Possum
Posted: Wed Jul 12, 2006 9:15 pm Post subject: fuel mix |
At 09:48 PM 7/12/2006, you wrote:
| Quote: | Hello group,
Is anyone using Amsoil Saber Professional (ATP) synthetic 2 cycle oil mix 100 to 1 in a 503 Rotax or had experence with it?
Thanks Jim Swan
Jim Swan in Michigan
will soon have a Kolb FS |
>I guess I can tell you my/our story. When I decarbed the heads and
>the top of the good pistons & the piston ring slots, I discovered that the
>carbon was rock hard. I have decarb engines before and since but this material was
>more fused that just plain carbon build up. I got to checking my oil. I
>had bought a case of Amsoil in late 1998
Nothing personal, and nothing personal against you, but I've/we've been flying
these things since 1983 and "Amsoil" sucks, it cost us Cuyuas' in the 80's
and I think it will cost you Rotax's in the 90's-2001.
From the archives - do not archive
Possum
Posted: Wed Jul 12, 2006 10:00 pm Post subject: fuel mix |
Thanks Jim Swan |
The 503 (Dual Carb)is a rock, it is a stone, it is the pinnacle of the
two stroke.
[/b] | The single carb has to be massaged - just a little.
| Quote: | I've flown a 447 with points - on a KXP for at least 400
hours before
this one - they are/were finicky little engines,
they want everything to be just right. But...when everything is
right, they are hard to beat - you know what I mean.
I've got 698 hours now without a decarb - really. 1999 Engine 503
E-gear box (Going for the record "800 hours")
No carbon yet. Compression still 120 per cylinder - (like new) "outa
the box" Still checking with the dental mirrors and intake and
exhaust manifolds off (flashlight down the plug holes) every 50 or
so hours. Gotta repaint my muffler once in a while anyway - wish I'd got
it chromed when it was new..
Just a test guys - so don't flame me.
Don't try this at home.
I'm at the Ferguson Farm & I'm JUST the test pilot for "this
one" anyway.
Never had the jugs off - never had the engine even hick up.
And I know that's not what the book says.(Where no man has gone before -
800 hr on a 503 CDI no decarb).
We who are about to die - salute you.
[/b] | BUT - GUYS! I GOT A BRAND NEW 65 HP "-----" AIR COOLED ENGINE.
SITTING IN THE BOX - JUST WAITING FOR ME TO TEST FLY or
BREAK IT. WEIGHT = 92 LBS. - 13 EXTRA HP!
JUST GOTTA BREAK THIS ONE FIRST!
I KNOW I CAN DO IT -
ANY SUGGESTIONS FROM THE PEANUT GALLEY?
Dave Bigelow
Joined: 29 Jan 2006 Posts: 103 Location: Kamuela, Hawaii
Posted: Thu Jul 13, 2006 1:21 am Post subject: Re: fuel mix |
Jim,
Probly not a good idea with Rotax two stroke engines. The amsoil leaves a sticky gunky black deposit which tends to cause the rings to get sticky, resulting in high cylinder head temperatures.
You can't go wrong with California Power System's AV2 oil or Pensoil Two Stroke Oil for Air-Cooled Engine. There are a number of other good two stroke oils out there that people swear by. The subject is kind of like politics or religion!
?? Is anyone using Amsoil Saber Professional (ATP) synthetic 2 cycle oil mix 100 to 1 in a 503 Rotax or had experence with it?
???? Thanks??? Jim Swan
_________________ Dave Bigelow
Kamuela, Hawaii
FS2, HKS 700E |
Arty Trost
Joined: 25 May 2006 Posts: 206 Location: Sandy, Oregon
Posted: Thu Jul 13, 2006 5:56 am Post subject: fuel mix |
Phile Lockwood of Lockwood Aviation has done the most
comprehensive testing I'm aware of re: oils for Rotax
2-stroke engines. (He's written articles about the
topic.) Two years ago at Arlington, he spoke on the
topic. My notes show that he said NOT to use ANY of
the 100-1 oils. He reminded us that oil has two
purposes - lubricating and cooling, and the 100-1
formulations don't do an adequate job on the cooling
end.
His research (he put 5 or 6 Rotaxes on a stand and ran
them for hundreds of hours with different oils) said
that Penzoil air-cooled was the best oil in a 2-stroke
Rotax. It is NOT compatible with any of the TC-W3
formulations (not even with Penzoil's outboard motor
oil, which is TC-W3) and he recommended draining the
gas tank before switching. I think if you contact
Lockwood Aviation (1-800-LA-ROTAX) they'll send you a
copy of the article.
Penzoil air-cooled is hard to find - so when I go on
long cross-country flights, I switch to Penzoil
outboard; since it's compatible with all other TC-W3
oils, you can use ANY TC-W3 oil if you're out in the
sticks and can't find Penzoil outboard motor oil.
As someone else on this list responded, oil selection
is as contentious a topic as religion or politics.
Arty
Thanks Jim Swan
www.LessonsFromTheEdge.com
"Life's a daring adventure or nothing"
Helen Keller
"I refuse to tip toe through life just to arrive safely at death."
blackbird
Posted: Thu Jul 13, 2006 10:15 am Post subject: fuel mix |
I think the article you are referring to was in a magazine with 2 strokes
mounted on a trailer.....12 years in ultralights and I have always used the
Penzoil air cooled even with a water cooled engine...
The article also showed the inside components after a certain number of
hours ....
It was great...
Wayne McCullough
_________________ Wish I lived in the American REPUBLIC!!! |
ElleryWeld(at)aol.com Guest
Posted: Thu Jul 13, 2006 11:46 am Post subject: fuel mix |
I feel the same way about what it says in the book I am flying the 447 with 359 hours and no problems and the key word ( yet ) and a new engine on the shelve also, but I dont want to put it on untill its time or when someone buys it then I will sell it with a new engine and keep the old engine for my next Firestar project thats on its way ,I have heard of others on the list running a two stroker alot longer than what the book says and as long as it keeps working great I plan on running it untill the vitals start running low on the inspections
Ellery in Maine
Jim Baker
Posted: Thu Jul 13, 2006 1:48 pm Post subject: fuel mix |
I tried to resist.......Auuuggghhhh!!!! Couldn't do it.....
First....
This is not an advertisement for 100:1 oils
Second.....
| Quote: | As someone else on this list responded, oil selection
Oil performance is quantifiable when exposed to rigorous testing
and objective investigation. The other two.....
| Quote: | Phile Lockwood of Lockwood Aviation has done the most
end.
A quote from an article that referenced these tests...
http://www.ultralightnews.com/features/oiltest.htm
____________________________________
Four different oils were chosen for the test. The oils
tested were:
1) Pennzoil" Two-Cycle Air-Cooled Engine Oil;
2) Pennzoil' Premium Out- board and Multi-purpose Two
Cycle Oil;
3) A conventional petroleum two-cycle oil; and
4) A two-cycle synthetic oil.
How does one arrive at the position that 100:1 ratios,
using oils formulated for 100:1 operation, will not cool
adequately if none are tested?
Further on in the article....
It is worthy to note that many pilots using synthetic oil
may mix at a higher (leaner) fuel/oil ratio than the
engine manufacturer may specify. Synthetic oils tend to
work well against deposit formation at these higher
ratios, however engine manufacturers generally state
that the higher (leaner) oil ratio may not provide
enough residual protection from corrosion during
extended storage conditions. Therefore, all oils run in
this test were run at the manufacturer's recommended
fuel/oil ratio of 50: 1.
Here is the possible start point for extrapolating
inadequate cooling from higher oil ratios when 50:1 oils
are used at higher ratios. False analogy, non sequiter,
and appeal to authority are not bases for scientific
proof.
This is what Pennzoil (Shell) claims in their Technical
Info letter P-15-A as the rationale for their air cooled
oils (the bold is my highlighting).....
________________________________________
Air cooled two-cycle engines are often idle or operate at
low output between bursts of high output
use. The idle time and infrequent high output use results
in lower average piston temperatures than
outboard engines. This results in less oil thinning in air
cooled engines.
The continued variations in speeds and the physical
punishment that these engines experience play a
key role in breaking off ash deposits that are formed by
detergent additives in two-cycle oils.
Consequently, detergent additives used in two-cycle oils do
not harm air cooled two-cycle engines.
Since air cooled engines have extensive idle and low
output operating time and lower average piston
temperatures, they do not always completely burn the
heavier oil that may be present in two-cycle oils.
This partially burned heavy oil causes carbon buildup in
exhaust ports and the exhaust system.
Buildup of these deposits causes loss of power.
Does this sound like your air-cooled two stroke engine?
Lots of idle time? Extensive low output time? Infrequent
high-output time?
Moving on......
| Quote: | His research (he put 5 or 6 Rotaxes on a stand and ran
Rotax.
"Best" is a relative term when one only tests four oils. As for TC-
W3 certification....
__________________________________________
TC-W3® lubricant, an NMMA owned trademark, has
evolved over the years through much testing and research,
and has proven to be the level of quality to satisfy the above
objectives. And, going a step further, now that two cycle
engines have moved towards higher cylinder temperatures
and compressions, this lubricant also meets the EPA
emissions reductions.
TC-W3® has demonstrated the necessary lubrication
performance quality needed for these more demanding
cylinder/engine conditions.
NMMA licenses those two cycle lubricants that meet the
stringent performance tests conducted by a sanctioned
laboratory approved by NMMA to conduct the tests.
This is the list of TC-W3 certified oils......
http://tinyurl.com/ko6dq
| Quote: | It is NOT compatible with any of the TC-W3
Based on the following from Pennzoil....
Pennzoil has three oils for two-cycle engines, Premium
Outboard And Multi-Purpose Two-Cycle Oil TC-W3TM,
Advanced-Performance Snowmobile Oil and 2-Cycle Air
Cooled Engine Oil, each specifically designed for different
applications. Care should be taken to avoid mixing the
various two-cycle oils together, especially when converting
a customer from one product to the other product.
Pennzoil® Premium Outboard and Multi-Purpose Two-Cycle
Oil TC-W3TM and Advanced- Performance Snowmobile Oil
contain ashless dispersant additives, whereas Pennzoil® 2-
Cycle Air Cooled Engine Oil contains a low-ash detergent
additive.
As a general rule, ash-containing two-cycle oils should not
be mixed with ashless two-cycle oils, as their additives may
be incompatible with each other. This would apply not only
to Pennzoil's two-cycle products, but to all two-cycle oils on
the market. Since Pennzoil® Premium Outboard And Multi-
Purpose Two-Cycle Oil TC-W3TM and Advanced-
Performance Snowmobile Oil are ashless formulations,
mixing of these products with an ash-containing product
should be avoided.
_______________________________________________
Arty is correct on this point. I can only take Pennzoil's
admonition at face value.
Those of us using 50:1 oils that do not have a Pennzoil label
and those of us using 100:1 oils recognize how thin the
argument is that any one oil is best. Interesting to note that
Lockwood doesn't specify which two stroke oil they sell on
their WEB site. If Air Cooled oil were best for air cooled
engines, why not carry both?
Jim Baker
580.788.2779
Elmore City, OK
eagle1(at)commspeed.net Guest
Posted: Thu Jul 13, 2006 5:07 pm Post subject: fuel mix |
For what it's worth (2 cents?) I have used Pennzoil air cooled oil in all my
Rotex 247 and 503's for approx. 700 hrs and have never had a stuck ring nor
cleaned the carbon.
Az Bald Eagle
Arksey(at)aol.com Guest
Posted: Thu Jul 13, 2006 5:08 pm Post subject: fuel mix |
Hello group,
I want to thank everyone for their input of my question, which was if anyone was using Amsoil Saber Professional (ATP) SYNTHETIC 2 CYCLE oil at 100-1 mix in a rotax 503 ...There is a wealth of experence and knowledge in this group. Possum's you sure have put some time in the air, hope to meet you some day, and Arty I have read some of your accounts of your cross country flights and I found them very enjoyable...what got me interested in our type of aircraft was a flight I took in a 2 place Drifter in Sebring Fl with Jeff Hudson a couple of years ago. The Drifter had Lotus floats and wheels and what a wonderful flight it was, I could not get over the visibilty and that is why I decided to look for that type of aircraft and decided on a Kolb firestar. I spend the winters at Sebring and have met Phil Lockwood and have great respect for his judgement and knowledge... Thanks again to all...Jim Swan
Posted: Fri Jul 14, 2006 1:01 am Post subject: fuel mix |
oil selection
| Quote: | is as contentious a topic as religion or politics.
and objective investigation. >>
Not at all like religion then!!!!
Cheers
Pat
Arty Trost
Posted: Fri Jul 14, 2006 5:57 am Post subject: fuel mix |
--- Jim Baker <jlbaker(at)msbit.net> wrote:
it.....
Jim -
I'm GLAD you couldn't resist - your information was
very informative. This is one of the reasons why I'm
on the Kolb list, even though I fly a Drifter! (The
other is that I met so many neat people at the MV Kolb
fly-in, and every time I see their posts on this list,
it's like being with them again.)
So thanks for the research.
Arty
Helen Keller
Richard Pike
Posted: Fri Jul 14, 2006 6:40 am Post subject: fuel mix |
Some of us would disagree. But that would require a different list.
Richard Pike
MKIII N420P (420ldPoops)
Pastor, Blountville Community Chapel
pat ladd wrote:
| Quote: | <snip>
Oil performance is quantifiable when exposed to rigorous testing and
Cheers
Pat
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
ulflyer(at)verizon.net Guest
Posted: Fri Jul 14, 2006 7:44 pm Post subject: fuel mix |
We were running CPS's AV2 in two planes with 447's. It worked fine
but cost $$$, CPS couldn't seem to ship it with a reasonable lead
time. It didn't produce a lot of carbon but the deposits were hard
and hard to clean off. Switched over to Pennzoil, been running that
for some time. Carbons a little more but easier to clean off. Just
pulled the exhaust off, the pistons and rings looked good, little
build up on the edges of the manifold. So far I am happy with
Pennzoil (aircooled) plus I can buy it locally by the case at a
reasonable price.
jerb
At 04:21 AM 7/13/2006, you wrote:
Jim,
> Hello group,
Dave Bigelow
Kamuela, Hawaii
FS2, Rotax 503 DCDI
http://forums.matronics.com/viewtopic.php?p=46838#46838
