CJ engine sling
Flibob
PostPosted: Thu Dec 14, 2017 8:39 am    Post subject: CJ engine sling Reply with quote
I am getting ready to install a new (zero time Chinese) engine. What are people using for engine slings. And any words of wisdom on install and run
in.
Thanks Bob
 Filesize:  47.93 KB
 Viewed:  5246 Time(s)
woodja51
PostPosted: Fri Dec 15, 2017 12:00 am    Post subject: Re: CJ engine sling Reply with quote
Wow ... you are lucky to have a zero timed engine ... I would suggest you fully
Depreserve it while its sitting there - oil in Carb , check magnetos clear and correctly put together internally / cigar etc ( take caps off) hot oil into front and rear crankcases , cylinders etc ..check all the screens , check the timing order is 135792468 - the Chinese diagram is slightly wrong and often misrouted no 7 airline .. dress as much as you can before installation as it’s easier than working around mounting frames etc .check the lower intake has the flattened section - or throttle won’t work, check baffles have holes in correct spot for controls blast tubes etc ... much easier to do on stand than airframe .. a bunch of other things might crop up but looks great !
Lancer
PostPosted: Fri Dec 29, 2017 3:45 am    Post subject: Re: CJ engine sling Reply with quote
Where did you pick up this little gem??
You can run but you can't hide
