		kearney
				 Posted: Sat Feb 24, 2018 7:12 pm    Post subject: Standby Alternator |
				Hi
 I am planning to use a B&C alternator as a backup mounted on the vacuum pad of my engine.
 Has anyone used a B&C BC462-3H alternator. I am interested in confirming that it will fit on the back of the engine. As I will be using a 90 degree oil filter adapter I will also be using the required spacer.
 Cheers
 Les
 C-GCWZ Flying
 C-GROK Somewhat less assembly required
		bcondrey
				 Posted: Sat Feb 24, 2018 7:26 pm    Post subject: Standby Alternator |
				Les,
 Call them or email B&C direct to check.  Using their Oil Filter Adapter (needs a spacer to clear the engine mount) with either their old SD-20 or their current BC410H there was a requirement for a spacer on the alternator also.
 On Sat, Feb 24, 2018 at 9:16 PM kearney <kearney(at)shaw.ca (kearney(at)shaw.ca)> wrote:
  	  | Quote: | 	 		  --> RV10-List message posted by: "kearney" <kearney(at)shaw.ca (kearney(at)shaw.ca)>
  Hi
  Cheers
  Les
  C-GCWZ Flying
  http://forums.matronics.com/viewtopic.php?p=478239#478239
		kearney
				 Posted: Sun Feb 25, 2018 5:49 am    Post subject: Re: Standby Alternator |
				Hi Bob
 I did speak to TJ at B&C yesterday. He was most helpful in deciding which alternator would be best for my application. He also spoke about the spacers.
 I just wanted to see if anyone else has done this and find out what, if any, issues they ran into.
 Cheers
 Les
		rjones560xl@gmail.com
  Joined: 29 Jul 2015 Posts: 64 Location: Las Vegas, NV
				 Posted: Sun Feb 25, 2018 7:29 am    Post subject: Standby Alternator |
				Are you using the Lycoming horizontal adapter?  If so that alternator won’t fit. However it will work with the B&C 90 degree adapter. Just check there sight or call them. They are very knowledgeable and helpful. I have the BC-410H on my 540 and it fits fine with the B&C 90 degree oil filter adapter.
 Robert Jones
  	  | Quote: | 	 		   On Feb 24, 2018, at 20:12, kearney <kearney(at)shaw.ca> wrote:
  Hi
  Cheers
  Les
  C-GCWZ Flying
  _________________ Robert J Jones
702-521-1840 |
		rvdave
		kearney
				 Posted: Tue Feb 27, 2018 6:23 pm    Post subject: Re: Standby Alternator |
				Hi
 I spoke to B &C again after conforming which oil filter adapter my engine builder would be using - it is from B&C . Here is what I received from B&C via email:
 If memory serves, your IO-540 will be going in an RV-10; and with that in mind, here is what would be needed:
                BC700-H Oil Filter Adapter
                FK502-1.4 OFA Spacer Kit (1.4”)
                BC462-3H Alternator
                FK710-1.25 Alternator Drive Extension/Spacer Kit (1.25”)
 Regarding your questions:  yes, there are indeed two “spacers” involved – a 1.4” spacer for the BC700-H Oil Filter Adapter, so that it clears the RV-10 engine mount, and a 1.25” drive extension/spacer for the BC462-3H Alternator, so that it clears the Oil Filter Adapter.  As I might have mentioned on the phone, the above makes for a tight installation … but it should space everything out so that the interferences are negotiated.
 Cheers
 Les
		rvdave
				 Posted: Tue Feb 27, 2018 6:42 pm    Post subject: Re: Standby Alternator |
				Sounds like you’re getting exactly what you need.
  _________________ Dave Ford
Cadillac, MI |
		dmaib(at)mac.com Guest
				 Posted: Tue Feb 27, 2018 6:44 pm    Post subject: Standby Alternator |
				Back in 2008, when I was trying to figure out how to fit the SD-20 alternator and the oil filter, I tried every combination I could find and could not make it work. I had more than one conversation with B&C. They were very helpful and even suggested I look at competitors oil filter spacers when we could not get the B&C to fit. I suspect that the alternator drive extension was not available back in those days. I ended up putting my oil filter on the firewall with the Airwolf system and have always been grateful that things worked out as they did. Oil changes are a breeze with the Airwolf remote oil filter.
 David Maib
 40559
 On Feb 27, 2018, at 9:23 PM, kearney <kearney(at)shaw.ca> wrote:
 Hi
               FK502-1.4 OFA Spacer Kit (1.4â)
               BC462-3H Alternator
               FK710-1.25 Alternator Drive Extension/Spacer Kit (1.25â)
 Regarding your questions:  yes, there are indeed two âspacersâ involved â a 1.4â spacer for the BC700-H Oil Filter Adapter, so that it clears the RV-10 engine mount, and a 1.25â drive extension/spacer for the BC462-3H Alternator, so that it clears the Oil Filter Adapter.  As I might have mentioned on the phone, the above makes for a tight installation ⦠but it should space everything out so that the interferences are negotiated.
 Cheers
 Les
 http://forums.matronics.com/viewtopic.php?p=478304#478304
