clivesutton
Posted: Sat Mar 11, 2017 9:11 am Post subject: MOD sheets? |
Hi, on the final inspection prep run now and checking off each required MOD with the LAA list against what's on the a/c.
But can't find anything on the EC or Europa websites for the following MOD's - Does anyone have/can send me, copies please?
MOD 15 - FWD Lift Pin Fuselage Strengthening
MOD 16 - Shock Absorber Block Shape
MOD 17 - Rudder Pedal guides
MOD46 - Pitch Torque Tube End Cap
clive.maf(at)googlemail.com
pjeffers(at)talktalk.net Guest
Posted: Sun Mar 12, 2017 1:33 am Post subject: MOD sheets? |
Hi Clive,
If you really want them I could email them to you but their applicability to
your a/c is largely dependent upon whether your kit is classic or XS.
I have left a voice message on your mobile with my phone number if you wish
to talk about it.
Pete Jeffers Europa Club LAA Inspector
neveyre(at)aol.com Guest
Posted: Sun Mar 12, 2017 9:25 am Post subject: MOD sheets? |
Hi Clive,
Hope this goes through, my posts have gone MIA before
Mod 15, the ''top hat'' lay up of 3 Bids over 3'' x 1/4'' blue foam, vertical from door sill to thigh support, centred over lift socket.
Mod 16, original block was a rectangular ''brick'', needs a V cutting out of upper and lower faces [ bear to do, get a new one from Europa].
Mod 17, without my notes can't be sure, might be the 5/8'' tubes [CS31] Reduxed into the pedal pivot tubes ?
Mod 46 Pitch torque tube originally had the solid bearings [ as per aileron control system] replaced with a spherical [ self aligning] bearing and beefier cap.
All these were very early on.
Tip, when you submit the paperwork to LaaLaaLand, list EVERY MOD, and mark as N/A as [ for instance] a Trigear application will be returned if the mono wheel block, Mod 16 hasn't been done..... DOH !
Cheers,
Nev
clivesutton
Posted: Mon Mar 13, 2017 11:25 am Post subject: Re: MOD sheets? |
Hi Nev, many thanks for your reply - i've emailed you a reply direct/off list
Clive
