altman51
Posted: Fri Jun 23, 2017 7:31 am Post subject: Excessive fuel burn on CJ6 (Housai engine) |
Am lately getting excessive fuel burn at about 19gph when previously it was about 15gph. anybody have this problem if so what did you find?
pa3arw(at)ziggo.nl Guest
Posted: Fri Jun 23, 2017 8:32 am Post subject: Excessive fuel burn on CJ6 (Housai engine) |
Too low compression on one or more cilinders??
Hans O.
wlannon(at)shaw.ca Guest
Posted: Fri Jun 23, 2017 9:26 am Post subject: Excessive fuel burn on CJ6 (Housai engine) |
Fuel burn or fuel leakage??
One possibility if your fuel header tank has been modified to include a
quick-drain fitting: In flight normal positive pressure on the lower
surface is sufficient to
force upwards any un-reinforced sheet metal access panel. The header tank
panel is a perfect example. It is large and un-reinforced and, in my
estimation, the centre portion could move upwards 5 or 6 mm or more, easily
enough to activate a poorly placed quick drain.
Check it out. If suspect, check the drain hole in the dome is open and push
the panel upward by hand.
Walt
altman51
Posted: Fri Jun 23, 2017 11:34 am Post subject: Re: Excessive fuel burn on CJ6 (Housai engine) |
Thanks guys will check it all out.
bwade154(at)yahoo.com Guest
altman51
