L29-List Digest: 1 Msgs - 09/29/17
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> L29-List
skyking76t(at)verizon.net
PostPosted: Sat Sep 30, 2017 4:53 am    Post subject: L29-List Digest: 1 Msgs - 09/29/17 Reply with quote
Hi Stan,
The consensus agrees with you that the major problem will lie in the tail outlet. Zach McNeil says there is one guy who has made this swap and he's trying to find more info.
Finding an airworthy engine with AB is the other problem. There are two J-85 engines in crates where I work but their model and flight status is unknown. I don't think anyone has opened the crates since they were received.
Anyway, it was just a concept idea and may prove to be more involved than what I may want to do.
Thanks for sharing your knowledge and input.
Anthony
On Saturday, September 30, 2017 3:16 AM, L29-List Digest Server <l29-list(at)matronics.com> wrote:
Today's complete L29-List Digest can also be found in either of the
two Web Links listed below.  The .html file includes the Digest formatted
of the L29-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2017-09-29&Archive=L29
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2017-09-29&Archive=L29
  L29-List Digest Archive
  Total Messages Posted Fri 09/29/17: 1
Today's Message Index:
1. 07:46 AM - Re: L29 w/ Afterburner (speedy11(at)aol.com (speedy11(at)aol.com))
________________________________ Message 1 _____________________________________
Time: 07:46:59 AM PST US
Subject: Re: L29 w/ Afterburner
Anthony,
It might be a good upgrade for the jet. It would be a much more expensive engine.
Even installing a J-85 without AB would be a nice option. I am not an expert on
the subject, but I have knowledge of both jets so I'll offer an opinion.
The J-85 AB section needs room for the AB to open and close, so that may be an
issue at the engine bay trailing edge. I'm sure you can get measurements from
someone on the dimensions of the AB when in full AB. That would be the limfac
in this situation.
Also, mounting points will likely have to be manufactured. As I recall, the T-38
engine rolls into the fuselage on rails built into the fuselage and then is
secured in place. The T-38 is similar to the L-29 in that the tail section "boat"
is removed to access the engine.
I think such an installation would be very interesting. I hope you can do it.
Stan Sutterfield
Time: 07:33:43 AM PST US
From: Anthony Royal <skyking76t(at)verizon.net (skyking76t(at)verizon.net)>
Subject: L29 w/ Afterburner
Has anyone heard of an L29 with a J85-GE-5 or -5A engine with afterburner i
nstalled?=C2- With 2400 lbs normal thrust and 3600-3850 lbs thrust with a
fterburner, it would seem to be a good fit. Engine dimensions look good to
go but was told the tail pipe might be an issue.=C2- Was told there is/wa
s one L29 with this conversion but gentleman didn't have any specifics.
_-= the many List utilities such as List Un/Subscription,
http://www.m=================
http://wiki.matronics.com====================
http://w======
- The Matronics L29-List Email Forum -
http://www.matronics.com/Navigator?L29-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> L29-List All times are GMT - 8 Hours
