ceengland7(at)gmail.com Guest
Posted: Mon Feb 05, 2018 8:41 am Post subject: Continuous Squelch Noise With SV-1000 Display On |
On 2/5/2018 10:22 AM, William Hunter wrote:
Quote: | <![endif]--> <![endif]-->
I am getting a continuous squelch type noise when I have one of the Dynon screens receiving ships power.
The Avionics system is two Skyview SV1000 displays, a Dynon radio, a Garmin GTN - 650, and an SL-15 audio panel.
The squelch noise is continuous regardless if the engine is running or not so I have eliminated any noise from the alternator system. And I have also disconnected any battery chargers so that the system is running only on airplane battery. I also turned off all shop lights
When I first fired up the system it sounded like the squelch was activated on a radio meaning the continuous White Noise sound was in the headsets and/ or the overhead speaker however when somebody would talk on the radio the white noise would go away and the transmission would come out completely clear. The nose is loud and is exactly the same sound the radios make when the squelch switch is in the squelch position…so I thought it was the squelch button/switch.
I turned off the Dynon radio and I also turned off the Garmin and the sound continued so those sources of either noise and or squelch were eliminated.
I began pulling all of the circuit breakers out one at a time and the sound continued until I pulled out the circuit breaker that powers the left side Dynon screen. The squelch noise stopped even though the backup battery was powering the display.
Push the circuit breaker in and the noise started again...pull out the CB and the noise stops and the screen stays on using its backup battery power.
So I have confirmed that the only source of noise in the headsets is when the circuit breaker for the left screen is pushed in.
Someone on the Dynon forum suggested that it could be a ground loop. The airplane is a composite and all of the ground wires from the instrument panel go to one copper bus bar near the instrument panel and then from the ground bus I have a 12 AWG wire going to the battery negative cable.
Does anybody have any recommendations for troubleshooting in addition to what I have done thus far?
AS ALWAYS…Thanks for any feedback, experience, and or suggestions!
Cheers!!!
Bill Hunter
| You said 'left side Dynon'. Do you have a pair? If so, can you swap units left/right & repeat the test? If the noise follows the box, then there's likely a defect in the box itself (probably has a 'switcher' power supply inside that's generating the white noise). If the internal backup battery is something lower than 12V, like a 4.5V or 6V battery, that would raise the odds that it's an internal switching type power supply generating the noise.
If the noise doesn't follow the box, then I'd start looking at wiring.
Kellym
Posted: Mon Feb 05, 2018 12:53 pm Post subject: Continuous Squelch Noise With SV-1000 Display On |
I strongly suggest calling Dynon directly. Their tech support is first
rate. Tech support best deals with specific problems over the phone,
while their forum is better for general problems.
The back up battery is 12 V, 12.25 when fully charged.
I have same system, except SL30 and GTN 650, no Dynon radio, and PS Eng
intercom/audio panel.
Quote: | You said 'left side Dynon'. Do you have a pair? If so, can you swap
<https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient&utm_term=icon>
Virus-free. www.avast.com
<https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient&utm_term=link>
<#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
KCHD |
