Hinge Failure Video
GalinHdz
PostPosted: Thu Jun 21, 2018 6:33 pm    Post subject: Hinge Failure Video Reply with quote
I made a short video of my KIS4 hinge failure and how to inspect it. You can view it at:
https://www.youtube.com/watch?v=9rVUYrrd7VE
mike(at)vision499.com
PostPosted: Thu Jun 21, 2018 6:44 pm    Post subject: Hinge Failure Video Reply with quote
Hello Galin,
Thanks for doing this, just amazing how much wear there was.
From: owner-kis-list-server(at)matronics.com [mailto:owner-kis-list-server(at)matronics.com] On Behalf Of Galin Hernandez
Sent: June 21, 2018 7:33 PM
To: kis-list(at)matronics.com
Subject: Hinge Failure Video
pastormac62
PostPosted: Fri Jun 22, 2018 2:22 am    Post subject: Hinge Failure Video Reply with quote
Thank you!!
To our success, Stephen McIntosh
On Jun 21, 2018, at 10:32 PM, Galin Hernandez <galinhdz(at)gmail.com (galinhdz(at)gmail.com)> wrote:
Robert Reed
PostPosted: Fri Jun 22, 2018 4:26 am    Post subject: Hinge Failure Video Reply with quote
Galin
One thing that I am not clear on is how the hinge actually failed. Did the worn tabs all fail or did the loosened hinge pin fall out?
I know that I was paranoid and did an overkill on all of my hinges by doubling the length and additional screws but the idea of just crimping the end to retain the pins didn’t appeal to me as being the right choice. I added a small tab to on end of each hinge with a small hole that a bolt could be inserted. Each hinge pin has a 90 degree bend and a loop that aligns with the tab. I put a small bolt through with lock nut after installing. I couldn’t get the bolt into a couple of them so I used safety wire to tie them in place. The hinge pins can’t come out no matter how loose the hinge.
Bob Reed
On Jun 21, 2018, at 9:32 PM, Galin Hernandez <galinhdz(at)gmail.com (galinhdz(at)gmail.com)> wrote:
=================================== //www.matronics.com/Navigator?KIS-List =================================== cs.com =================================== om =================================== matronics.com/contribution ===================================
aeromomentum(at)yahoo.com
PostPosted: Fri Jun 22, 2018 4:31 am    Post subject: Hinge Failure Video Reply with quote
This sort of play should really be seen even on a preflight inspection let alone an annual inspection.
GalinHdz
PostPosted: Fri Jun 22, 2018 2:31 pm    Post subject: Hinge Failure Video Reply with quote
Bob; There was no indication of the actual hinge failing except the insides being worn out. Then there is the fact the pin was nowhere to be found. Otherwise the hinge looked normal. It fell out. If it would have been one long hinge, the entire rudder would have failed catastrophically and I would have been in real doggie do-do. But since it had two hinges, the second hinge held long enough to safely land the airplane. That is why I decided to add a 3rd hinge instead of making one super long hinge.
On Fri, Jun 22, 2018 at 8:26 AM, Robert Reed <robertr237(at)att.net (robertr237(at)att.net)> wrote:
Galin
Bob Reed
========== //www.matronics.com/Navigator?KIS-List ========== cs.com ========== om ========== matronics.com/contribution ==========
Robert Reed
PostPosted: Fri Jun 22, 2018 2:46 pm    Post subject: Hinge Failure Video Reply with quote
Galin
That is what I suspected, the loosened pin was not locked in and fell out the bottom of the hinge. The way the original instructions said to secure the pin just never seemed right to me.
Bob Reed
On Jun 22, 2018, at 5:30 PM, Galin Hernandez <galinhdz(at)gmail.com (galinhdz(at)gmail.com)> wrote:
Galin
Bob Reed
