Starter hesitation
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> LycomingEngines-List
RV7ASask
PostPosted: Mon Mar 06, 2017 12:34 pm    Post subject: Starter hesitation Reply with quote
I have a Sky-Tec starter on a Lycoming IO360. It has always started the engine BUT lately when I push the START button there is a pause. Sometimes it is a long pause then it kicks in. Sometimes I release the button and try again. I have a fear it will not start one time when I am a long way from maintenance or from home. Is this a symptom of something worse to come? Should I be concerned?
David Lamb
RV7A C-FLAM
- The Matronics LycomingEngines-List Email Forum -
http://www.matronics.com/Navigator?LycomingEngines-List
BARRY CHECK 6
PostPosted: Mon Mar 06, 2017 1:01 pm    Post subject: Starter hesitation Reply with quote
David:
You have a right to be A FEARED!  The problem is NOT the starter...  Well, it maybe but I have seen and heard of the same problem many a time - AND the problem being the STARTER RELAY.  Sky-tech has had quite a few failures and they offer a NEW REPLACEMENT Starter Relay - IF!  You are using their relay.
NOW!  If you are not using their relay you have to do some very simple checking:
1 - Remove ALL the Nuts, Lock Washers and Cables from the entire Starter System.  This includes the BATTERY!
2 - CLEAN the Posts, Nuts and Cables - Use a wire brush.  If you have/see corrosion wash down the corrosion with VINEGAR <-- Yes, Vinegar. Follow that up with Baking Soda and Water...  Lots of water.
3 - REPLACE the Lock Washers with NEW Internal Star Lock Washers.
4 - Another TRICK...  Take a VOLTAGE reading ACROSS the Master Relay and the Starter Relay when there is Power Applied. NOTE:  Remove the cable from the STARTER Relay to the Starter.  You don't want the engine to start!!!   You should get ZERO (0) Volts.  ANY voltage indicates Resistance within the relay, that means it is time to replace the relay(s).  YOU DID do ALL of the above steps before you did Step 4, didn't you?
Hope this helps.
Barry
On Mon, Mar 6, 2017 at 3:34 PM, RV7ASask <rv7alamb(at)sasktel.net (rv7alamb(at)sasktel.net)> wrote:
--> LycomingEngines-List message posted by: "RV7ASask" <rv7alamb(at)sasktel.net (rv7alamb(at)sasktel.net)>
David Lamb
RV7A C-FLAM
http://forums.matronics.com/viewtopic.php?p=466947#466947
rum -
mingEngines-List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?LycomingEngines-List
FORUMS -
WIKI -
b Site -
          -Matt Dralle, List Admin.
fherr(at)cfl.rr.com
PostPosted: Mon Mar 06, 2017 1:34 pm    Post subject: Starter hesitation Reply with quote
Personally David, I would check the battery also. It could show 12.2+ volts and yet have not enough amperage available to turn the engine.
And yes, you should be concerned, much concerned.
Francis
On Mar 6, 2017, at 4:00 PM, FLYaDIVE <flyadive(at)gmail.com (flyadive(at)gmail.com)> wrote:
David:
Hope this helps.
Barry
--> LycomingEngines-List message posted by: "RV7ASask" <rv7alamb(at)sasktel.net (rv7alamb(at)sasktel.net)> I have a Sky-Tec starter on a Lycoming IO360. It has always started the engine BUT lately when I push the START button there is a pause. Sometimes it is a long pause then it kicks in. Sometimes I release the button and try again. I have a fear it will not start one time when I am a long way from maintenance or from home. Is this a symptom of something worse to come? Should I be concerned? Thanks David Lamb RV7A C-FLAM Read this topic online here: http://forums.matronics.com/viewtopic.php?p=466947#466947 ==================================== rum - mingEngines-List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?LycomingEngines-List ==================================== FORUMS - eferrer" target="_blank">http://forums.matronics.com ==================================== WIKI - errer" target="_blank">http://wiki.matronics.com ==================================== b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution ====================================
RV7ASask
PostPosted: Tue Mar 07, 2017 5:43 am    Post subject: Re: Starter hesitation Reply with quote
Thanks Francis and Barry. I will start with this. Appreciate the input.
David
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> LycomingEngines-List All times are GMT - 8 Hours
