echristley(at)att.net Guest
Posted: Thu Jun 14, 2018 11:39 am Post subject: Removing Pins from High Density D-Sub Connector |
Push the tool over the pin.
Push the pin into the tool from the backside of the connector and hold it there.
Push the tool over the pin again.
Gently pull the wire.
If it doesn't come out, reseat the tool, then push the wire back in harder while pushing the tool in harder. You have to get the pin to slide into the tool just a bit (and there is less than a bit of playroom to work with.).
On Thursday, June 14, 2018 10:50 AM, Roger Curtis <rnjcurtis(at)charter.net> wrote:
Art, I assume you are using the correct tool since the high-density and regular D connector use different tools
Sent from my Verizon Wireless 4G LTE smartphone
Date: 06/14/2018 10:42 (GMT-05:00)
Subject: Removing Pins from High Density D-Sub Connector
Folks,
It's not my fault... I'm sure that the pins moved by themselves in the middle of the night... but some of the pins in my high density D-Sub connector are in the wrong places.
I have the right tool: https://www.steinair.com/product/insertionremoval-tool-for-high-density-d-sub-pins-mil-spec/
I have successfully removed regular density pins from DB-25 connectors.
These darned high-density pins refuse to come loose.
Before I make things worse, do you have any suggestions?
-- Art Z.
https://CheerfulCurmudgeon.com/"We do not see the world as it is. We see the world as we are."
