philperry9
Posted: Thu Feb 23, 2017 9:36 am Post subject: One last question - almost |
I'm about to close up this aft deck area to prep for the inspection. Before I do, I'm just going over everything one last time.
For those if you using the overhead console from Geoff, have any of you had experience with using an undersized hole in the bulkhead? Just curious how the airflow is...
I punched a 1" hole inside the 2" scat connector. I just couldn't bring myself to knocking a 2" hole in that bulkhead.
I also drilled a 1/8" drain hole to let any water drain out. I'll attach a photo so you can see.
I'm just curious if anyone else has done something similar with a 1" hole and I'm most curious about how happy you are with he airflow.
Phil
65.79 KB |
3530 Time(s) |
civengpe
Posted: Thu Feb 23, 2017 10:35 am Post subject: One last question - almost |
Phil,I used two 1" holes with 2"X1" bulkhead adapters. The airflow seems very good to me.
Shannon
On Thu, Feb 23, 2017 at 11:35 AM, Phillip Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)> wrote:
| Quote: | I'm about to close up this aft deck area to prep for the inspection. Before I do, I'm just going over everything one last time.
Phil
122.94 KB |
3528 Time(s) |
456.34 KB |
3528 Time(s) |
