tomcostanza(at)comcast.ne Guest
Posted: Sun Jul 16, 2006 5:56 am Post subject: Landing lights & relays |
What is your opinion of using mechanical relays to implement wig-wag flashing of landing lights?
I would like to use a rotary switch with the following pattern: off, wig-wag, landing, taxi (4 positions). Otherwise I would need to use 3 toggle switches and a complicated switch operation. Using transistors would lower the voltage at the light by about 1.5 volts. To confuse the issue further, I have wingtip landing and taxi lights (1 landing and 1 taxi on each wing) 4 lights total. Using relays would solve my problems, but I don't know the longevity of the relay.
What are your thoughts?
Tom Costanza
RV-7A Fuselage
N1DeltaWhiskey(at)comcast Guest
Posted: Sun Jul 16, 2006 8:45 am Post subject: Landing lights & relays |
Tom,
One way to look at this is that if landing/taxi lights (nor wig/wag) are not required for night flight, so what does it matter if the relay fails? One landing without the benefit of them? I would just get a quality relay and let the longevity concern take care of itself - don't plan to do much night flying anyway.
Do you preflight check all the lights and wig/wag function? (This is rhetorical. If not, then how do you not know whether a light has burned out, a more likely event that losing a relay, I think. I would check light function only if I thought I would have the potential to use them during a flight. Obviously, if you use wig-wag as a safety feature during normal flights, one would check proper operation before takeoff.)
Doug Windhorn
klehman(at)albedo.net Guest
Posted: Sun Jul 16, 2006 10:23 am Post subject: Landing lights & relays |
Not sure how many lights you have Tom. I have a landing light and a taxi
light in both wingtips. Four lamps total. One toggle switch turns on
both landing lights. Another toggle switch turns on both taxi lights. A
third toggle switch selects whether the two taxi lights stay on steady
or wig wag when the taxi lights are on. No relays, diodes, or
transistors. Common cheap toggle switches and an off the shelf cheap
automotive mechancal flasher (OK I guess there is a relay inside the
flasher Seemed pretty simple to me. For daytime operation all I
ever touch is the taxi light switch.
Ken
tomcostanza(at)comcast.net wrote:
| Quote: | What is your opinion of using mechanical relays to implement wig-wag
Tom Costanza
RV-7A Fuselage
Posted: Sun Jul 16, 2006 2:43 pm Post subject: Landing lights & relays |
[b][quote]Doug,That's reasonable as long as the relay doesn't go South every couple months.I don't spend all my time replacing relays. The other concern was RFI.I also don't want to listen to the lights flashing or have them interferewith navigation.Thanks for the reply. If you have any further thoughts, I would be very interested.Regards,Tom Costanza Tom, One way to look at this is that if landing/taxi lights (nor wig/wag) are not required for night flight, so what does it matter if the relay fails? One landing without the benefit of them? I would just get a quality relay and let the longevity concern take care of itself - don't plan to do much night flying anyway. Do you preflight check all the lights and wig/wag function? (This is rhetorical. If not, then how do you not know whether a light has burned out, a more likely event that losing a relay, I think. I would check light function only if I thought I would have the potential to use them during a flight. Obviously, if you use wig-wag as a safety feature during normal flights, one would check proper operation before takeoff.) Regards, Doug Windhorn ---
Posted: Sun Jul 16, 2006 2:49 pm Post subject: Landing lights & relays |
Hi Ken,
That's the configuration I'll have. I started with that approach, but wanted to keep the switch count to a minimum. I guess you pay your money and take your choice. I ordered some spare bulbs and think I'll do an experiment and see what happens.
Tom Costanza
Ken
tomcostanza(at)comcast.net ([email]tomcostanza(at)comcast.net?subject=Re:%20Landing%20lights%20&%20relays&replyto=44BA83C9.9080404(at)albedo.net[/email]) wrote:
I would like to use a rotary switch with the f ollowing pattern: off,
Tom Costanza
RV-7A Fuselage
FLYaDIVE(at)aol.com Guest
Posted: Mon Jul 17, 2006 3:41 am Post subject: Landing lights & relays |
In a message dated 7/16/06 9:58:05 AM Eastern Daylight Time,
tomcostanza(at)comcast.net writes:
flashing
| Quote: | of landing lights?
wig-wag,
| Quote: | landing, taxi (4 positions). Otherwise I would need to use 3 toggle
switches
| Quote: | and a complicated switch operation. Using transistors would lower the
voltage
| Quote: | at the light by about 1.5 volts. To confuse the issue further, I have
wingtip
| Quote: | landing and taxi lights (1 landing and 1 taxi on each wing) 4 lights total.
relay.
Tom Costanza
RV-7A Fuselage
Tom:
My thoughts:
1 - NO Rotary switch.
a> Cost
b> Why the cost? Because it would have to be a heavy duty silver plated
rotary switch.
c> Size probably would be large due to the current handling problem.
2 - Not easy to repair.
3 - If you have a failure on one contact you would have to replace the entire
rotary switch.
4 - You can do it with two toggle switches:
a> A three position switch ... OFF - LANDING LIGHTS - TAXI LIGHTS
When the Taxi lights come on the Landing Lights CAN go off. This would be up
to you and the current handling capability of the alternator.
b> Wig - Wag Switch.
4 - A relay type Wig - Wag system would work, BUT! ! ! You are introducing
a strong point for:
a> Failure - Lots of Opening and Closing of the relay
b> Lots of NOISE - Static, Lots of Opening and Closing of the relay points
causing small arcs.
c> You will need additional filtering and spark suppression for the relay
contacts.
d> You will need to install the relay using plug in sockets.
5 - I would go with a solid state system.
Barry
"Chop'd Liver"
KBelue(at)drs-tem.com Guest
Posted: Mon Jul 17, 2006 4:12 am Post subject: Landing lights & relays |
I have used a three-position switch for: ON, wig-wag, OFF. This controlled a
$19 relay-type wig-wag from Gall's to drive two 100W bulbs. I have used this
for 4.5 yrs, 700 hrs. If it's hazy I leave the wig-wag on for the whole
flight, hours at a time. I have never had any noise, extra filters, and have
never replaced anything.
Kevin
RV-6A
RV-10
[quote] --
N1deltawhiskey(at)comcast Guest
Posted: Mon Jul 17, 2006 6:44 pm Post subject: Landing lights & relays |
Tom,
Keep in mind that I am not a proponent of relays in critical circuits. Having said that, I would not be uncomfortable with your relay circuit proposal for your system. The other thing I would look at is the consequences of the possible failure modes.
It is not clear to me why you would think a relay would go belly up any more frequently than a toggle switch. Junk is junk, but a quality relay should have a similar reliability as a quality switch. Why you would expect more RFI in the relay than in other circuit component? How would a relay interfer with navigation or cause noise in your audio system? A relay is a switch which is electrically activated. Do you have the same concerns about your battery contactors (a relay) or starter relay?
I am using manual switches in my light system and am comfortable with that approach. But I would not exclude or be uncomfortable with the use of relays in this system either.
Regards, Doug
Eric M. Jones
Posted: Sat Jul 22, 2006 7:11 am Post subject: Re: Landing lights & relays |
I sell these by the bushels to RV builders and owners on my website. Please take a look. You can spend less on a Wig-wag, but you can't buy one that is smaller or easier to use.
"No one travelling on a business trip would be missed if he failed to arrive."
- Thorstein Veblen
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
