				|  | Matronics Email Lists Web Forum Interface to the Matronics Email Lists
		| Author | Message |
		| rparigor(at)suffolk.lib.n Guest
				|  Posted: Mon Jul 17, 2006 8:26 am    Post subject: PPG to prime fiberglass? |   |
				| How did those prime Europa airframe with PPG primer?
What was post cure time and sandpaper used after fill?
 What PPG primer?
 PPG literature states that DPLF Epoxy Primer and K-36 can be applied over
 fiberglass.
 After talking to technical support, their stance is "fiberglass", means
 fiberglass with gel coat on it. They do not support apply of their primers
 over raw fiberglass.
 She said that if you apply K-36 over raw fiberglass, there is a good
 chance that seep in will cause problems.
 Unofficial from PPG, a good starting point would be to apply DPLF Epoxy
 primer at least 1.2 to 1.5 mil thick, wait 4 or 5 days, sand then apply
 K-36.
 An Autobody guy said he puts a thin coat of DPLF on Corvettes he works on,
 then lets cure for 1 day, then applies K-36 over DPLF without sanding.
 I plan to fill with Aeropoxy and Expancel, and top coat with PPG DCC.
 Ron Parigoris
 | |  |  | - The Matronics Europa-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Europa-List
		| Back to top |  |
		| europa flugzeug fabrik
				|  Posted: Mon Jul 17, 2006 1:40 pm    Post subject: Re: PPG to prime fiberglass? |   |
				|  	  | rparigor(at)suffolk.lib.n wrote: |  	  | After talking to technical support, their stance is "fiberglass", means fiberglass with gel coat on it. They do not support apply of their  apply of their primers over raw fiberglass.
 Gelcoat is resin, either epoxy or polyester.  On many Europa molded parts, no gelcoat per se, but the molding process leaves a thin resin coating on the outside.
 We don't use raw fiberglass, whatever that means. If you sand down excessively and cut into fibers, which is bad anyway, there will be problems when coating.
 Fred F.
		| Back to top |  |
		| hagargs(at)earthlink.net Guest
				|  Posted: Mon Jul 17, 2006 6:08 pm    Post subject: PPG to prime fiberglass? |   |
				| I used the K-36 over UV smooth prime to seal it and am going to do my
flyoff in this condition.  The coating was good and it stayed pretty
 smooth.  I used a HVLP gun and did not have good luck with it.  However
 going to a normal spray gun led to better results.  I did have a good deal
 of sanding to do but that was due to me having 4 thumbs when dealing with a
 spray gun.  The  sanding left me with an entirely acceptable finish.  I
 believe I used grits between 360 and 600 both wet and dry.
 Steve Hagar
 A 143  N40SH
 Expect to fly within a week
 Steve Hagar
  	  | Quote: |  	  | [Original Message] From: <rparigor(at)suffolk.lib.ny.us>
 To: <europa-list(at)matronics.com>
 Date: 7/17/2006 9:40:48 AM
 Subject: PPG  to prime fiberglass?
 What PPG primer?
  	  | Quote: |  	  | PPG literature states that DPLF Epoxy Primer and K-36 can be applied over fiberglass.
 K-36.
 Ron Parigoris
		| Back to top |  |
 | You cannot post new topics in this forum You cannot reply to topics in this forum
