Fwd: CNBTR connector
pelletie1959(at)me.com
PostPosted: Tue Feb 14, 2017 3:39 pm    Post subject: Fwd: CNBTR connector Reply with quote
Somebody knows this kind on connector and how to open the female one, to be able to solder my wires.
https://www.amazon.com/gp/product/B01DIY1Z12/ref=s9_acsd_hps_bw_c_x_1_w
Daniel Pelletier
edpav8r(at)yahoo.com
PostPosted: Tue Feb 14, 2017 11:35 pm    Post subject: Fwd: CNBTR connector Reply with quote
Does the threaded collar unscrew from the cable-grip end of the connector body? If so, you may find one or more screws hidden under the collar that allow the body to be split. It seems to me that I once used a similar connector made by Hirose Electric of Japan that opened this way.
Eric
On Feb 14, 2017, at 3:36 PM, DANIEL PELLETIER <pelletie1959(at)me.com> wrote:
> Daniel Pelletier
PostPosted: Wed Feb 15, 2017 2:05 am    Post subject: Fwd: CNBTR connector Reply with quote
At 05:36 PM 2/14/2017, you wrote:
--> AeroElectric-List message posted by: DANIEL PELLETIER <pelletie1959(at)me.com>
> Daniel Pelletier
I've not encountered that particular product
before. It APPEARS to be a plastic clone of
the Mil-C-5015 connectors with roots dating
back to WWII. If so, check as follows:
[img]cid:7.1.0.9.0.20170215034727.0539fdd8(at)aeroelectric.com.0[/img]
See if there is a threaded joint under
the shaded area. Unscrew the back-shell
from the connector body. The Threaded
ring that engages the mating connector
simply floats on the housing held in
place by the back-shell.
mating
 Filesize:  34.37 KB
 Viewed:  6461 Time(s)
> Daniel Pelletier
[img]cid:7.1.0.9.0.20170215035930.05528b88(at)aeroelectric.com.1[/img]
mating
-I STAND CORRECTED -
Found a whole line of products from CNBTR that
includes some solder-cup, emulations (if not
exact clones) of a Mil-spec connector line.
I've ordered one in to take a peek
http://tinyurl.com/jdgnmtt
These are an interesting product with an
attractive price. I'm looking forward
to a closer look.
 Filesize:  34.37 KB
PostPosted: Wed Feb 15, 2017 7:00 am    Post subject: Fwd: CNBTR connector Reply with quote
Thank you Bob,
You're right for the threaded joint under the shaded area. To unscrew the back-shell from the connector body, we must let the male part in place in the female part. You place the male part in a vise and use a vise grip to unscrew the back-shell. A particularity you unscrew counter clockwise.
Daniel
Le 15 févr. 2017 à 05:02, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> a écrit :
--> AeroElectric-List message posted by: DANIEL PELLETIER <pelletie1959(at)me.com (pelletie1959(at)me.com)>
> Daniel Pelletier
<26db80.jpg>
mating
to a closer look.
PostPosted: Wed Feb 15, 2017 7:37 pm    Post subject: Fwd: CNBTR connector Reply with quote
At 08:58 AM 2/15/2017, you wrote:
Thank you Bob,
Yeah, these appear to be a near-if-not-exact clone
of a legacy mil-spec connector. I'll know more about
them when the sample I ordered gets here. The
prices are certainly right . . .
jan_de_jong(at)casema.nl
PostPosted: Thu Feb 16, 2017 1:53 am    Post subject: Fwd: CNBTR connector Reply with quote
Here the whole range, up to 65 pins:
https://www.aliexpress.com/wholesale?catId=0&initiative_id=SB_20170216014307&SearchText=y2m+connector
Interested in your conclusions..
Jan de Jong
Thank you Bob,
PostPosted: Thu Feb 16, 2017 9:16 am    Post subject: Fwd: CNBTR connector Reply with quote
thanks! at first blush, these seem to be a close
cousin to M311X series connectors (solder cup)
otherwise identical and mates with M312X series
(crimp pins).
It would be really cool if these in fact do
mate with the M31XX devices.
