skidmk
Joined: 19 Nov 2007 Posts: 171 Location: Ottawa, Ontario
Posted: Fri Oct 13, 2017 6:57 am Post subject: Landing light malfunction |
Hey folks,
returned from a flight the other day and got this:
landing light switch is off, the light stayed deployed and on. As soon as the masterswitch is on, the light will come on (even if the switch is in the off position), the light will not retract. The only way to turn off the landing light is to flip the breaker.
anyone seen this? thoughts?
| - The Matronics L29-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?L29-List |
_________________ Mike "Skidmk" Bourget
Ottawa, Ontario |
migfighter42(at)gmail.com Guest
Posted: Fri Oct 13, 2017 12:41 pm Post subject: Landing light malfunction |
Landing light up micro switch is either improperly adjusted or broken. Pull the light but leave it plugged in and check travel. Adjust or replace as necessary
Bill
N39DE
Quote: | On Oct 13, 2017, at 10:57 AM, skidmk <skidmk(at)gmail.com> wrote:
Hey folks,
Ottawa, Ontario
http://forums.matronics.com/viewtopic.php?p=473502#473502
Dawg
Posted: Fri Oct 13, 2017 2:51 pm Post subject: Landing light malfunction |
I too have that exact problem.
Bill C, with the light extended can we get to the micro switch?
bill g.
Quote: | On Oct 13, 2017, at 14:40, Bill Culberson <migfighter42(at)gmail.com> wrote:
Bill
N39DE
> Hey folks,
> Ottawa, Ontario
_________________ Dawg |
Posted: Fri Oct 13, 2017 8:28 pm Post subject: Landing light malfunction |
No, but if you pull the screws out and let it hang (gently) by the harness, the inspection covers on the sides are easily removed and you can watch what happens as you cycle the switch. Pretty easy to adjust.
Bill
Quote: | On Oct 13, 2017, at 6:49 PM, William Geipel <l129bs(at)gmail.com> wrote:
bill g.
> Bill
> N39DE
> Sent from my iPhone
>> Hey folks,
>> Ottawa, Ontario
Dawg
Posted: Fri Oct 13, 2017 8:30 pm Post subject: Landing light malfunction |
thank you.
Quote: | On Oct 13, 2017, at 22:27, Bill Culberson <migfighter42(at)gmail.com> wrote:
Bill
> bill g.
>> Bill
>> N39DE
>> Sent from my iPhone
>>> Hey folks,
>>> Ottawa, Ontario
>>> Read this topic online here:
skidmk
Posted: Sat Oct 14, 2017 7:00 am Post subject: Re: Landing light malfunction |
Thank you! I'll give it a try this week
Ottawa, Ontario |
skidmk
Posted: Mon Jan 01, 2018 10:07 am Post subject: Re: Landing light malfunction |
Update:
for both aircraft, it turns out the "ground" wire pulled itself loose from the cannon plug. Both are functioning now quite nicely.
Thanks for the hints.
M
Ottawa, Ontario |
N777ZE
Posted: Tue Jan 09, 2018 3:23 pm Post subject: Re: Landing light malfunction |
Ground wire? Mine grounds through the airframe I found.
