Master contactor catch diode failure
jdubner
PostPosted: Tue Jun 27, 2017 10:56 am    Post subject: Master contactor catch diode failure Reply with quote
What would be the root cause of this charred diode and wiring?
https://i.imgur.com/e3FcBgf.jpg
https://i.imgur.com/Sl9foF6.jpg
This is in a friend's RV-9A and the diode was wired (properly) across the master
contactor's coil. The wire runs to the master switch (split-rocker type) where
a ground is applied. Both the contactor and the diode were supplied by Van's
Aircraft.
http://vansaircraft.com/cgi-bin/store.cgi?ident=1498576754-172-723&browse=electrical&product=master-sw
http://vansaircraft.com/cgi-bin/store.cgi?ident=1498576754-172-723&browse=electrical&product=diodes
This incident happened the instant the master power was turned on. Could the
diode have failed in a shorted condition, vaporizing itself and the wire when
the switch applied a ground?
After replacing the diode and wiring, operation seems normal.
Joe
Independence, OR
Bob McC
PostPosted: Tue Jun 27, 2017 11:53 am    Post subject: Master contactor catch diode failure Reply with quote
The most obvious answer is that the original diode was installed backwards. Maybe the supplied "packaged" assembly from Vans was incorrectly assembled under the heat shrink causing full battery voltage and hence current to forward bias the diode leading to its action as a fuse. The new assemblies shown in your photos leave no possible clue as to the direction the encapsulated diode is oriented. The external red band is fine and dandy, but if the diode under the shrink was accidentally reversed there is no way to know without "testing". I would suggest your "test" proved conclusively it was incorrect.
Bob McC [quote]
Bob McC
Falco #908
(just starting)
jdubner
PostPosted: Tue Jun 27, 2017 1:16 pm    Post subject: Re: Master contactor catch diode failure Reply with quote
That was my initial thought too but the aircraft had 29 hours TTSN with that configuration.
The RV-9A owner told me this incident happened on the first master switch actuation after battery replacement due to a totally discharged battery. There was a battery charger involved but the owner assured me it was always connected properly. And the master contactor actuated, at least momentarily, because the Dynon EFIS turned on (and continued to run on its internal battery).
PostPosted: Wed Jun 28, 2017 3:04 am    Post subject: Master contactor catch diode failure Reply with quote
Agreed . . . with one other possibility . . .
I have encountered plastic diodes that
were incorrectly marked. Band on the
wrong end. It's rare but I think I've
seen it a couple of times. Further,
they were a one-of event, not a 'batch'
problem.
I'm not sure this is possible but it's
certainly low probability given modern
manufacturing and grading techniques
for diodes. But these days, there are
diodes and then there are DIODES. Without
knowing the critter's pedigree, we'll never
know.
In any case, replacing the diode is the
permanent fix.
billhuntersemail(at)gmail
PostPosted: Wed Jun 28, 2017 6:21 am    Post subject: Master contactor catch diode failure Reply with quote
How does one (me) check a diode when it is installed on the contactor?
I assume that you want to have the master switch off and use DC resistance. Does it matter what polarity to connect the leads?
  problem.
  know.
  permanent fix.
PostPosted: Wed Jun 28, 2017 11:40 am    Post subject: Master contactor catch diode failure Reply with quote
Just unhook one end (the small terminal) and use
your ohmmeter function to test continuity through
the diode. One configuration will show SOME value
of resistance, reversing the leads will show
infinite resistance.
You test BOTH ways . . . looking for basically
NO conduction one way (off scale high resistance)
and some value of resistance the other way . . .
the exact value unimportant as it will vary
from one ohmmeter to another.
PostPosted: Wed Jun 28, 2017 11:47 am    Post subject: Master contactor catch diode failure Reply with quote
At 04:16 PM 6/27/2017, you wrote:
--> AeroElectric-List message posted by: "jdubner" <jdubner(at)yahoo.com>
THIS IS NOT GOOD . . . If the diode WAS good
and fried after battery replacement, then the
battery was hooked up BACKWARDS . . . This
fries the catch diode and potentially, lots
of other stuff.
Years ago, I used to recommend adding a fuse
in series with the battery master contactor
wire that runs off to the master switch.
When paired with a catch diode on the contactor
the diode shorts out reversed voltage to the
contactor preventing closure while the fuse
blows preventing wire damage . . . and perhaps
damage to the diode as well.
But it sounds like this event went on long
enough to open the diode, close the contactor
and to put battery energy onto the ship's bus . . .
PostPosted: Wed Jun 28, 2017 11:50 am    Post subject: Master contactor catch diode failure Reply with quote
Also, how warm do contactors get when they are energized?
I have two contactors mounted in a well underneath the backseat of my airplane.  This well is about three inches deep 20 inches wide and 12 inches long and it's completely sealed with no cooling air and since it is constructed of foam core fiberglass It is Well insulated and therefore none of the heat can get conducted out of the airplane.
I felt them and the contactors do get warm but the question is how warm can they get and do they need any cooling air? Inflight only one contactor will be energized however on the ground during maintenance I will have both contactors energized.
THANKS AGAIN FOR YOUR HELP
Bill Hunter On Jun 28, 2017 12:44 PM, "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
PostPosted: Wed Jun 28, 2017 12:11 pm    Post subject: Master contactor catch diode failure Reply with quote
Too hot to touch but not hot enough to 'sizzle spit'
http://tinyurl.com/mpcgp3t
http://tinyurl.com/k6bwdqo
Materials used in construction of these devices
is rated for operating at temperatures well in
excess of 100C . . . but of course, hotter than
you would want to touch.
PostPosted: Wed Jun 28, 2017 12:49 pm    Post subject: Master contactor catch diode failure Reply with quote
Thanks Bob!!!
The next time I have them humming for two hours at room temperature I will lick them to see if spit sizzles.
Thanks again,
Bill Hunter On Jun 28, 2017 1:15 PM, "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
ceengland7(at)gmail.com
PostPosted: Wed Jun 28, 2017 1:56 pm    Post subject: Master contactor catch diode failure Reply with quote
Do be aware that the temp it will get a *lot* hotter in your sealed up insulated box than it will sitting on your kitchen counter. I wouldn't do what you're talking about, because I wouldn't want to melt my aircraft in that area. Component life might be a secondary issue, in this case (pardon the pun).
On 6/28/2017 3:48 PM, William Hunter wrote:
Thanks Bob!!!
Thanks again,
PostPosted: Wed Jun 28, 2017 4:32 pm    Post subject: Re: Master contactor catch diode failure Reply with quote
I agree with Charlie. The heat given off by a fire (caused by hot contactors) will be a whole lot hotter than the heat given off by contactors exposed to circulating air. What is the purpose of an insulated box?
At what temperature will the diode start conducting in the reverse direction? Nobody knows how hot it will get inside of the box because it depends on several factors: size of box, how well it is sealed, insulating properties of the box, ambient air temperature, wattage of the contactor, length of time contactor is energized.
Joe Gores
PostPosted: Wed Jun 28, 2017 5:33 pm    Post subject: Master contactor catch diode failure Reply with quote
I appreciate everyone's opinions and suggestions!!!
The airplane is a Velocity (pusher) so it is constructed of fiberglass foam sandwich panels and I was trying to move as much of the heavy electrical cables aft closer to the engine so I placed these components under the rear bench seat. The rear seat "pedestal" (support structure) is a fiberglass box integral with the fuselage also constructed with fiberglass foam sandwich panels that equate to an "enclosed box".
I thought that this was an "elegant solution" to utilize this empty space as an electrical equipment box however I didn't really think about the BTU output of these contactors.
I guess I could cut some vent openings into the pedestal and that would introduce some cabin ambient air into the box (four feet away from the heater floor vents) however this would not be forced air ventilation but still much better than an enclosed, sealed, and very insulated box.
Bill Hunter On Jun 28, 2017 5:37 PM, "user9253" <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
Joe Gores
http://forums.matronics.com/viewtopic.php?p=470566#470566
donvansanten(at)gmail.com
PostPosted: Wed Jun 28, 2017 6:44 pm    Post subject: Master contactor catch diode failure Reply with quote
I would put the battery contactor as close to the battery as possible and the starter contactor on thd engine side of the firewall. This is how the RV 10 is done, battery in rear battery contactor inches away and starter contactor on the front of the firewall. I realize that your are building a pusher but this will work fine. This also keeps the heay generating contactors out in the open and seperated from each other.
On Jun 28, 2017 18:37, "William Hunter" <billhuntersemail(at)gmail.com (billhuntersemail(at)gmail.com)> wrote:
Joe Gores
PostPosted: Thu Jun 29, 2017 3:47 am    Post subject: Master contactor catch diode failure Reply with quote
I like that . . .
Starter contactors on firewall become a tie-point
for the altenrator's b-lead to tie into the fat-wire
system. Battery contactors are generally only
inches away from Battery(+).
Robert Reed
PostPosted: Thu Jun 29, 2017 5:58 am    Post subject: Master contactor catch diode failure Reply with quote
I am using your Z-14 dual alternator and dual battery design with the batteries under the pilot and copilot seats, battery contactor within 6 inches of battery. The crossover contactor and starter contactor on firewall with 2 inch crossover connection to starter contactor. Alternator B-leads connect to crossover input and starter input lead. Overvoltage connections just before connection to contactors. Any issues you can foresee?
Bob Reed
Sent: Thursday, June 29, 2017 6:48 AM
Subject: Re: Re: Master contactor catch diode failure
I like that . . .
PostPosted: Thu Jun 29, 2017 12:18 pm    Post subject: Master contactor catch diode failure Reply with quote
Okay
Okay
Okay
Not sure what this means . . . what hardware are
you using for regulators . . . do they
have ov protection built in?
Robert Reed
PostPosted: Thu Jun 29, 2017 12:49 pm    Post subject: Master contactor catch diode failure Reply with quote
"Always double check before hitting send...a motto I clearly forgot."
What I meant to say was I placed the ANL Current Limiters Before the connections from the B-Lead to the Starter Lead and Crossover Lead. (50 amp primary, 30 amp secondary)
I am using the B & C Regulators (LR3C-14) on both circuits.
Sent: Thursday, June 29, 2017 3:19 PM
Okay
Okay
Okay
