Fuel valve siphoning across?
philperry9
PostPosted: Sun Jun 10, 2018 3:02 pm    Post subject: Fuel valve siphoning across? Reply with quote
I had a first time experience this weekend. We flew into Tradewind airport (Amarillo) for the weekend and I parked the airplane on a ramp that was slightly sloped.
Topped off the tanks, tied it down, and left it for a few days.
We got ready to leave today and I popped open the uphill-most tank to inspect fuel levels and a good amount of fuel had disappeared. My first thought was that it was stolen.
The downhill tank was full to the rim and dripping fuel at the vent. Judging from the stains, it appears fuel was dripping out of the vent the entire weekend.
So, apparently I was cross feeding fuel from the uphill tank to the downhill tank, then from the downhill tank out the vent line to the ground.
I topped off the uphill tank with 2.8 gal. When full, the vent on that tank dripped fuel, so I knew it’s was not blocked.
The only path would be leakage inside the andair fuel valve body.
I have always left the fuel valve on the last tank used, as opposed to moving it to the off position. It just seems safer that way as it’s one less thing to miss that could kill you.
Here’s the question, have any of you see siphoning across the andair fuel selector valve in the -10? Is that normal or am I dealing with a leaky valve?
Phil
rleffler
PostPosted: Sun Jun 10, 2018 3:21 pm    Post subject: Fuel valve siphoning across? Reply with quote
I would have thought that to be physically impossible.
Even with a tank selected, the fuel path is to the engine, not the other tank.
Keep us posted on what you find.
Get Outlook for iOS
From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com> on behalf of Phillip Perry <philperry9(at)gmail.com>
Sent: Sunday, June 10, 2018 7:00:22 PM
Subject: Fuel valve siphoning across?
--> RV10-List message posted by: Phillip Perry <philperry9(at)gmail.com>
I topped off the uphill tank with 2.8 gal. When full, the vent on that tank dripped fuel, so I knew its was not blocked.
I have always left the fuel valve on the last tank used, as opposed to moving it to the off position. It just seems safer that way as its one less thing to miss that could kill you.
Heres the question, have any of you see siphoning across the andair fuel selector valve in the -10? Is that normal or am I dealing with a leaky valve?
Phil
Email Forum -
-List">http://www.matronics.com/Navigator?RV10-List
p; - MATRONICS WEB FORUMS -
ums.matronics.com
p; - NEW MATRONICS LIST WIKI -
matronics.com
p; -Matt Dralle, List Admin.
Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler
carl.froehlich(at)verizon
PostPosted: Sun Jun 10, 2018 3:40 pm    Post subject: Fuel valve siphoning across? Reply with quote
If you leave a 90 degree throw Andair fuel valve in between the left and right tank, it will (somewhat) cross connect the tanks.
Carl
On Jun 10, 2018, at 4:19 PM, Bob Leffler <bob(at)thelefflers.com (bob(at)thelefflers.com)> wrote:
Get Outlook for iOS
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) <owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)> on behalf of Phillip Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)>
--> RV10-List message posted by: Phillip Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)>
Phil
Email Forum -
ums.matronics.com
matronics.com
neilekins(at)aol.com
PostPosted: Sun Jun 10, 2018 3:43 pm    Post subject: Fuel valve siphoning across? Reply with quote
Yes I believe I have also. Tank levels get different depending on how plane is parked. I always Shut valve off now. Neil
Phil
philperry9
PostPosted: Sun Jun 10, 2018 5:14 pm    Post subject: Fuel valve siphoning across? Reply with quote
This one was in the detent, but I highly suspect it was leaking between the ports in the valve body housing.
On Jun 10, 2018, at 6:38 PM, Carl Froehlich <carl.froehlich(at)verizon.net (carl.froehlich(at)verizon.net)> wrote:
Carl
Get Outlook for iOS
Phil
Email Forum -
ums.matronics.com
matronics.com
Lenny Iszak
PostPosted: Sun Jun 10, 2018 5:34 pm    Post subject: Fuel valve siphoning across? Reply with quote
Was it hot outside? I live in Florida and this happens to me often. The plane is red and black, fuel in the tank gets hot, expands and just drips out the vents.
Lenny
On Jun 10, 2018, at 6:38 PM, Carl Froehlich <carl.froehlich(at)verizon.net> wrote:
> Carl
>> Get Outlook for iOS
>> To: rv10-list(at)matronics.com
>> Phil
>> Sent from my iPhone
>> Email Forum -
>> ums.matronics.com
>> matronics.com
>> http://www.matronics.com/contribution
Lenny Iszak
Palm City, FL
2014 RV-10, N311LZ - 500 hrs
PostPosted: Mon Jun 11, 2018 2:41 am    Post subject: Fuel valve siphoning across? Reply with quote
I’m in Florida also. Yes it happens to me to. I thought I was crazy. Couldn’t figure how that can work. My fuel pulls from the side I want when on left or right. But it will go to other side while sitting in hot hangar. I’m in Florida also
On Jun 10, 2018, at 9:32 PM, Lenny Iszak <lenard(at)rapiddecision.com> wrote:
Lenny
> Sent from my iPhone
>> Carl
>>> Get Outlook for iOS
>>> Phil
>>> Sent from my iPhone
>>> Email Forum -
>>> ums.matronics.com
>>> matronics.com
