Posted: Fri May 05, 2017 3:41 am Post subject: Switches and Breakers |
At 08:36 PM 5/4/2017, you wrote:
| Quote: | | I agree in spirit, BUT I recently ran into an issue where the procedure for handling an ignition system failure indication, is to pull the ignition system breaker while the engine is running. This is not a situation where the manufacture and myself would not want a switch. |
"Failure indications" are not normal
operations . . . and yes, crew are
sometimes advised to pull breakers
for duration of flight as response to
a failure; implementing Plan-B for
comfortable termination of flight.
But I'm curious as to the design of
any ignition system that is not effectively
shut down by simply turning it off.
Was the pulling of a breaker intended
to 'reset' the failure or was the
breaker pulled to prevent a malfunctioning
ignition from causing more mischief
even tho it was commanded OFF by normal
positioning of controls?
I'm aware of no electronic ignition
system offered to the OBAM aviation
market that would require such an
action . . . setting the panel control
to OFF does what the label implies.
Do you recall what make/model of ignition
system suggested this procedure? Was
it to 'reset' the light or simply
disable the system for duration
of the flight?
neil(at)rosoff.com Guest
Posted: Fri May 05, 2017 6:50 am Post subject: Switches and Breakers |
The plane is a Twin Commander with TPE 331-10s. The specific failure is the 50% speed switch. There are 4 or 5 operational items that happened at that time. If any one of them fail the ignition indication will remain on. Resetting the breaker will reset all of the thing that happen at 50%. Interestingly enough this procedure was "Tribal Knowledge" on my model, the next model the procedure was documented in the POH.
Neil Rosoff
On May 5, 2017, at 7:39 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
of the flight?
jim(at)PoogieBearRanch.co Guest
Posted: Fri May 05, 2017 12:16 pm Post subject: Switches and Breakers |
OK - I give up.
I cannot find the meaning of "OBAM" anywhere, but I see it used
frequently in this list. What does it mean?
Thank you.
Jim Parker
harleydixon
Joined: 17 Sep 2016 Posts: 18 Location: Henrietta, NY
Posted: Fri May 05, 2017 12:27 pm Post subject: Switches and Breakers |
I once had the same question...Had me guessing for awhile as well.
Owner Built And Maintained!
Harley
On 5/5/2017 4:14 PM, jim(at)PoogieBearRanch.com (jim(at)PoogieBearRanch.com) wrote:
| Quote: | | Quote: | --> AeroElectric-List message posted by: <jim(at)poogiebearranch.com> (jim(at)poogiebearranch.com)
OK - I give up.
Thank you.
Jim Parker
_________________ Harley Dixon
Long EZ N28EZ
Canandaigua Airport (D38)
Canandaigua, NY |
cluros(at)gmail.com Guest
Posted: Fri May 05, 2017 12:28 pm Post subject: Switches and Breakers |
I always thought Owner Built And Maintained.
On Fri, May 5, 2017 at 1:14 PM, <jim(at)poogiebearranch.com (jim(at)poogiebearranch.com)> wrote:
[quote]--> AeroElectric-List message posted by: <jim(at)poogiebearranch.com (jim(at)poogiebearranch.com)>
OK - I give up.
Thank you.
Jim Parker
ngeorge(at)cmg.aero Guest
Posted: Fri May 05, 2017 12:32 pm Post subject: Switches and Breakers |
OBAM
Owner Build And Maintained aircraft
neal
JohnCiolino(at)carolina.r Guest
Posted: Fri May 05, 2017 1:17 pm Post subject: Switches and Breakers |
Jim,
It's an acronym for "Owner Built And Maintained"
John
Posted: Fri May 05, 2017 3:17 pm Post subject: Switches and Breakers |
At 04:15 PM 5/5/2017, you wrote:
| Quote: | --> AeroElectric-List message posted by: "John Ciolino" <JohnCiolino(at)carolina.rr.com>
Jim,
It's an acronym for "Owner Built And Maintained" |
I coined the phrase many moons ago after
having worked decades with one foot in
TC aircraft, the other in 'experimental'
aircraft.
While 'experimental' is the official
designation for giving a builder something
that amounts to a permanent, unbounded
ferry permit, I thought the term inadequate
and misleading. While we are indeed free to
EVOLVE our aircraft, the vast majority of what
gets licensed every year is anything but
and experiment.
The OBAM aircraft industry has at least
met and perhaps surpassed the quality,
utility and reliability of the TC
aircraft. I am loath to debase our
craft with a term that does not comport
with reality.
Posted: Sat May 06, 2017 6:37 am Post subject: Switches and Breakers |
At 09:48 AM 5/5/2017, you wrote:
| Quote: | | The plane is a Twin Commander with TPE 331-10s. The specific failure is the 50% speed switch. There are 4 or 5 operational items that happened at that time. If any one of them fail the ignition indication will remain on. Resetting the breaker will reset all of the thing that happen at 50%. Interestingly enough this procedure was "Tribal Knowledge" on my model, the next model the procedure was documented in the POH. |
Hmmmm . . . yeah, there are probably dozens
of examples for what my bosses would have called
a 'work around' for relatively minor deficiencies
in system FEMA.
The condition you cited was probably not discovered
before the system was holy-watered for production.
As a general rule on new designs, we were chartered
not to rely on crew management of input power by
cycling power to a bus or pulling a breaker.
To be sure, there have been instances
where the practice did find its way into
the cockpit but the work around could only be
applied in low pucker-factor situations.
Finding and operating the right breaker in a
sea of little black knobs with lights flashing,
bells going off or captain giving tense orders
was problematic at best. We just didn't do
it.
On our airplanes, such a condition is EASY to
fix . . . on airplanes with TCs . . . not so much.
efraim.otero(at)gmail.com Guest
Posted: Sat May 06, 2017 8:31 pm Post subject: Switches and Breakers |
Neal:
Wouldn't that be
OBAMA?
[quote] On May 5, 2017, at 3:31 PM, Neal George <ngeorge(at)cmg.aero> wrote:
OBAM
neal
billhuntersemail(at)gmail Guest
Posted: Sat May 06, 2017 9:11 pm Post subject: Switches and Breakers |
| Quote: | Wouldn't that be OBAMA?
Chirp...chirp...chirp...no response to your joke for some reason Neal...
Ouch...folks are still sore I guess...
: ) < ------ CJII (Cyber Joke Indicator Icon)
Cheers!!!
Bill Hunter
Robert Reed
Joined: 22 Oct 2009 Posts: 331 Location: Dallas/Ft.Worth
Posted: Sun May 07, 2017 4:30 am Post subject: Switches and Breakers |
Only if they were intended to Always Crash and Burn.
Bob Reed
[quote] On May 6, 2017, at 11:29 PM, Efraim Otero <efraim.otero(at)gmail.com> wrote:
Neal:
Wouldn't that be
OBAMA?
> OBAM
> neal
neal.george(at)gmail.com Guest
Posted: Sun May 07, 2017 5:35 am Post subject: Switches and Breakers |
Oh hell!
Words escape me.
Mea culpa
Neal George
Bob Reed
Neal:
Wouldn't that be
OBAMA?
> OBAM
> neal
ceengland7(at)gmail.com Guest
Posted: Sun May 07, 2017 7:01 am Post subject: Switches and Breakers |
1st, politics are not the subject of this list.
2nd, do you really want to go there, Vladimir?
Bob Reed
> Neal:
> Wouldn't that be
> OBAMA?
> Sent from my iPhone
>> OBAM
>> neal
