HJ460 kit A238 flies
wdaniell.longport(at)gmai
PostPosted: Tue May 30, 2017 4:00 am    Post subject: HJ460 kit A238 flies Reply with quote
HJ 460 Flew yesterday at the hands of Alfredo Gracia in SKGY taking off at 8500 and doing circuits for 20 mins at 10500.  An emotional moment.
Thanks to all, it would not have been possible without the help of the forum.
Alfredo reported that everything was fine except for a marked nose up tendency despite trim
My trim is standard Kit LED with a vehicle Electric Window Switch and the Dynon AP panel.  The trim works normally on the ground with the appropriate deflections.
Alfredo even suggested taking off with two LED bar nose down which i suspect is not normal.
I spoke to Bud who suggested the following as a first look
1.  Check the trim is working correctly (not back to front)
2.  Check the CG for tail heavy
3.  Check the flaps fully retract against the incidence template.
Suggestions and ideas welcome.
Again, many thanks to all
Will
William Daniell
LONGPORT
+57 310 295 0744
 Filesize:  1.68 MB
 Viewed:  4896 Time(s)
rlborger(at)mac.com
PostPosted: Tue May 30, 2017 5:47 pm    Post subject: HJ460 kit A238 flies Reply with quote
William,
Congratulations on the first flight of your fine looking aircraft.
Blue skies & tailwinds,Bob BorgerEuropa XS Tri, Rotax 914, Airmaster C/S Prop (75 hrs).Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP3705 Lynchburg Dr.Corinth, TX 76208-5331Cel: 817-992-1117rlborger(at)mac.com (rlborger(at)mac.com)
On May 30, 2017, at 6:59 AM, William Daniell <wdaniell.longport(at)gmail.com (wdaniell.longport(at)gmail.com)> wrote:
Will
William Daniell
LONGPORT+57 310 295 0744
<20170527_170717.jpg>
Fred Klein
PostPosted: Tue May 30, 2017 7:52 pm    Post subject: HJ460 kit A238 flies Reply with quote
Hearty Congratulations Will…especially after building under somewhat isolated conditions...might you be the first first-flight on your continent?
Many happy landings,
Fred
On May 30, 2017, at 4:59 AM, William Daniell <wdaniell.longport(at)gmail.com (wdaniell.longport(at)gmail.com)> wrote:
PostPosted: Wed May 31, 2017 1:49 am    Post subject: HJ460 kit A238 flies Reply with quote
Fred and bob
No not that much of a trail blazer. ..there have been about 6 constructed in colombia.  I think there is one in argentina and one in brazil but i could be wrong.
However due to distance and terrain i didnt have much dialogue with the other colombia  constructor who builds essentially to resell.
The forum bud the late Nev and the factory were the biggest help.
Many thanks again Will
On May 30, 2017 22:54, "Fred Klein" <fklein(at)orcasonline.com (fklein(at)orcasonline.com)> wrote:
Fred
graeme bird
PostPosted: Wed May 31, 2017 3:53 am    Post subject: Re: HJ460 kit A238 flies Reply with quote
Great, congratulations.
Mine has the trim set well down for almost everything - always been so. Didn't seem to upset Mr Draper. Maybe there is a way to centralise it.
Graeme Bird
kit4 (Wagstaff) TBD
Kit 1 G-UMPY - Mono Classic/XS 912S, Woodcomp G(@)gdbmk.co.uk
