GTN-650 White Noise
billhuntersemail(at)gmail
PostPosted: Fri Feb 09, 2018 9:07 am    Post subject: GTN-650 White Noise Reply with quote
I have been struggling with a continuous white squelch noise in the headsets regardless of where the SL-15 comm selector switch was selected to the Dynon radio or the Garmin GTN-650 radio.
I called Dynon tech support and they walked me through an internal setting to adjust the squelch through the Skyview display so I no longer am getting white noise from the Dynon. I am still getting white noise from the GTN-650.
Does anyone  know of an internal squelch adjustment in the GTN?
Bill Hunter
cluros(at)gmail.com
PostPosted: Fri Feb 09, 2018 9:32 am    Post subject: GTN-650 White Noise Reply with quote
Setup Page
Com Configuration
Com RF Squelch
On Fri, Feb 9, 2018 at 9:06 AM, William Hunter <billhuntersemail(at)gmail.com (billhuntersemail(at)gmail.com)> wrote:
Bill Hunter
PostPosted: Fri Feb 09, 2018 9:53 am    Post subject: GTN-650 White Noise Reply with quote
Thanks a lot!!!
Bill Hunter
On Feb 9, 2018 9:37 AM, "Sebastien" <cluros(at)gmail.com (cluros(at)gmail.com)> wrote:
Setup Page
Com Configuration
Com RF Squelch
Bill Hunter
cbirdsall6(at)cox.net
PostPosted: Fri Feb 09, 2018 4:33 pm    Post subject: GTN-650 White Noise Reply with quote
If you have a newer (post 2013) unit, Try starting at a level of at least 75. Sounds really high but Garmin changed the way the squelch was mapped in late 2013, and a setting of 75 puts the   squelch at the “original” 0 setting.
Chuck
On Feb 9, 2018, at 11:52, William Hunter <billhuntersemail(at)gmail.com (billhuntersemail(at)gmail.com)> wrote:
Thanks a lot!!!
Bill Hunter
Setup Page
Com Configuration
Com RF Squelch
Bill Hunter
PostPosted: Fri Feb 09, 2018 5:24 pm    Post subject: GTN-650 White Noise Reply with quote
Thanks everyone for your help!!!  I am always amazed at the knowledge base on this forum!!!
Cheers!!!
Bill  Hunter
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Chuck Birdsall
Sent: Friday, February 9, 2018 4:33 PM
Subject: Re: GTN-650 White Noise
Chuck
Thanks a lot!!!
Bill Hunter
Setup Page
Com Configuration
Com RF Squelch
Bill Hunter
