drfred(at)cox-internet.co Guest
Posted: Sun Jul 16, 2006 1:37 pm Post subject: Duckworks lights. |
Oops!
Put in the wrong fax number
Correct one is : 903 784 7405
Thanks: Fred Williams
I'm working on the slo-build wings. Getting close to section 17 and the
outboard leading edge. I helped a friend install his Duckworks lights
in his RV 6 that he just about has complete. So far, I think I will go
just with the lighting system 6 as is recommended by Vans and place the
landing lights in the wingtips. I would, however, like to cheat a
little and install the nutplates and extra wires in the left wing so
that if I decide to add a duckworks landing light at a later date, most
of the hard work will be done. Could someone who has installed the
duckworks light fax me a copy of the template for the nutplate
locations? I would be much abliged.
Fax; 903 784 3200
See you'all at Oshgosh. Wed thru Sat.
Fred Williams slo-building in Texas
40515
drfred(at)cox-internet.com
