certified WAAS-GPS receiver may find it far less expensive to go this
route. My previous airplane that had a 430W and a GTX-330 cost me well
under $2,000 to upgrade to 1090ES by upgrading the 330 to 330ES ($1,200
through Garmin) and wiring the 430W to the 330ES ($500-600 to the
avionics shop doing that work).
Jim Parker
Posted: Sun Feb 12, 2017 2:24 pm Post subject: Everything I Need To Know About Transponders |
Jim,
You are correct wit is that h regaeds to the Garmin transponders. The information that I have from Trig i and a Avidyne 540Ts that Garmin 430w/530w are not approved as the gps source unless they are updated per Garmin. The software update is not currently available and may never become available. My work around is a Trig/Dynon 261 mode s and an Avidyne 540T all certified and approved. Only draw back was the price.
Don
On Sun, Feb 12, 2017 at 1:44 PM, <jim(at)poogiebearranch.com (jim(at)poogiebearranch.com)> wrote:
[quote]--> AeroElectric-List message posted by: <jim(at)poogiebearranch.com (jim(at)poogiebearranch.com)>
units.
Jim Parker
Posted: Sun Feb 12, 2017 2:27 pm Post subject: Re: Everything I Need To Know About Transponders |
Here is a link to the FAA's list of approved ADS-B Certified Equipment.
https://www.faa.gov/nextgen/equipadsb/equipment/
Unfortunately they do not keep it up to date.
alec(at)alecmyers.com Guest
Posted: Sun Feb 12, 2017 2:49 pm Post subject: Everything I Need To Know About Transponders |
As things stand, there are no requirements for anything beyond old fashioned mode C to be mandatory in any parts of Canada. And even that is only required in a very small portion of airspace.
On Feb 12, 2017, at 17:08, <jim(at)PoogieBearRanch.com> <jim(at)PoogieBearRanch.com> wrote:
1090ES version.
Posted: Sun Feb 12, 2017 3:39 pm Post subject: Everything I Need To Know About Transponders |
My point is that it's not a current requirement; it *will be* in 2020.
On Sun, Feb 12, 2017 at 4:08 PM, <jim(at)poogiebearranch.com (jim(at)poogiebearranch.com)> wrote:
data stream.
Jim Parker
