kearney
Posted: Thu Nov 23, 2017 2:45 pm Post subject: Wiring and going on a diet |
Hi
On my build I decided to use CCA (Copper Clad Aluminium) wire from perihelion designs.
Info and specs on it can be found at:
http://www.periheliondesign.com/fatwires.htm
I am quite surprised at how much lighter it is. Apparently it is used by the big guys (ie AirBus etc) due to the weight savings.
Cheers
Les
C-GCWZ Flying
C-GROK Some assembly required
Dave Saylor
Posted: Thu Nov 23, 2017 4:01 pm Post subject: Wiring and going on a diet |
I’ve been flying with this wire since 2007. 1700 hours and not a single issue. And yes, significantly lighter.
—Dave
On Thu, Nov 23, 2017 at 2:48 PM kearney <kearney(at)shaw.ca (kearney(at)shaw.ca)> wrote:
| Quote: | --> RV10-List message posted by: "kearney" <kearney(at)shaw.ca (kearney(at)shaw.ca)>
Hi
Cheers
Les
C-GCWZ Flying
http://forums.matronics.com/viewtopic.php?p=475481#475481
FORUMS -
WIKI -
b Site -
-Matt Dralle, List Admin.
_________________ --Dave
KWVI |
Kellym
Posted: Thu Nov 23, 2017 5:33 pm Post subject: Wiring and going on a diet |
What do you estimate the weight savings? Perhaps we would do better to
reduce weight of the front seat occupants by say 5 lbs?
On 11/23/2017 4:59 PM, David Saylor wrote:
| Quote: | I’ve been flying with this wire since 2007. 1700 hours and not a single
—Dave
Hi
perihelion designs.
Cheers
Les
C-GCWZ Flying
FORUMS -
WIKI -
b Site -
KCHD |
kearney
Posted: Thu Nov 23, 2017 8:40 pm Post subject: Re: Wiring and going on a diet |
Hi Kelly
What a great idea. Go on a diet and also save weight on the battery cable.
Cheers
Les
riveteddragon(at)gmail.co Guest
Posted: Thu Nov 23, 2017 8:46 pm Post subject: Wiring and going on a diet |
I thought the aluminum wires were more susceptible to work hardening and cracking than he copper ones.
Steve
Bob Turner
Posted: Thu Nov 23, 2017 9:22 pm Post subject: Re: Wiring and going on a diet |
Like others, I’m curious as to how many pounds were saved.
Also, since this wire is fatter, did you have to oversize any bushings to get the wire(s) thru?
_________________ Bob Turner
RV-10 QB |
Dave Saylor
Posted: Thu Nov 23, 2017 9:56 pm Post subject: Wiring and going on a diet |
If you replace 2AWG with "Super 2 CCA" (what I used) from the battery to the firewall, you save about 2 lbs.
I ran the wire up the right side of the fuse, under the door sill, across the panel structure to my GPU plug in front of the left door. I did have to accommodate the larger size. I don't recall any specific adverse issues but like any mod it took more effort.
Perihelion lists specs and discusses work hardening, corrosion, etc. Like I said, my installation has been trouble free for some time.
--Dave
On Thu, Nov 23, 2017 at 9:22 PM, Bob Turner <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)> wrote:
| Quote: | --> RV10-List message posted by: "Bob Turner" <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)>
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=475492#475492
FORUMS -
WIKI -
b Site -
KWVI |
