		mp.gamble(at)talktalk.net Guest
				 Posted: Tue May 16, 2017 12:07 am    Post subject: engine support |
				Can anyone tell me what tool is needed to fit the 4 engine support bolts – 912S engine mount to block?
 Mike Gamble
 Mono XS
 G-CFMP
		JonathanMilbank
  Joined: 14 Apr 2012 Posts: 397 Location: Aberdeen area
				 Posted: Tue May 16, 2017 2:10 am    Post subject: Re: engine support |
				I used an Allen key/wrench for mine. Additionally you'll probably need to temporarily remove one of the inlet manifolds and maybe even a coolant elbow pipe connector on one of the cylinder heads to get access to one of the bolts.
 You'll probably also find that you need to slide a metal tube/pipe of some sort over the end of the Allen key to get leverage for tightening.
		pjeffers(at)talktalk.net Guest
				 Posted: Tue May 16, 2017 11:56 pm    Post subject: engine support |
				Hi Mike,
 You just need an Allen Key of the correct size but you will need one that is long enough to reach, in particular, the ones on the LHS of the engine.
 I am afraid you will need to go to a good tool shop. An alternative that I use is a correct size key bit on the end of an extension rod.  In order to keep the diameter as small as possible use 1/4" square drive extension.
 Pete
 From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of mp.gamble
 Sent: 16 May 2017 09:07
 Subject: engine support
 Mike Gamble
 Mono XS
 G-CFMP
 Virus-free. www.avg.com
				 Posted: Wed May 17, 2017 9:02 am    Post subject: engine support |
				Right Pete but what size key bit is needed? I have the 1/4 ‘’ extension.
 Mike
		Nigel Graham
  Joined: 23 Mar 2017 Posts: 36 Location: Winchester - UK
				 Posted: Fri May 19, 2017 6:53 am    Post subject: Re: engine support |
				Mike, you need an 8.0 mm hex. If you need to buy the tool, look for one with a spherically ground tip - it will allow you to tighten the hex head Allen bolts from a slight angle (up to about 10 degrees I think) which is useful if you can't get a "straight in approach" to the little blighters!
				 Posted: Thu May 25, 2017 9:10 am    Post subject: engine support |
				Thanks Nigel. A straight in approach it isn't but we will manage.
 Mike
