bsmith3163(at)aol.com Guest
Posted: Tue Jul 11, 2006 5:44 am Post subject: Rotax 532 a Boat Anchor? |
Help, I am looking at bying a Kitfox 1 and it comes with a never used Rotax 532. I just spent some time on the phone with an authorized Rotax dealer and he said that the 532 was basically a boat anchor. They do not even have a parts list for it anymore. We talked about some of the alternatives but I wanted to find out what other people were using. Is anyone flying a Kitfox 1? What engine combination are you using? What is the TBO? What is the cost for a rebuild? I have come to the conclusion that the kit I am looking at is a good deal but not so much if I have to replace the engine with brand new. Any help would be appreciated.
algate(at)attglobal.net Guest
Posted: Tue Jul 11, 2006 6:38 am Post subject: Rotax 532 a Boat Anchor? |
Can’t help you much with the 532 but I have a Kitfox Lite2 (Model 4) with 582 and all mods at Cad$28,000
Gary Algate
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Brian Smith
Sent: Tuesday, July 11, 2006 9:42 AM
Subject: Rotax 532 a Boat Anchor?
Richard Rabbers
Joined: 09 Jan 2006 Posts: 114 Location: Benton Harbor, MI - USA
Posted: Tue Jul 11, 2006 6:42 am Post subject: Re: Rotax 532 a Boat Anchor? |
Brian,
I have a model 1 - though I can only offer a distant view.. since I've not yet flown it. The previous owner mounted floats and in the process installed a Rotax 618. The 618 at 73-74 hp is more power than you would need and seems not to be all that common an engine. I'm sure others will offer more specific comments or suggestions.
_________________ Richard in SW Michigan
Model 1 / 618 - full-lotus floats (restoration) |
RichWill
Joined: 24 Feb 2006 Posts: 24 Location: Southern Maine
Posted: Tue Jul 11, 2006 7:03 am Post subject: Re: Rotax 532 a Boat Anchor? |
Never had one myself, but know of many who did and failed... Been around awhile and they did have problems with the rotary values, something to do with caburation...
I would NOT use it, or offered a price that excludes the engine.. Put in a 582 or go the extra mile and get the 912... you'll be much happier and safer!!
Rich
N50PC
Posted: Tue Jul 11, 2006 7:16 am Post subject: Rotax 532 a Boat Anchor? |
Thanks for the advice Rich. By "rotary values" are you talking about engine
rpm values? I did read something about not operating below 2000 rpm except
for start and shutdown. That seems kind of strange to me. Brian Smith.
mike Guest
Posted: Tue Jul 11, 2006 8:36 am Post subject: Re: Rotax 532 a Boat Anchor? |
I guess you can always do like a spokane local named jerry turner and trailer your new fox around to flyins and pull it out and taxi it like you just flew in, of course his isn't a kitfox it's a hyper light, but I think you get the idea.
bmwebb(at)cox.net Guest
Posted: Tue Jul 11, 2006 2:04 pm Post subject: Rotax 532 a Boat Anchor? |
A 912 will not fit. The fuselage tubing up until the 3 (possibly IV) is too
small to support the weight. The Geo, with 65hp and 150#, is at the upper
limit of what I can install on my M2.
I would suggest you go with the Geo, but if you NEED a Rotax, go with the
582. The grey-heads are fine if you can find one, and be prepared to do ALL
that is required to maintain it ($$$). If you aren't, then your choices are
that much more limited on the 1.
Bradley
Posted: Wed Jul 12, 2006 5:36 am Post subject: Rotax 532 a Boat Anchor? |
I believe that the blue head 582 has a number of desirable upgrades over the
grey head ie) thermostat by-pass etc. Probably worth looking into.
Just for the record the 58 has an amazing power to weight ration and
excellent durability due to de-rated power and oversized crank and bearings.
Each engine variation has its own benefits and drawbacks and I don't think
there is any one combination that meets all of our requirements. For some
people TBO and cost is extremely important while for others performance and
durability are critical. I think it's up to each of us to decide what is
best for our personal mission.
I have flown Kitfoxes behind 912's, Jabiru's and 582's each one has its
pros and its cons but they are great and reliable engines.
For what it's worth!
Gary Algate
Posted: Wed Jul 12, 2006 1:34 pm Post subject: Rotax 532 a Boat Anchor? |
What desirable upgrades? A water bypass? Oooooh.
The grey head is as good as the blue. Trading a grey for a blue is pure
folly (how's that comin' from a Southern boy!). The Bluehead just isn't that
much nicer. Of course, you should go buy a Bluehead if you're shopping new.
Especially since that's all you can get!
It does have a good P/Wt ratio, but it DOES NOT have excellent reliability,
in any sense of the phrase. Sorry, but I have to raise the BS flag here. Can
you name an engine, used for just about anything, that is LESS reliable than
the Rotax UL two-strokes? I can't think of any; production ones, anyway.
That's my .02,
Bradley
dave(at)cfisher.com Guest
Posted: Wed Jul 12, 2006 2:12 pm Post subject: Rotax 532 a Boat Anchor? |
Bradley,
I would not let of too much steam till you get some testing done on your
Geo.
Some are ok, some are not.
time will tell.
The Majority of the rotax 582 troubles have stemmed from the operators and
not just the engine.
I think most will agree there.
Dave
Now if you want some facts from a Geo armchair critic with handson
experience, I will give it to you since you like to be critical.
Dave,
I had a look at the photo and this fellow is heading for trouble. He has
a turbo 3 so the power will be adequate but there are several other
problems. The flywheel is very light so there will be a lot of shaking.
There is no damper as there is in the Russian gearbox, so the only damping
will be by the belt, and this will vary with tension.
The exhaust has a couple of problems. First off it is a waste of effort
and weight to use any sort of muffler. The turbo will quiet the engine down
quite well by itself. There appears to have been a bit of interference
between the cowl and the exhaust elbow, so the builder shaved the exhaust
and welded in a plate. It looks as if the shaving might have caused a
restriction. This could restrict the outflow of exhaust, and if this is the
case there will be a loss of power. The other exhaust problem is that there
appears to be no mount for the muffler. If the engine shakes as much as I
think it will, the muffler will be acting like a pendulum. It will not be
long before the pipe parts from the turbo flange. This will improve the
power output but it could also cause a fire.
The prop extension looks to be very long, and there appears to be only a
very small radius where it meets its mounting flange. This is a recipe for
crack initiation and propagation. If I were in the insurance business I
would not be selling any life insurance to this fellow. ....
Michel
On Jul 12, 2006, at 11:32 PM, Bradley M Webb wrote:
| Quote: | Trading a grey for a blue is pure
I say, I am rather shocked, old chap, what?
Seriously, the grey top 582 from before 1992 (I think) had a weaker
crankshaft. Mind you, mine did very well up to its 300 hours, but if I
was to buy a second hand grey top, I'd try to get one from after 1992
(or a certain engine number, if anyone remembers which one it is).
Cheers,
Michel
Posted: Wed Jul 12, 2006 2:28 pm Post subject: Rotax 532 a Boat Anchor? |
You certainly have a way with words.
I think if you look at the cause of failure of two stroke engines you will
find that 99% of the cases result from incorrect care, maintenance and/or
operation.
When you say the grey head is as good as the blue what logic are you using?
The thermostat by-pass on the blue head is in fact an excellent safety
factor and another step in the logical improvement and development of the
engine. I really don't understand why you would smear a 2 stroke 582 on one
hand for unreliability and on the other, berate a logical improvement like
the bypass system which could save a plane in the event of thermostat
failure. I believe that the Blue head also has a number of other features
over the Grey head and by saying that I don't mean that the grey head is not
an excellent engine - it's just that like our aircrafts the engine
manufacturers are learning and making subtle changes to improve the safety
and performance of their products. I certainly wasn't suggesting that
everybody with a grey head should immediately change to the blue head.
Bob Robertson (Light Engine Services) would have more info on this subject.
As I said in my posting all of the engine options have their place in the
sport and I think it is important that we respect each others choices. For
your interest there are a couple of Challengers flying with the Geo Metro
and I believe their power to weight ration is excellent.
Gary Algate
Aerobatics(at)aol.com Guest
Posted: Wed Jul 12, 2006 3:29 pm Post subject: Rotax 532 a Boat Anchor? |
In a message dated 7/12/2006 4:36:50 P.M. Central Daylight Time, bmwebb(at)cox.net writes:
| Quote: | What desirable upgrades? A water bypass? Oooooh.
actually there are many upgrades on the 582 BH. I know, I have had both the 582 and 532. I spent a lot of money on my new 582BH with the E Box and feel it was well worth the money. I purchased from Lockwood and they have provided GREAT support.
I have around 550 hours behind various Rotax 2 strokes with excellent results. I also have a Piper warrior 2 that I love to fly and is kept very "cherry" but we just spent 27,000 that past 12 months if you include 2 annuals and a new engine. The old engine made it to 1,600 hours. Do the math.... I wont!
What ever we do, especially when flying,driving, etc, is part of risk management. I have no interest in taking unnecessary risks. Knowing we are flying a 2 stroke VS a certified Lycoming, I fly differently. Like I never fly my KF at night, over solid cloud and so on....
That's what is supposed to be the great value of the Internet. But, we all need to filter the strong opinions and try to sort out the facts. Not an easy thing to do.
We all know there are a lot of 582s around. But, when shopping for an engine, I called around, went to 3 OSH and a Sun and Fun, spoke pilots and vendors, I then made my decision. Since then it has been a very smooth and reliable engine. So for me, that's my reality
All parts are available and reasonable, considering its an airplane. In fact I am flying mine to Kankakee Ill ( Jim Leon) for scheduled service. Decarb, check seals etc. He has a great service center with an even better reputation......
There are a lot of good engines.....and I certainly include the 582.
Dave P KF 2
Malcolmbru(at)AOL.COM Guest
Posted: Wed Jul 12, 2006 6:38 pm Post subject: Rotax 532 a Boat Anchor? |
Why would anyone put a $800 motor on a $10,000 air frame? I wouldn't pay very much for a kit that was so old it had an unused 532. malcolm
noelloveys(at)yahoo.ca Guest
Posted: Wed Jul 12, 2006 7:24 pm Post subject: Rotax 532 a Boat Anchor? |
As far as I know many earlier grey heads had the cranks replaced with the
spec 99 cranks. Before flying my spec 90, vintage 91 engine I had it
overhauled by a reputable Rotax repair centre. They replaced the crank, the
expensive piece, and worked on the rotary valves. They also upgraded
something to do with harmonic balances.
The long and the short of it is that the grey head engines can be brought up
to spec 99.
Referring to reliability I still have some misgivings about the reliability
of the 2 stroke engine. It's just that you are getting a mammoth energy
from a dwarf package. In the four stroke C172 that I trained on I would
periodically check the engine gauges..... In the 2 stroke it is a bit more
than periodically I've only got about 25 hr on the engine but so far, knock
on wood, no probs.
Noel
[quote] --
Posted: Wed Jul 12, 2006 7:30 pm Post subject: Rotax 532 a Boat Anchor? |
The only thing I can disagree here is with the statement that there is more
damping with a loose belt. From what I have learned on other groups there
is zero, nil, zilch damping in belts. Having a belt too loose is an
invitation to a broken belt party. I believe many manufacturers of belt
drives also use a TV damper in their designs.
Noel
[quote] --
Posted: Wed Jul 12, 2006 7:52 pm Post subject: Rotax 532 a Boat Anchor? |
Malcolm:
Your point should be well taken. Any airframe that old should be gone over with a fine tooth comb before flying. The engine at the very least should be completely overhauled..... in this case replaced.
Noel [quote]
Posted: Wed Jul 12, 2006 8:29 pm Post subject: Rotax 532 a Boat Anchor? |
The guy that wrote that about the Turbo 'fox is a blithering idiot. The belt
is, in fact, Kevlar, and has no dampening qualities whatsoever. If he knew
the first thing about the issue, he would know that this is actually the
desired state for a belt drive. He would also know that Raven has a very
elaborate, yet simple, dampening system in the upper drive hub that all but
eliminates the natural harmonics of the Suzy 3. Jeron at Raven has spent
over ten years developing this system, and it's a complete package that
deals with all aspects of the design. The "Russian system" uses a BMW donut,
and it does work, but not as well. Raven will idle at 1100 engine rpm, and
the "Russian" won't go below 1500 at all, and 1800 is the norm due to the
shaking. It really doesn't address the issue of the harmonics at all; it
just band-aids the problem.
His prop flange radius issue is absurd. There have been NO breaks, ever.
NONE. ZILCH. NADA. Call Raven and ask.
BTW, the 582 mod 99 has 55ft/lb of torque at 6000rpm. A dead-stock G10 with
a T3 turbo at 5 psi is 107ft/lbs at 5500 rpm. Yeah, it's got enough power.
Go talk to anyone that drives a Metro/Swift, and see if it has been a
reliable car or not.
Bradley
wayne(at)engravers.net Guest
Posted: Thu Jul 13, 2006 3:03 am Post subject: Rotax 532 a Boat Anchor? |
I'm a 582 operator since 1998, The Rotax gray head was a poor engine to
start with and it's short 300 hour BOH (between Over Hauls) is very short
compared to other engines. I've had three engine outs while flying, one was
an oil seal that let go and cost me over $2000 to fix. All had a successful
landing, but my heart was pumping fast enough that it could have turned the
prop at speed if there was a way to connect the two. My friend has
snowmobile engines that have fuel injection, automatic altitude compisation,
can go 110 MPH over the lakes and cost half of what our engines cost plus
they don't have a 300 TBO time limit. Rotax FOR YEARS knew of the oil seal
problem without doing anything about it, there changes are slower the
Microsoft and they are WAY behind the curve on any technology changes.
Wayne Cahoon
Michel
Posted: Thu Jul 13, 2006 4:43 am Post subject: Rotax 532 a Boat Anchor? |
On Jul 13, 2006, at 4:02 AM, Wayne Cahoon wrote:
| Quote: | Rotax FOR YEARS knew of the oil seal problem without doing anything
about it
Wayne, I know nothing about the Rotax engine and even if I flew 100
hours behind a 582, I didn't even know they had an oil seal problem.
But, like most people, I work for an average company. We have
marketing, R&D, production and customer support. Those guys fight each
other every day: Marketing sells products we don't have, R&D says we
can't produce it, production says, no way for that date, and customer
support ... blame it all on the customers.
I expect it is about the same with Rotax. Why would they refuse to fix
a problem? I miss the company policy point, here.
Today, we can't blame it on the Jews or the Blacks. So, we blame it on
politicians, lawyers, ... and even engine manufacturers. On the Jabiru
list, it is the same thing: no one is pleased with Jabiru customer
support. One has been waiting months for a part, the other one never
got an answer to his email. But there are thousands of Jabiru and Rotax
users who are quite happy. It's unfortunate that we rarely hear from
them.
Cheers,
Michel
