davestapa(at)juno.com Guest
Posted: Sat Jul 15, 2006 6:56 am Post subject: Final Inspection |
Second Try (after working on a Kitfox for 8 years I misspelled Kitfox in the Matronics address!)
I'm going through all the paper work for my Final Inspection. I came across a check list on an FAA web site for items I need, and this statement I don't understand: A program letter in accordance with 14 CFR section 21.191(g). Which I looked up and it says:
[*](g) Operating amateur-built aircraft. Operating an aircraft the major portion of which has been fabricated and assembled by persons who undertook the construction project solely for their own education or recreation.
I think this refers to the 51% rule. Where do I get this. I know all Kitfox kits meet this rule. Do I have to prove it? I can't reach the DAR I want to use as he must be out of town. Any help would be appreciated.
C David Estapa
Woodstock, GA
N97DE S5 TD
lcfitt(at)sbcglobal.net Guest
Posted: Sat Jul 15, 2006 7:56 am Post subject: Final Inspection |
David,
The Kitfox complies with the regs. The Kitfox is on the FAA approved list.
Especially if you can document your 8 years. I found that when I had the
inspection, the examiner was very familiar with the Kitfox and it's history.
Lowell
courierboy(at)earthlink.n Guest
Posted: Sat Jul 15, 2006 8:42 am Post subject: Final Inspection |
David -
The document showing that Kitfox satisfies the 51% rule is at:
http://search.google.dot.gov/FAA/FAASearchProcess.asp?ie=&site=DOT_Pages&output=xml_no_dtd&client=DOT_Pages&lr=&proxystylesheet=http%3A%2F%2Fsearch.google.dot.gov%2FFAA%2Ffaa_google.xslt&oe=&faa_only=1&q=REVISED+LISTING+OF+AMATEUR-BUILT+AIRCRAFT+KITS&x=13&y
At top of page click on:
REVISED LISTING OF AMATEUR-BUILT AIRCRAFT KITS
See page 14 for Kitfox.
Bill
(lurking)
| Quote: | Second Try (after working on a Kitfox for 8 years I misspelled
14 CFR section
<http://www.airweb.faa.gov/Regulatory_and_Guidance_Library/rgFAR.nsf/0/A9986A485C9E636386256EDF00510840?OpenDocument>21.191(g).
C David Estapa
Woodstock, GA
N97DE S5 TD
RFor785099(at)aol.com Guest
Posted: Sat Jul 15, 2006 10:06 am Post subject: Final Inspection |
David
Yes its the 51% rule.
I'm still coming up to Ga. This week my home A/C unit gave up after 21 years and I'm trying to get quotes to replace the complete unit inside and outside so my KF is suffering but I did get my new rudder cables installed.
Bob Forrest
bnn(at)nethere.com Guest
Posted: Sat Jul 15, 2006 2:14 pm Post subject: Final Inspection |
At 07:52 AM 7/15/2006, you wrote:
| Quote: | I came across a check list on an FAA web site for items I need, and this
I downloaded one from the EAA site. My DAR had his own, though, and wanted
me to use it. Moral: Talk to your DAR first. (When he gets back from vacation.)
Guy Buchanan
Posted: Sat Jul 15, 2006 6:52 pm Post subject: Final Inspection |
Thanks for the help Guys.
C David Estapa
Woodstock, GA
N97DE S5TD
On Sat, 15 Jul 2006 08:55:10 -0700 "Lowell Fitt" <lcfitt(at)sbcglobal.net>
writes:
David,
approved list.
had the
history.
Lowell
