Vgs
byoungplumbing(at)gmail.c
PostPosted: Mon Apr 03, 2017 5:52 pm    Post subject: Vgs Reply with quote
For 900 hours I figured I had a good handling plane... I had an expensive lesson at 118 hours,   I was too close to the ground to recover...  afterwards  I modified the way I flew the plane..
For years I refused the thought of vgs.   After putting them on,,, wish I had done it long long ago.  I would say don't knock it till you try it.
I truly believe that if I had had vgs on the horizontals,  my expensive lesson would have been a non event.
Boyd
PostPosted: Mon Apr 03, 2017 6:05 pm    Post subject: Vgs Reply with quote
Should have thought to add,,,   if you try vgs and don't like them,  I promise to listen and try to learn.   At that point let's compare notes.
If you reject vgs on principle,,, you are now where I was a few months ago.
My position is clear and have backed it up with numbers.  If you are apposed, let me see your numbers., Angles, speeds,responsiveness, etc.
Boyd
PostPosted: Wed Apr 05, 2017 7:15 am    Post subject: Vgs Reply with quote
Clip"""And on the subject of VG s on stab, aren't they usually placed just ahead of the
hinge line where the air is going to break as it goes over the elevator not
up near the leading edge???"""end clip
The instructions from John Gilpen say to install the vgs at 4 inches forward of the elevator hinge.  If I had more vg sticky pads,  I may have re tested by removed the vgs, and  reinstalling them further forward.  Then either move them back to the 4 inch location or leave them in the forward position depending on results.
My thinking of why to put them further forward was a combination of a couple ideas.  1. In a further forward position, there would be more    'time / distance' for the vortex to develop.   2. Similar concept but a different way to look at it.  On the wing we know that the vgs maintain better aileron control.  The aileron is 3 1/2 feet back from the vgs.  The question in my mind, if the vortexes are adding benefit 3 1/2 plus feet back,  why limit it to 4 inches.
There is a good chance someone has tested in this manner and that is why 4 inches is the recommendation.  If any of you know, please pass on the information.
Boyd Young
PostPosted: Thu Apr 06, 2017 9:55 am    Post subject: Vgs Reply with quote
Clip  " Yes, I miss ole Buford too.
>"  End clip
As interesting as the original conversation about vgs got way back when,,,,   Buford kept a fence of humour about it all....
He posted to the list a photo of him wearing a helmet,  vgs taped on it all the way around,  vgs on the bottom of the wing,  with a big stogie protruding from a giant grin.
O don't recall the caption,  but left me with the impression,,,  if a few vgs on top are good,   then putting them everywhere is better.
I also miss Buford.
Boyd Young
Do not archive.
russk50(at)gmail.com
PostPosted: Thu Apr 06, 2017 4:22 pm    Post subject: Vgs Reply with quote
Boyd - has Beauford died? I dint hear about it. If so, why’d he do that??
On Apr 6, 2017, at 1:54 PM, B Young <byoungplumbing(at)gmail.com (byoungplumbing(at)gmail.com)> wrote:
Clip " Yes, I miss ole Buford too. >" End clip
I also miss Buford.
Boyd Young
Do not archive.
PostPosted: Thu Apr 06, 2017 5:41 pm    Post subject: Vgs Reply with quote
I don't have any knowledge of his breathing status / health or lack thereof.    The vgs on the helmet and bottom of the wing was 100 % for laughs and to lighten up the mood on the list.
Boyd Young
clip
End vlip
PostPosted: Thu Apr 06, 2017 5:57 pm    Post subject: Vgs Reply with quote
I realize that; thought it was mildly hilarious!
On Apr 6, 2017, at 9:41 PM, B Young <byoungplumbing(at)gmail.com (byoungplumbing(at)gmail.com)> wrote:
Boyd Young
clip > Boyd - has Beauford died? I dint hear about it. > If so, why’d he do that?? End vlip
Richard Pike
PostPosted: Thu Apr 06, 2017 7:11 pm    Post subject: Re: Vgs Reply with quote
I am pretty sure that Beauford had a very serious stroke. He was a huge asset to this group.
 Filesize:  37.63 KB
 Viewed:  5705 Time(s)
 Filesize:  40.88 KB
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
