philperry9
Posted: Sun Mar 26, 2017 6:08 pm Post subject: W&B Configuration |
I'm about to zero in on having this thing on the scales in the next couple of days.
Reading the FAA circular, they mention that the sumo should be full. (12 Qts in my case). Vans Section 5 is a little more vague.
I have a hard time seeing myself ever filling the sump with 12, just to watch it get pumped right overboard and settle in around 8-9 on the stick.
What have you all done with regards to sump capacity when running your W&B? I'm tempted to run it with full lines and 8 on the stick.
But I'm just curious to know what most of you have done with yours?
rv10flyer(at)live.com Guest
Posted: Sun Mar 26, 2017 6:26 pm Post subject: W&B Configuration |
I thought through how I would fly the plane (aka 8qts) and did the W&B based on that assumption.
Kellym
Joined: 10 Jan 2006 Posts: 1705 Location: Sun Lakes AZ
Posted: Sun Mar 26, 2017 6:33 pm Post subject: W&B Configuration |
Do it on a measured 8 qts. The quantity to full is known. You likely
will run it between 6 and 8 qts, depending on whether you have an
air/oil separator or not.
You can then prepare a separate W&B with full sump.
I also recommend you weigh it with fuel tanks dry, because you won't
know what the exact full quantity is, much less its weight that depends
on temperature.
KCHD |
Dave Saylor
Posted: Sun Mar 26, 2017 7:27 pm Post subject: W&B Configuration |
I do W&Bs in the most common empty configuration. So I'd weigh it with 8 or 9 qts.
If you want the data for "just in case", weigh it with 8 and then add 2 quarts. That should be enough to see the weight on a decent scale. Record all your weights again and you'll have the data to extract the exact arm of the oil. It's easy on a spreadsheet.
Same goes for pilot, pax, and baggage. Plop down in the seat while it's still on the scales and you get the most accurate arm for your own self. Put 50# in the center of the baggage compartment, and you can get that arm too.
Another thing to consider is to make the datum an easy-to-find spot, like the wing leading edge or the instrument panel or the front of the door. Then when you want to actually measure something important some day, you don't have to mess with some imaginary point out in front of the plane.
--Dave
On Sun, Mar 26, 2017 at 7:06 PM, Phillip Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)> wrote:
Quote: | --> RV10-List message posted by: Phillip Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)>
_________________ --Dave
KWVI |
Lew Gallagher
Posted: Sun Mar 26, 2017 8:05 pm Post subject: W&B Configuration |
Hey guys,
Just curious here. Did I understand correctly that heating fuel changes the weight ... ?? If so, could someone explain why that would be?
Thanks, – Lew
_________________ non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed ! |
jdriggs49(at)MSN.COM Guest
Posted: Sun Mar 26, 2017 8:25 pm Post subject: W&B Configuration |
When you add heat for all practical purposes it adds mass to the object (liquid fuel).
There is a formula that shows this but since my iPad doesn't do "powers" I won't repeat it here. In actuality the added mass is so small as to be of virtually no easily measurable consequence. Heating causes an easily discerned expansion however.
On Mar 26, 2017, at 11:11 PM, "lewgall(at)charter.net (lewgall(at)charter.net)" <lewgall(at)charter.net (lewgall(at)charter.net)> wrote:
Quote: | Hey guys,
Just curious here.� Did I understand correctly that heating fuel changes the weight ... ??� If so, could someone explain why that would be?
Thanks, – Lew
Bob Turner
Posted: Sun Mar 26, 2017 8:34 pm Post subject: Re: W&B Configuration |
Lew Gallagher wrote: | Hey guys,
Thanks, – Lew |
Nearly all materials (water being different) expand when heated. So one gallon of gas at some temperature might weigh exactly 6 pounds. Heat it up, it expands and overflows the container. There is now less (by weight, or number of molecules) gas in the one gallon container. In real life the aluminum fuel tank will also expand, but it's an order of magnitude less than the expansion of the gas. This is one reason jets (that carry huge amounts of gas) usually keep track of the actual weight.
Strictly speaking the statement should be "Heating decreases the density (mass per volume)".
_________________ Bob Turner
RV-10 QB |
Lew Gallagher
Posted: Mon Mar 27, 2017 4:15 am Post subject: W&B Configuration |
Volume, obviously yes. Weight? Sounds like "Trump science" to me
Keep trying, not sure I believe it yet. Fuel consumption or
expansion/contraction changing COG; changing volume with overflow; density,
I can understand. Maybe that's the deal -- does the expansion with heat
shift the weight, not change the weight? As I said, it doesn't really
matter, just curious.
Later, - Lew
Bob Turner
RV-10 QB
Lew Gallagher
Posted: Mon Mar 27, 2017 4:28 am Post subject: W&B Configuration |
Then there's this: "Water expands about four percent when heated from room
temperature to its boiling point". Hence more issue of rising ocean levels
from global warming of ocean temperature than from melting ice caps.
Never mind, I'm just giddy from South Carolina making it into the Final Four
.. who would have thunk that!!
Do NOT archive.
Later, - Lew
"Nearly all materials (water being different) expand when heated. So one
amounts of gas) usually keep track of the actual weight."
Tim Olson
Posted: Mon Mar 27, 2017 4:54 am Post subject: W&B Configuration |
Don't worry Lew, it's just that many people are better pilots that they are scientists. It is true that the fuel will expand when it is warm. But considering there will be the same number of molecules, they will not weigh differently when they are warm. Yes, the fuel tanks will overflow if they are all the way full to the top, so warm fuel would weigh less in that situation… If it overflowed some of the fuel. But, if you have your fuel tanks filled to 2 inches from the top, on a cold day, and then you take your plane out on a warm day, and the fuel is up to the top, it will not weigh less. It may in fact weigh a minuscule amount more, due to additional dissolved gases. The comment about Jets calculating fuel in pounds is accurate, but that would not simply be because fuel weighs less when it is warm. It would have more to do with that it has less volume when it is warm , for the same given amount of fuel in molecules. So you are not going crazy.
Either way, the warm fuel versus cold fuel is a small enough number has to be pretty much insignificant when calculating your weight and balance. Sure, it may weigh a few pounds more if you feel to the exact same spot on a cold day as on a warm day, but I don't think a weight and balance needs to be calculated to that Precision.
Quote: | On Mar 27, 2017, at 7:14 AM, <lewgall(at)charter.net> <lewgall(at)charter.net> wrote:
Volume, obviously yes. Weight? Sounds like "Trump science" to me Keep trying, not sure I believe it yet. Fuel consumption or expansion/contraction changing COG; changing volume with overflow; density, I can understand. Maybe that's the deal -- does the expansion with heat shift the weight, not change the weight? As I said, it doesn't really matter, just curious.
Later, - Lew
Bob Turner
RV-10 QB
Kellym
Posted: Mon Mar 27, 2017 6:10 am Post subject: W&B Configuration |
The weight per gallon of avgas varies approx. 0.1% per degree C.
So at 15C it is 6.01 lbs per gal. At -40 it is 6.41 lbs/gal, and at 35C
it is around 5.88 lb/gal. A swing of .53 lbs/gal. That would be
somewhere in the 32 lb range for full tanks. Yes, it is mostly very
close to the C.G. I wouldn't call it insignificant. Yes, the difference
between 10 and 30 C is around a 2% change, not big. Then you have
difference between individual tanks that may be a gallon or two, for
another 12 lb difference.
However, why worry about it when it is easy to weigh the plane with
tanks empty?
I don't advocate calculating weight to a couple decimals, nor c.g. by
more than about 1 decimal, but you should be aware that if you are
fueling in Phoenix in the summer, that 120 lbs of baggage will affect
c.g. more than it will at International Falls in Jan.
On 3/27/2017 5:53 AM, Tim Olson wrote:
Quote: |
C.G.
KCHD |
Tim Olson
Posted: Mon Mar 27, 2017 6:52 am Post subject: W&B Configuration |
As long as you understand that nearly the entire reason that
the fuel has a different "weight" per gallon is that the
actual QUANTITY of fuel molecules in that gallon is less
as it gets warmer, then you're right on. It's a VOLUME
issue, not a weight issue. If you took hot fuel
of a given weight, and cold fuel of a given weight, and
brought them to the same temperature, they would still
weigh the same but have different VOLUMES.
And, I will say that I do consider it to be pretty irrelevant
regarding the weight of fuel, despite the 32lbs of
difference. The reason I say it's irrelevant is because
I know of no person who flies small planes like RV's, who
would calculate their W&B for a given day of flying and
actually compensate for the weight of fuel THAT DAY
based on temperature.
But you're right, just weigh it with the tanks empty, or
if you wish, after adding some fuel and draining everything
but the unusable fuel. In the RV-10/14 the unusable fuel
is also such a small quantity that it really isn't a significant
number for practical purposes. I have flown my tanks to
dry in testing and there is about 1 cup, 2 max, left
in the tank when flown to empty.
So my personal summary is: The weight difference of fuel
is not significant in PRACTICAL terms for anything,
AFTER you have done an accurate airplane weighing. You're
not likely to ever need to consider that added or
decreased weight due to temperature when planning any
flight. And, for practical purposes, in the RV-10/14
models, useable fuel = total fuel, so you don't need to
mark your tanks with a label like "60 Gallons, 59 usable"
or anything like that.
I personally have never, other than during fuel tank
capacity testing, ever flown with less than 5 gallons in
a tank. I think the risk of fuel unporting during
turns in the pattern would be too high if you get much
lower than that.
And, I think weighing with tanks empty is the way to go.
tanks empty?
> C.G.
> Tim
Posted: Mon Mar 27, 2017 7:23 am Post subject: W&B Configuration |
This whole discussion cracks me up. The weighing issue is that you have to do it with empty tanks or full tanks. That's the point made that started the expansion of fuel when heated discussion. If you use full tanks, the plane is lighter if the fuel is warm because it's bigger. If you fill it up with cold fuel and it warms up, the expansion will send fuel out the vents onto the ground, making the plane lighter. At half tanks it makes no difference in weight, but you can't weigh at half tanks because you don't know exactly how much fuel you have to calculate it back out for an accurate empty weight.
The actual best way to get empty weight is to disconnect the fuel line at the engine and pump it out, leaving the unusable fuel in the tanks.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
C: 352-427-0285
F: 815-377-3694
Quote: | On Mar 27, 2017, at 8:14 AM, <lewgall(at)charter.net> <lewgall(at)charter.net> wrote:
Later, - Lew
Bob Turner
RV-10 QB
flyboy(at)gmail.com Guest
Posted: Mon Mar 27, 2017 7:26 am Post subject: W&B Configuration |
On Mon, Mar 27, 2017 at 8:43 AM, Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote:
Quote: | --> RV10-List message posted by: Tim Olson <Tim(at)MyRV10.com>
weigh the same but have different VOLUMES. |
Uhm, no. If you take a pound of cold fuel and pound of hot fuel, they're going to have the same volume *and* weight once you equalize the temperature. This is one of the many reasons we fuel airliners by weight.
rv10pro(at)gmail.com Guest
Posted: Mon Mar 27, 2017 7:31 am Post subject: W&B Configuration |
On the long cross country flights from the West Coast to AirVenture I would swear the bugs get bigger and their weight becomes a factor as we approach Wisconsin.
Will need to tweak my W&B formula.
On Mon, Mar 27, 2017 at 7:43 AM, Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote:
lower than that.
Quote: | --> RV10-List message posted by: Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
tanks empty?
C.G.
rene(at)felker.com Guest
Posted: Mon Mar 27, 2017 7:37 am Post subject: W&B Configuration |
I did mine, full lines and 9 on the stick. I am changing my starter and will
be redoing it in May. I am going to 8 this time. I almost always run
within a Quart of that. Never over 9 and as low as 6 is what I have seen in
my 700 hours.
Rene'
801-721-6080
Posted: Mon Mar 27, 2017 7:49 am Post subject: W&B Configuration |
Great idea.
Do not archive.
Rene'
801-721-6080
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Cox
Sent: Monday, March 27, 2017 9:31 AM
Subject: Re: Re: W&B Configuration
On Mon, Mar 27, 2017 at 7:43 AM, Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote: Quote: |
--> RV10-List message posted by: Tim Olson <Tim(at)MyRV10.com (Tim(at)MyRV10.com)>
lower than that.
On 03/27/2017 09:08 AM, Kelly McMullen wrote: Quote: |
tanks empty?
On 3/27/2017 5:53 AM, Tim Olson wrote: Quote: |
C.G.
Tim |
Tim Olson
Posted: Mon Mar 27, 2017 7:50 am Post subject: W&B Configuration |
Hey Berck,
I, like Jesse, am getting a chuckle out of this whole discussion.
I read what you said here, and I think we're basically saying
the same thing. Of course, a pound of fuel hot and a pound
of fuel cold will have the same volume and weight, when
temperature equalizes. I think that is what I was trying
to say, but I just didn't do it eloquently enough.
The weight of the fuel is due to the molecular structure
of the fuel itself having that weight per fuel molecule.
It just happens to be that if you heat things up, the
molecules become further apart and less dense, so the
volume changes. But, a the number of molecules and
weight doesn't change.
Now, if you really want to get a pressure/volume/density
problem that confuses people, try explaining why moist
air is LIGHTER than dry air. Everyone always says stuff
like "the air was so heavy and wet today". The funny
thing is, moist air weighs less than dry air.
That's why the dangerous factors in flying are
"Hot, High, and Humid".... the air is less dense.
If moist air was heavier than dry air, we'd be in
a constant state of ground fog, and clouds wouldn't
be up high in the sky.
(I think I just caused worse thread creep than original.)
Bob Turner
Posted: Mon Mar 27, 2017 9:16 am Post subject: Re: more drift |
Tim Olson wrote: | Hey Berck,
(I think I just caused worse thread creep than origine] |
More thread creep: Moist air doesn't rise because it's moist. In the lower atmosphere there's very good mixing. If that weren't true all the oxygen would be down low, and at higher altitudes it would be all nitrogen. What changes is the amount of water in the vapor state depends on temperature. As the air cools as it rises, you reach the dew point - where no more water can evaporate, so you start having liquid drops.
I thought an early post was referring to Einstein's theory of special relativity: E=mc2(squared). Strictly speaking a sealed container of anything should weigh more as energy (heat) is added. But the speed of light squared is such a big number that you can't measure it under most circumstances.
RV-10 QB |
Tim Olson
Posted: Mon Mar 27, 2017 10:14 am Post subject: W&B Configuration |
Thread creep again....water...
It's amazing when you think of the design of things as simple as
water, in our world.
Think of ice...since water hits its greatest density at above
freezing, we can drive on lakes and go ice fishing.
If water followed other molecules pattern, the ice would
form and sink to the bottom of a cold lake, and eventually the
entire lake would turn into a giant ice block.
There are so many things that were designed just perfectly,
that they amaze me all the time.
On 03/27/2017 12:16 PM, Bob Turner wrote:
Quote: |
Tim Olson wrote:
> Hey Berck,
> Tim
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=467694#467694
