barrie
Kellym
Posted: Fri May 19, 2017 6:06 pm Post subject: magneto problems |
Are you certain that you had the engine at TDC on the compression stroke
when you installed the left mag? You can get your symptoms if the mag is
installed on the non-firing stroke.
On 5/19/2017 5:14 PM, barrie wrote:
Quote: |
Hi, I have just finished an engine install in my homebuilt and have a problem with the Mags(probably of my own doing). After starting and checking for mag a drop, the left mag somehow appears to be grounded. The engine starts ok and the left mag has the impulse so I am assuming that it was working alright to begin with. Also the right one is working just fine. [Question] I am sure that I have overlooked something but just haven't been able to figure it out. Does anybody have the magic solution?
Barrie
http://forums.matronics.com/viewtopic.php?p=469448#469448
KCHD |
barrie
Posted: Fri May 19, 2017 6:15 pm Post subject: Re: magneto problems |
Yes, positive. I took a lot of care when doing the installation
JohnCiolino(at)carolina.r Guest
Posted: Sat May 20, 2017 1:52 am Post subject: magneto problems |
Barrie,
You probably used shielded wire for the P-lead. Check that the shield wire
is not touching the terminal.
John Ciolino
Bearhawk Patrol
joerhenry(at)suddenlink.n Guest
Posted: Sat May 20, 2017 5:49 am Post subject: magneto problems |
It can be difficult to time a mag with an impulse coupling. The impulse coupling must be disengaged or the timing will be incorrect. You should turn the prop in direction of rotation enough to hear the coupling snap. Then you can turn backwards to set the timing advance but not so much to reset the impulse coupling. jrh
---- John Ciolino <JohnCiolino(at)carolina.rr.com> wrote:
Barrie,
John Ciolino
Bearhawk Patrol
barrie
barrie
