Starter engaged warning light
jpoint(at)wi.rr.com
PostPosted: Tue Apr 11, 2017 7:30 pm    Post subject: Starter engaged warning light Reply with quote
Bob and fellow listers,
My starter solenoid (B&C) is not the type with a post for a starter
engaged warning light. It seems to me that I could simply run a wire
from the starter side of the solenoid to a warning lamp with no issues.
Once energized, the starter would draw it's large current and the lamp
it's very small current. Is it that simple of am I missing something?
Jeff Point
Milwaukee
Tim Olson
PostPosted: Tue Apr 11, 2017 8:24 pm    Post subject: Starter engaged warning light Reply with quote
Hey Jeff,
I'm not 100% sure on this but I think I've seen a cutaway photo showing
that the
"I" terminal on the other type of solenoid is actually connected
internally to the same
basic spot as the big terminal is. So I would think it would work just
fine.
I can't think of any real reason not to do it, as long as the main
terminal is secure
and has enough exposed threads with an added ring terminal there, and I bet
it will fit fine. I did put the starter engaged light on my -14, but I
have the
regular Van's solenoid.
Mine is like the second one on page 6.
http://verticalpower.com/_documents/_pdf/contactor_wiring.pdf
I'm guessing that the reason they even added the terminal is for
simplicity in wiring those smaller wire ends to the solenoid without needing
a large ring terminal.
Up NorthWest of you
issues. Once energized, the starter would draw it's large current and
the lamp it's very small current. Is it that simple of am I missing
something?
Jeff Point
Milwaukee
PostPosted: Wed Apr 12, 2017 1:37 am    Post subject: Starter engaged warning light Reply with quote
At 11:21 PM 4/11/2017, you wrote:
--> AeroElectric-List message posted by: Tim Olson <Tim(at)MyRV10.com>
Hey Jeff,
I'm not 100% sure on this but I think I've seen a cutaway photo showing that the
"I" terminal on the other type of solenoid is actually connected internally to the same
basic spot as the big terminal is. So I would think it would work just fine.
Correct . . .
Actually, the "I" terminal is a holdover from
the early days of the transition from 6 to 12
volt cars. It was deduced that the original
6v Kettering type ignition coil could be
retained if one simply added a resistor in
series with the coil . . . the added source
resistance REDUCES coil charging time and
you got better performance at higher RPM.
A further benefit was realized by adding
the "I" for ignition terminal to the starter
contactor. This was used to bypass the coil
resistor increased spark energy at low
RPM of engine cranking. You can see the
full disclosure of the 3-terminal starter
contactors here:
[img]cid:.0[/img]
All three 'floating' terminals of the
power path through the contactor get connected
together simultaneously with the motion of
"B" against "A" as suggested by the schematic
below.
Fully floating contacts were necessary to achieve
design goals for the automotive world . . . and
they're handy for our purposes 60 years later to
drive a light bulb . . . but the same goal can be
achieved by attaching driving the light directly
from the starter motor's power input terminal.
Don't forget to fuse the wire at the starter
end if driving a lamp . . . or you could put
the LED's current limiting resistor in series
with the wire at the starter end and eliminate
the fuse . . . the resistor will protect the
shorted wire.
 Filesize:  155.64 KB
 Viewed:  3697 Time(s)
jpoint(at)wi.rr.com
PostPosted: Wed Apr 12, 2017 2:55 pm    Post subject: Starter engaged warning light Reply with quote
Thanks Bob (and others) for the detailed explanation confirming what I
thought. Protecting this run of 22ga wire seems like a perfect job for
a fusible link, and since I have some 26ga left over from the Ray Allen
servos, I will make one. The panel LED has a resistor built in so that
option is not available.
Jeff
On 4/12/17 4:25 AM, Robert L. Nuckolls, III wrote:
