saolesen(at)sirentel.net Guest
Posted: Fri Jan 05, 2018 7:59 am Post subject: Need GNS 480 and Navworx help |
While doing my annual, I took time to run a wire from my 480 to the Navworx box. I fiddled with the 480 software to set it to the ADS-B out setting and did the same with Navworx to accept the 480 input. I rolled the plane out in to the subzero WI weather to view the GPS satellites and got nothing. The 480 wasn’t talking to the 600B.
I used: P1-6 for serial 3 out at 9600 from the 480
Pin 34 on the 600B
UAT software 4.1
The 480 has the ADS-B out software installed
In the 480 Ground Service Mode, there was no activity showing on Serial 3 in the monitor mode.
Where am I going wrong?
Sheldon Olesen
RV-10 N475PV 791 hrs
Sent from my iPad
rene(at)felker.com Guest
Posted: Fri Jan 05, 2018 8:22 am Post subject: Need GNS 480 and Navworx help |
I do not know about the 480, but I had to connect two wires for the 430.
Pin 34 with the GPS (ads-B out + setting on the 430)
Pin 11 with time "time mark out" from the 430
Set the NAVWORX box to use the ads-b out + from the garmin, do not know what it was labeled as, but I think it was generic and not specific to the 430.
Hope this helps in some way.
Do you have the correct UAT version and date? The is more than one 4.1 floating around.
Rene'
801-721-6080
Posted: Fri Jan 05, 2018 9:56 am Post subject: Need GNS 480 and Navworx help |
Sheldon,
I'm not the 480 expert when it comes to NavWorx - I think that's Phil Yoder (he got the 480 AMOC), but I think you need a timing signal (pins 1-17 and 1-19 on the 480 to pins 2 and 21 on the 600B) as well as the source which is ARINC (pins 5-5 and 5-25 on the 480 to pins 9 and 28 on the 600B)...according to my NavWorx Manual.
Hope this helps,
Ralph
Airdog77
Joined: 24 Nov 2013 Posts: 80 Location: Northern Virginia
Posted: Sat Jan 06, 2018 9:46 am Post subject: Re: Need GNS 480 and Navworx help |
Sheldon,
Just to confirm, when you say that your Quote: | 480 has the ADS-B out software installed | does that mean you have the latest 2.4 software version on your unit?
I ask because I've seen discussions on ADS-B vs ADS-B+ out there, and there seems to be confusion between the two. Version 2.3 will give you ADS-B, but to drive an S-mode transponder for ADS-B you need 2.4.
Again, just double-checking.
Cheers,
Wade
_________________ Airdog
Wade Parton
Building Long-EZ N916WP
www.longezpush.com |
