nickc(at)mtaonline.net Guest
Posted: Tue Mar 07, 2017 3:42 pm Post subject: Internal Auto fuel pump? |
Kolbers,
I was talking with an A&P, at the airport about the size of my fuel tank, and leaving space for the in external fuel pump behind the tank, while still maximizing the size of the tank. He said that in his experience an automotive style internal fuel pumps are far more reliable and when installed in the tank, would allow for a lager tank size…
This guy has been around, and has a good reputation. I would be interested in your thoughts…you don’t have to hold back:)
Nick Cassara
PAAQ
Palmer, Alaska
N607AK still on the ground…
lcottrell
Posted: Tue Mar 07, 2017 5:52 pm Post subject: Internal Auto fuel pump? |
Well I have been using the same one since 1997. Its simple to use, simple to see and check. I think it cost me $17.00 A Facett I mean, with 3-5 lbs pressure. You can be as sophisticated as you want. Neither one would hurt. I am sure that one of them is cheaper however. They are still going to call it an ultralight or a toy however. :-)Larry
On Tue, Mar 7, 2017 at 4:37 PM, Nick Cassara <nickc(at)mtaonline.net (nickc(at)mtaonline.net)> wrote:
| Quote: | --> Kolb-List message posted by: Nick Cassara <nickc(at)mtaonline.net (nickc(at)mtaonline.net)>
Kolbers,
Nick Cassara
PAAQ
Palmer, Alaska
FORUMS -
WIKI -
b Site -
-Matt Dralle, List Admin.
The older I get, the less tolerant I am of those who are intolerant of others.
west1m
Joined: 19 Apr 2014 Posts: 155 Location: Hastings, MN
Posted: Tue Mar 07, 2017 6:01 pm Post subject: Re: Internal Auto fuel pump? |
I believe most in tank automotive pumps are made with fuel injection in mind. putting out high pressures. Even the old throttle bodies ran 15psi newer multiport run up around 40 psi. I don't think this what you want wit a Rotax
_________________ West1m
Hastings, MN |
