PSalter(at)aol.com Guest
Posted: Wed Jul 12, 2006 5:42 am Post subject: Oil Temp Gauge CJ6A |
My oil temp gauge is pegging when I have the switch in the upper position. My guess is a broken wire at a cannon plug. Any advice on the proper use of the switch(temps and when to use) and the cure for the maxed out gauge?
I have scanned the manuals for information relating to the oil temp gauge and have found nothing.
Phil
jimscjs(at)mbay.net Guest
Posted: Wed Jul 12, 2006 6:52 am Post subject: Oil Temp Gauge CJ6A |
your right it will be a wire at the cannon plug end at the engine probably.
jim
wlannon(at)cablerocket.co Guest
Posted: Wed Jul 12, 2006 7:39 am Post subject: Oil Temp Gauge CJ6A |
Phil;
Either a broken wire at the probe end connector or an open circuit in the probe. That is the oil out probe. The oil out temp. is not normally monitored in Western engine installations. It is monitored during engine test cell run after overhaul. You should normally see about a 30 deg.C increase over the oil in temp. Max allowable oil out is 125 degs. C but you would rarely see it that high with the Huosai.
Walt
