		Albert Gardner
				 Posted: Mon Mar 27, 2017 9:24 pm    Post subject: Unuseable Full |
				I have 8 oz in one tank and 9 in the other of unusable full when tanks were
 drained while sitting on the ramp. Aircraft was in level cruise flight and
 tank was used in flight until fuel pressure started to drop. Switched tanks,
 landed and drained tank. Very small amount of unusable fuel  but makes me
 aware of the need to frequently check tanks for water/other contamination.
 Anyone else have numbers?
 Albert Gardner
 RV-10 N991RV
 Yuma, AZ
  _________________ RV-9A N872RV
RV-10 N991RV |
		fehdxlbb(at)gmail.com Guest
				 Posted: Mon Mar 27, 2017 9:44 pm    Post subject: Unuseable Full |
				How much is unusable in a takeoff/go-around attitude?  Or a cross-wind slip to landing?  That's the value we all should really be seeking and using to flight plan.
 Fly safe,
 Jim
  	  | Quote: | 	 		   On Mar 28, 2017, at 00:23, Albert <ibspud(at)roadrunner.com> wrote:
  Albert Gardner
  RV-10 N991RV
  Yuma, AZ
		flying-nut(at)cfl.rr.com Guest
				 Posted: Tue Mar 28, 2017 4:28 am    Post subject: Unuseable Full |
				That might be good info but useless.   If you depart or land with that little fuel then you're obviously suicidal and in need of professional help.
 IMHO of course!!!!
 Linn
 Sent from Samsung tablet cruising on the Oasis Of The Seas.
 From Jim Beyer <fehdxlbb(at)gmail.com>
 Date: 03/28/2017  1:41 AM  (GMT-05:00)
 To rv10-list(at)matronics.com
 Subject Re: RV10-List: Unuseable Full
 --> RV10-List message posted by: Jim Beyer <fehdxlbb(at)gmail.com>
 Fly safe,
 Jim
  --> RV10-List message posted by: "Albert" <ibspud(at)roadrunner.com>
  Albert Gardner
  RV-10 N991RV
  Yuma, AZ
 _-============================================================
 _-=          - The RV10-List Email Forum -
 _-= Use the Matronics List Features Navigator to browse
 _-= the many List utilities such as List Un/Subscription,
 _-= Archive Search & Download, 7-Day Browse, Chat, FAQ,
 _-= Photoshare, and much much more:
 _-=
 _-=   --> http://www.matronics.com/Navigator?RV10-List
 _-=
 _-=               - MATRONICS WEB FORUMS -
 _-= Same great content also available via the Web Forums!
 _-=
 _-=   --> http://forums.matronics.com
 _-=
 _-=              - NEW MATRONICS LIST WIKI -
 _-= Add some info to the Matronics Email List Wiki!
 _-=   --> http://wiki.matronics.com
 _-=             - List Contribution Web Site -
 _-=  Thank you for your generous support!
 _-=                              -Matt Dralle, List Admin.
 _-=   --> http://www.matronics.com/contribution
		partner14
				 Posted: Tue Mar 28, 2017 4:51 am    Post subject: Unuseable Full |
				Hopefully, if you're, for whatever reason, running right down to the last drop, you won't be doing anything wierd, other than landing the airplane.  I purposely ran a tank dry, at very low time, for 2 reasons, one, to find the usable fuel, the other to insure the engine would refire. The results were very comforting;  could barely fill 1/4 of the plastic fuel tester, and the engine fired back up immediately, with no boost pump necessary.Although we tend to flight plan longer legs than most of our RV friends, it's still nowhere near 55 gallons.  Usually use 4 hours, and, if necessary, slightly longer, but only if there is/are other fuel choices closer in case fuel burn is higher and/or speed is much slower.  We are very blessed to be flying a fast and efficient plane, which makes flight planning a whole lot easier.I usually start the flight planning at around 600nm..... looking for the cheapest fuel, at the highest possible airport.  You'll save fuel and time being able to decend and climb out 5,000' instead of 10,000'. Don McDonaldComing up on 1,000 hours and still enjoying every damn minute.In an attempt to share the fun, I now have had over 275 "different" passengers.
  Sent: Tuesday, March 28, 2017 12:52 AM
  Subject: Re: Unuseable Full
 Fly safe,
 Jim
40636 |
		Tim Olson
				 Posted: Tue Mar 28, 2017 5:20 am    Post subject: Unuseable Full |
				I somewhat agree.  I think Jim's general concept is correct...you
 wouldn't want to flight plan with an amount of fuel that is
 expected to be available but may not be under certain conditions.
 But, at the same time, you can't really try to simulate the
 most extreme situations and come up with a reliable number.
 First, let me say that when I did my test, I got maybe a
 pop-can's worth of fuel out after flying them empty.
 That was in level flight.  Also, I just saw someone posted
 on the RV-14 forum that they got between .1 and .2 gallons
 remaining doing the same thing.  A pop can is 12oz, which
 is also .1 gallons.  So, we can basically know that
 there is almost zero unusable fuel in the RV-10/14 design
 of wing tanks.  12oz isn't enough for me to say counts
 for anything. I certainly can't top my tanks off to within
 12oz every time, given uneven pavement and such.
 So in the RV-10, I just consider all fuel to be
 labeled "useable".
 But, the other thing we know about the RV-10 tanks is that
 the fuel port is just a couple inches from the aft portion
 of the tank near the spar, and it's on the flatter area of
 the tank, not on the curved airfoil.  So where Jim
 says in a "takeoff/go-around situation", in the RV-10,
 that is actually not where I would have my worry.
 I think you could actually tap into that last little
 bit of fuel better in climb-out, especially if you
 mis-applied rudder enough to keep the fuel forced against
 the bulkhead.
 My big worry, and the reason I really don't fly it down
 to less than 5 gallons per tank, has a few reasons:
 1) with float error and such, I don't want to count on the
 accuracy that low.
 2) I have fuel low warnings that come on around 6-7
 gallons (each side) if I remember right.  If I go below
 that, I'm going to be hitting mute a lot.
 3) During landing, if you don't keep the rudder pressure
 right, or have a crosswind that you have to correct for,
 you could easily un-port that fuel port even with a couple
 gallons in there.
 4) This is the big one...  In landing configuration, the
 RV-10 tips quite a bit nose down if you are landing
 with full flaps. (I almost always do) and you are far
 more likely to un-port the fuel inlet when it all
 sloshes forward in the tank.
 So I really don't like the idea of trying to bring a plane
 in at low fuel levels.
 In teaching landings, BTW, we all know that there
 are 2 ways to do the crosswind correction.  I've been
 teaching them a bunch lately.  You can crab to landing
 and then kick the rudder in just before you touch down,
 or you can hold the slip correction all the way down final.
 Another instructor I know does not even TEACH the former
 method, and I am not thrilled by this.  I specifically
 teach my students that although the slip to final is
 easier for initial learning, they will absolutely
 want to work to perfect the crab and kick-in the rudder
 method.  It will be really the only way to help
 guard against fuel un-porting in lower fuel situations,
 and there are planes like one I used to own, that
 are placarded "slips with flaps prohibited".  So I
 see this as a very necessary skill for pilots.
 Taking into consideration the above, that's how I
 came to my personal minimum of 10 gallons remaining
 for the RV-10.  In fact, I think my lowest was 10.2,
 and that only happened one time.   If I were even
 to want to stretch my fuel burn lower, the only way
 I would do it is to fly one tank empty, and land
 with 5 gallons in the remaining tank....but take this
 with a grain of salt because that would violate
 the FAR's...the RV-10 in cruise (low-altitude
 such as going to an alternate airport) will generally
 burn more than 10gph (usually 14 or so), and
 that puts you below the 30 minute fuel reserve
 minimums.  I myself would only use that method
 in the most extreme fuel emergency, but it is
 a tool to keep in your back pocket.
 Hopefully by reading the above, if you weren't already
 thinking of fuel minimums for yourself, you can at
 least have some food for thought when you develop
 your own personal fuel minimums.
 On 03/28/2017 07:24 AM, Linn Walters wrote:
  	  | Quote: | 	 		   That might be good info but useless.   If you depart or land with that
  IMHO of course!!!!
  Linn
  Subject Re: Unuseable Full
  Fly safe,
  Jim
  were
  tanks,
 > Albert Gardner
 > RV-10 N991RV
 > Yuma, AZ
		Kellym
				 Posted: Tue Mar 28, 2017 7:21 am    Post subject: Unuseable Full |
				Just a couple points. Most single engine Cessnas have some
 recommendation against slipping with full flaps. However, I don't recall
 any that prohibited it, and certainly not slips for crosswind landing.
 Second, the FAR fuel requirements for VFR and IFR are "planning"
 requirements, not a requirement to land with that much fuel. For VFR it
 is only a "planned" 30 minutes, which I guess would be about 7-8 gal.
 For IFR if no alternate is required, 45 min. If alternate is needed,
 then fuel to that alternate plus 45 min.
 That said, I too am very uncomfortable with less than 5 gal per tank, or
 10 gal all in one tank, and I prefer to plan for 15 gal on board at
 landing. Likewise, if it looks like I am burning more than planned by
 1/2 way distance, I will start evaluating alternates to at least get 15
 gal extra.
 As a controller, I once worked a DC-8-63 that landed without enough fuel
 to even make a go around to a less suitable airport 7 miles away. They
 had an enroute alternate, passed that when destination was still above
 minimums, and then destination and nearby alternates went below
 minimums. Forced them to fly an extra 300 nm to nearest suitable
 airport, which fortunately for them was clear and 80 nm vis.
 I can't imagine the pressure of being committed to a single shot at
 landing a large jet from 300 nm out, knowing that any delay, any miscalc
 and you would crash.
 On 3/28/2017 6:19 AM, Tim Olson wrote:
  	  | Quote: | 	 		   My big worry, and the reason I really don't fly it down
  accuracy that low.
  	  | Quote: | 	 		   guard against fuel un-porting in lower fuel situations,
KCHD |
		Tim Olson
				 Posted: Tue Mar 28, 2017 7:35 am    Post subject: Unuseable Full |
				Yeah, my Sundowner was one of them that was "Slips with flaps
 prohibited".  I was told a week or so ago that the
 flight training cessna locally (M model) was no slips with
 full flaps, but as you said, that may be that it was
 just advice, not a real prohibition.  Still, my main point
 was that I think a pilot should absolutely learn both
 methods and then try to perfect the no-slip landing so
 that they can avoid fuel issues easiest.  The same thing
 with fuel minimums...may as well not go with the letter of the
 law minimums when a prudent amount will be more.  For my
 students who solo, I will tell them they must land with
 10 gallons or 1 hour as an absolute minimum for solo
 requirements.
 The worst I ever personally saw was an airplane that
 landed on a direct flight from the east coast, who
 landed straight in, and as they were taxiing to the ramp,
 the prop quit about 100 yards away and they rolled to the
 pump....bone dry.  That was way too closet.
 On 3/28/2017 10:20 AM, Kelly McMullen wrote:
  gal extra.
		rv10pro(at)gmail.com Guest
				In January 1981,Portland had a DC-8 which circled multiple times during a mechanical issue until both turbines went silent.  11 soles were lost when the pilot made a choice to continue flight.  The landing was on 162nd and Stark in SE PDX.
 The FAA developed Cockpit Resource Management as a result.  Discussions were held of the independent streak of post war fighter pilots in the decision making process..  CRM morphed into Crew Resourse Management which places the responsibility of the newer pilots to reach out and consult every available resource.  As a result the safety record continues to improve.
 John
 On Tue, Mar 28, 2017 at 8:20 AM, Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)> wrote:
  	  | Quote: | 	 		  --> RV10-List message posted by: Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
  Just a couple points. Most single engine Cessnas have some recommendation against slipping with full flaps. However, I don't recall any that prohibited it, and certainly not slips for crosswind landing.
  Second, the FAR fuel requirements for VFR and IFR are "planning" requirements, not a requirement to land with that much fuel. For VFR it is only a "planned" 30 minutes, which I guess would be about 7-8 gal.
  For IFR if no alternate is required, 45 min. If alternate is needed, then fuel to that alternate plus 45 min.
  That said, I too am very uncomfortable with less than 5 gal per tank, or 10 gal all in one tank, and I prefer to plan for 15 gal on board at landing. Likewise, if it looks like I am burning more than planned by 1/2 way distance, I will start evaluating alternates to at least get 15 gal extra.
  As a controller, I once worked a DC-8-63 that landed without enough fuel to even make a go around to a less suitable airport 7 miles away. They had an enroute alternate, passed that when destination was still above minimums, and then destination and nearby alternates went below minimums. Forced them to fly an extra 300 nm to nearest suitable airport, which fortunately for them was clear and 80 nm vis.
  I can't imagine the pressure of being committed to a single shot at landing a large jet from 300 nm out, knowing that any delay, any miscalc and you would crash.
   	  | Quote: | 	 		   --> RV10-List message posted by: Tim Olson <Tim(at)MyRV10.com>
  accuracy that low.
   FORUMS -
  WIKI -
  b Site -
		rene(at)felker.com Guest
				 Posted: Tue Mar 28, 2017 7:56 am    Post subject: Unuseable Full |
				Not to start another discussion....but why not. I thought the no slip with full flips on some aircraft, t-tail in particular, had to do with blanking out the tail.  I know is some Cessna in my past, it had a time limit and I assume that was a fuel issue.
 Rene'
 801-721-6080
		Tim Olson
				 Posted: Tue Mar 28, 2017 8:13 am    Post subject: Unuseable Full |
				Sadly I personally haven't heard the "why" but just see the placards
 or notes in the POH.  I guess they aren't expected to tell us
 the details but only give us the prohibition...   I can only
 assume that in some cases it's aerodynamic and other cases it's
 fuel or systems related.  There are probably far better
 sources than myself who could speak to the why on various
 airplanes.
  Rene'
  801-721-6080
		flyboy(at)gmail.com Guest
				 Posted: Tue Mar 28, 2017 8:25 am    Post subject: Unuseable Full |
				The older 172s (40 degrees of flaps), will sometimes, after prolonged slips with full flaps, unexpectedly and sharply drop the nose because of blocked airflow over the tail.  It's easy to recover, but it's scary.  The newer, 30 degree flapped 172s will not do this (I beleive this s why flaps were limited to 30 degrees), but will do some pretty odd buffeting in prolonged slips with full flaps.  Fuel supply is not a problem as long as you've got some fuel in both tanks and the selector on both.
 On Tue, Mar 28, 2017 at 10:13 AM, Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote:
 [quote]--> RV10-List message posted by: Tim Olson <Tim(at)MyRV10.com>
  airplanes.
  [quote] --> RV10-List message posted by: "Rene" <rene(at)felker.com (rene(at)felker.com)>
  Rene'
  [url=tel:801-721-6080]801-721-6080[/url]
		Kellym
				 Posted: Tue Mar 28, 2017 8:54 am    Post subject: Unuseable Full |
				Fuel supply is a problem with the older Cessnas. I don't recall when or
 if they got rid of the placard which required 1/4 tank for takeoff or go
 around. the pickup was somewhere near the middle of the tank, (fore and
 aft axis) and would unport with nose up attitude used on takeoff climb.
 On 3/28/2017 9:24 AM, Berck E. Nash wrote:
 [quote] The older 172s (40 degrees of flaps), will sometimes, after prolonged
      airplanes.
          <mailto:rene(at)felker.com>>
          Rene'
          801-721-6080 <tel:801-721-6080>
KCHD |
				 Posted: Tue Mar 28, 2017 12:10 pm    Post subject: Unuseable Full |
				The flap change was done for certification .... has something to do with ability to climb with full flaps during a go around.
 Linn
 From "Berck E. Nash" <flyboy(at)gmail.com>
 Date: 03/28/2017  12:24 PM  (GMT-05:00)
  airplanes.
  Rene'
		Bob Turner
				 Posted: Tue Mar 28, 2017 1:38 pm    Post subject: Re: Unuseable Full |
				 	  | flying-nut(at)cfl.rr.com wrote: | 	 		  The flap change was done for certification .... has something to do with ability to climb with full flaps during a go around.�
 Linn
 yes, it was done in conjunction with an increase in gross weight. There's an STC available for older 172s.
  _________________ Bob Turner
RV-10 QB |
		maca2790
				 Posted: Tue Mar 28, 2017 4:51 pm    Post subject: Unuseable Full |
				Well I ran my Right tank empty accidentally in purpose while in the Circuit at Bathurst, NSW Aus. When I checked how much there was left in the tank I got 120 ml out of it. But I also had the engine die on me when doing a big side slip in level flight for an extended time. The tank was indicating 17 ltrs at the time. It certainly got my attention real quick as I was only 700 ft agl at the time. Anyway from that event I made a note to myself to not go below 20 ltrs (5.2 Galls US)  on any tank while in flight.
 Cheers John MacCalum
 RV10 41016
 VH-DUU
  	  | Quote: | 	 		   On 29 Mar 2017, at 8:38 am, Bob Turner <bobturner(at)alum.rpi.edu> wrote:
 > Linn
  Bob Turner
  RV-10 QB
  http://forums.matronics.com/viewtopic.php?p=467767#467767
		cooprv7(at)yahoo.com Guest
				 Posted: Tue Mar 28, 2017 5:19 pm    Post subject: Unuseable Full |
				I too strive to always land with at least 10 gallons, roughly an hour of cruise burn. However, if I'm going to be even close I burn most of the left tank out, not enough to go quiet, so the majority is in the right tank to minimize any chance of the fuel pickup becoming uncovered with fuel during approach and landing.  Just a technique.
 Marcus
  	  | Quote: | 	 		   On Mar 28, 2017, at 8:49 PM, John MacCallum <john.maccallum(at)bigpond.com> wrote:
  RV10 41016
  VH-DUU
 >> Linn
 > Bob Turner
 > RV-10 QB
