Strobe wiring?
davidjoyce(at)doctors.org
PostPosted: Sat Aug 19, 2017 12:36 pm    Post subject: Strobe wiring? Reply with quote
I am down to almost the last wire from my old fuselage to connect to the new bit and new panel and have run up against a problem with my Airworld Skyflash single head strobe. The wire coming from the driver unit is a fairly heavy gauge 3 core unshielded one with red, black and green wires. My problem is what to do with the green wire. The installation guide I have kept since 2000 doesn't mention it. Airworld went out of business a while ago. Internet search for a wiring diagram has drawn a blank, only turning up the same installation guide I already have, which is good on actual hardware fixing but no hint about the green wire. The driver is up in the tail cone where I really do not want to go! Can anyone help please?
Regards, David Joyce, GXSDJ
PostPosted: Sat Aug 19, 2017 1:27 pm    Post subject: Strobe wiring? Reply with quote
PS. It may be of course that I just used three core wire because I had it but there were only two cores connected!
Nigel Graham
PostPosted: Sat Aug 19, 2017 1:43 pm    Post subject: Re: Strobe wiring? Reply with quote
I have attached a copy of the Skyworld Installation instructions. These include the plug wiring. This may be what you are after.
Nigel
Skyflash Wiring Instructions.doc
 Filename:  Skyflash Wiring Instructions.doc
 Filesize:  72.5 KB
 Downloaded:  922 Time(s)
Duncan McFadyean
PostPosted: Sun Aug 20, 2017 1:06 am    Post subject: Strobe wiring? Reply with quote
David,
Airworld strobe stuff was supplied by Kuntzleman:
http://www.kestrobes.com/
Duncan.
----Original Message----
Date: 19/08/2017 21:34
To: "europa list"<europa-list(at)matronics.com>
Subj: Strobe wiring?
Burrilla
PostPosted: Sun Aug 20, 2017 2:58 am    Post subject: Strobe wiring? Reply with quote
Davind, sent you a pad document that i have if it helps - has a green wire in the diagrams.
If any use then perhaps the Europa site Webmaster might consider adding to the knowledge pool on the Europa Site for future as they Airworld now out of business.
Alan
GCDPY
On 19 Aug 2017, at 21:34, davidjoyce(at)doctors.org.uk (davidjoyce(at)doctors.org.uk) wrote:
dpark748(at)me.com
PostPosted: Sun Aug 20, 2017 5:48 am    Post subject: Strobe wiring? Reply with quote
While on the subject i am getting pulses of interference on my radio with my skyflash? Has anyone had similar problem and know the fix.
Dave Park G-LDVO
On 20 Aug 2017, at 11:57, Alan Burrill <alanb(at)dpy01.co.uk (alanb(at)dpy01.co.uk)> wrote:
Alan
GCDPY
pete(at)lawless.info
PostPosted: Sun Aug 20, 2017 7:37 am    Post subject: Strobe wiring? Reply with quote
Hi Dave
Yes I had a similar problem a couple of years back.  Ended up replacing the then 15 year old unit. Opened the box thinking it may be a capacitor but could not find anything obvious.
Pete
G-RMAC
Dave Park G-LDVO
Alan
GCDPY
