Harv
Posted: Tue Oct 10, 2017 12:55 pm Post subject: CJ cough/miss fire/hesitation in flight |
Gents
Advice sought as I have a slight misfire in flight after 25mins so.
Always seems fine on the ground run up from cold, no mag drop, t's & p's all good. Take off fine but then once in the cruise after above amount of time engine seems to skip a beat and get rougher. Tried leaning, richening, carb heat, fuel primer locked, hotter and cooler cyl head temps all with no difference and my gut feeling is a mag is going bad.
Can this be isolated on the ground via prolonged warm up? I've not tried as yet.
Any ideas sought.
If it's indeed a mag coil then anyone got a source for new ones (should both be changed as a precaution for age)? I've asked Doug but he hasn't any stock.
Are the old ones re build able?
Thanks in advance.
Ernie
Posted: Tue Oct 10, 2017 1:01 pm Post subject: CJ cough/miss fire/hesitation in flight |
Probably a bad coil in the mag.
Ernie
On Tue, Oct 10, 2017 at 4:55 PM, Harv <martin.harvey(at)kbr.com (martin.harvey(at)kbr.com)> wrote:
| Quote: | --> Yak-List message posted by: "Harv" <martin.harvey(at)kbr.com (martin.harvey(at)kbr.com)>
Gents
Any ideas sought.
Thanks in advance.
http://forums.matronics.com/viewtopic.php?p=473443#473443
Posted: Tue Oct 10, 2017 1:10 pm Post subject: CJ cough/miss fire/hesitation in flight |
Bad coil. Typical problem after 20-40 minutes of flight. It takes that long for the heat to permeate the coil. That's when the coil breaks down. Contact George Coy in Swanton, VT. I believe he has them.
Dennis
To: yak-list(at)matronics.com
Sent: Tuesday, October 10, 2017 4:57 PM
Subject: Yak-List: CJ cough/miss fire/hesitation in flight
Gents
Any ideas sought.
Thanks in advance.
http://www.matronics.com/Np; - MATRONICS WEB FORUMS -
<; --> http:/nbsp; - NEW MATRONICS LIST WIKI -matronics.com/" target="_blank">http://wiki.matronics.com
; -Matt Draltp://www.matronics.com/contribution" target="_blank">http://www.matronics==
michael(at)wikstrom.cc Guest
Posted: Tue Oct 10, 2017 1:18 pm Post subject: CJ cough/miss fire/hesitation in flight |
I agree, bad coil. Had similar problem, bought a coil from Richard Goode, installed it and problem fixed.
Cheers
Michael Wikström [iPhone]
Marine Satellite Systems
Les Espaces de Sophia
80 Route des Lucioles
06560 Valbonne
France
Tel: +33 493 958 093
Gsm: +33 607 44 40 11
Fax: +33 493 958 042
Email: michael(at)mssfrance.com (michael(at)mssfrance.com)
Web: www.mssfrance.com
VAT No: FR69347398729
On 10 Oct 2017, at 22:59, Ernest Martinez <erniel29(at)gmail.com (erniel29(at)gmail.com)> wrote:
| Quote: | Probably a bad coil in the mag.
Ernie
Gents
Any ideas sought.
Thanks in advance.
GL
Posted: Tue Oct 10, 2017 1:21 pm Post subject: CJ cough/miss fire/hesitation in flight |
George Coy has them
On Tue, Oct 10, 2017 at 3:55 PM, Harv <martin.harvey(at)kbr.com (martin.harvey(at)kbr.com)> wrote:
Gents
Any ideas sought.
Thanks in advance.
migfighter42(at)gmail.com Guest
Posted: Tue Oct 10, 2017 2:26 pm Post subject: CJ cough/miss fire/hesitation in flight |
It does indeed sound like a coil. I would think M-14P has them.
Red Star Aero Services
| Quote: | On Oct 10, 2017, at 3:55 PM, Harv <martin.harvey(at)kbr.com> wrote:
Gents
Any ideas sought.
Thanks in advance.
GeorgeCoy
Posted: Tue Oct 10, 2017 2:31 pm Post subject: CJ cough/miss fire/hesitation in flight |
I think I have at least one in stock. I can order more. They are new production. Contact off list.
George coy
On Oct 10, 2017, at 5:09 PM, A. Dennis Savarese <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)> wrote:
jackpot
Joined: 13 Jul 2010 Posts: 65 Location: Las Vegas, Nevada
Posted: Tue Oct 10, 2017 4:11 pm Post subject: CJ cough/miss fire/hesitation in flight |
Check the gap on the points. Been there done that. Fixed the problem. This may not be your problem. Remember the gap is in millimeters. Gary. LAS. CJ-22YK
| Quote: | On Oct 10, 2017, at 15:25, Bill Culberson <migfighter42(at)gmail.com> wrote:
> Gents
> Any ideas sought.
> Thanks in advance.
rickkelleyfly(at)gmail.co Guest
Posted: Tue Oct 10, 2017 4:33 pm Post subject: CJ cough/miss fire/hesitation in flight |
Yes could be a coil most like. My was the oil wick had to much oil in it and keep filling the points with oil. Been fine for the last 100 hrs.
Thug
| Quote: | On Oct 10, 2017, at 5:25 PM, Bill Culberson <migfighter42(at)gmail.com> wrote:
> Gents
> Any ideas sought.
> Thanks in advance.
heaysr(at)telus.net Guest
Posted: Tue Oct 10, 2017 8:56 pm Post subject: CJ cough/miss fire/hesitation in flight |
Hello Harv,
I have had the same problem on the M14P in a Yak 55M. Not sure if you are
talking about a Housai. Was your flight at high altitude when you ran into
the problem? Intermittent Mag problems and spark plug problems are worse at
high altitude.
In flight, when the problem occurs, try turning one mag off and see if
engine runs smoothly. Then then switch that one on and the other mag off and
check for smooth running again. If it runs rough or with an occasional
skipping a beat on each mag one by one it's unlikely to be a mag problem as
it's unlikely both mag coils would start to fail simultaneously.
In my case of missing a beat, it was on a freshly overhauled engine and it
turned out to be the pressure carb. They are supposed to be overhauled every
six years when all rubber parts are replaced. I had a spare carb that had
been recently overhauled which I canalized off a second old engine. Swapped
it out and that got rid of the missing beat.
On another more recent occasion, had a slightly rough running engine about 2
hours into a flight at 3000 ft and at 70% RPM . I thought it might be fuel
hanging up in a slightly clogged air vent, but increasing power to 80% to
85% to 90% didn't make it worse or better. The roughness was obvious from
vibration and sound and also from a slightly wavering tach needle. Even
though mags were 3% drop on each at run-up - it happened again the next week
about 1 hour into a flight at 2500 ft. Not nice - it was over water. That
was followed immediately by annual inspection. Plugs were rather sooty -
maybe carb is a bit rich. Nothing else untoward was found. Plugs were
cleaned - haven't has a problem since , albeit, have only done one short
flight and two longer flights of around 1 hour each. So the jury is still
out on that problem, at least until I do a longer flight.
Best regards
Royden
Ernie
Posted: Tue Oct 10, 2017 9:02 pm Post subject: CJ cough/miss fire/hesitation in flight |
Nope. One bad coil will affect both sides. Must be a design flaw but it is a well known fact.
On Wed, Oct 11, 2017 at 12:58 AM Royden Heays <heaysr(at)telus.net (heaysr(at)telus.net)> wrote:
[quote]--> Yak-List message posted by: "Royden Heays" <heaysr(at)telus.net (heaysr(at)telus.net)>
Hello Harv,
high altitude.
Best regards
Royden
nigel.willson(at)yakdispl Guest
Posted: Tue Oct 10, 2017 10:17 pm Post subject: CJ cough/miss fire/hesitation in flight |
Agreed. Same on a 52 from first hand experience. Bad coil affects both mags strangely.
Nigel Willson
Flying Instructor & Examiner | Airshow Organiser | Display Pilot
Tel. 07809 116676
www.yakdisplay.com
On 11 Oct 2017, at 06:01, Ernest Martinez <erniel29(at)gmail.com (erniel29(at)gmail.com)> wrote:
[quote]Nope. One bad coil will affect both sides. Must be a design flaw but it is a well known fact.
Hello Harv,
high altitude.
Best regards
Royden
Harv
Posted: Wed Oct 11, 2017 12:14 am Post subject: Re: CJ cough/miss fire/hesitation in flight |
Thanks for the replies.
This is a Housai and we are fresh out of annual, points are cleaned and gapped, timing set, compressions all good, one new cigar cartridge.
I've had this once before and don't associate it to above works (this is why I think it could be a mag coil) but will check through the items raised.
It's not a particularly nice feeling when it skips for that heart beat but maybe I'll have to fly her again to pinpoint which mag is giving out.
I'll try an increase temp run up first and see if she'll misbehave on the ground (that would be nice)
Will update with findings.
Cheers
Harv
Posted: Wed Oct 11, 2017 12:49 am Post subject: CJ cough/miss fire/hesitation in flight |
It's not worth bothering trying to figure out which mag.
Also beware of "old" new spares. The coils deteriorate on the shelf as well
as "in life".
I replaced mine with brand new in all respects from M14P.
Nigel Willson
Mobile:
+44 (0)7809 116676
Email:
nigel.willson(at)yakdisplay.com
Web:
http://easyppl.com
http://greatbritishairshows.com
http://yakdisplay.com
