GalinHdz
Posted: Fri Jun 22, 2018 2:34 pm Post subject: How do you remove the flaps? |
Can anybody post a step-by-step method to remove the flaps on a KIS4?
Robert Reed
Joined: 22 Oct 2009 Posts: 331 Location: Dallas/Ft.Worth
Posted: Fri Jun 22, 2018 2:52 pm Post subject: How do you remove the flaps? |
Disconnect the connection from handle to flap control arm then lower the flaps by hand until control arms slip out if the channel at end of flaps. Once flaps are fully down the hinges should be accessible.
(My assumption was manual flaps. In my case I disconnect the flap motor and lower flaps. )
Bob Reed
| Quote: | On Jun 22, 2018, at 5:33 PM, Galin Hernandez <galinhdz(at)gmail.com> wrote:
GalinHdz
Posted: Fri Jun 22, 2018 4:42 pm Post subject: How do you remove the flaps? |
THANKS! The flap hinges are in excellent shape but, since I have new ones, I am going to replace them anyways.
On Fri, Jun 22, 2018 at 6:51 PM, Robert Reed <robertr237(at)att.net (robertr237(at)att.net)> wrote:
| Quote: | --> KIS-List message posted by: Robert Reed <robertr237(at)att.net (robertr237(at)att.net)>
Bob Reed
> On Jun 22, 2018, at 5:33 PM, Galin Hernandez <galinhdz(at)gmail.com (galinhdz(at)gmail.com)> wrote:
List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?KIS-List
mike(at)vision499.com Guest
Posted: Fri Jun 22, 2018 8:11 pm Post subject: How do you remove the flaps? |
For a while there I could not understand the problem.
Then I realised I put nut plates on all my hinges, this makes it a breeze to remove and replace them, you only have to get to one side. I put a piece of weed eater nylon through 2 holes on the hinge and then through the holes in the wing and pull it together with one hand and put the screws in with the other. Also explains why I’m not in the air yet.
Try these screws https://www.microfasteners.com/fcmxs0808-8-32-x-1-2-t15-100-degree-flat-head-6-lobe-drive-machine-screws-stainless.html
Keep well
From: owner-kis-list-server(at)matronics.com [mailto:owner-kis-list-server(at)matronics.com] On Behalf Of Galin Hernandez
Sent: June 22, 2018 5:42 PM
To: kis-list(at)matronics.com
Subject: Re: How do you remove the flaps?
On Fri, Jun 22, 2018 at 6:51 PM, Robert Reed <robertr237(at)att.net (robertr237(at)att.net)> wrote: | Quote: |
Bob Reed
| Quote: | On Jun 22, 2018, at 5:33 PM, Galin Hernandez <galinhdz(at)gmail.com (galinhdz(at)gmail.com)> wrote:
fredorosa(at)gmail.com Guest
Posted: Sat Jun 23, 2018 4:08 am Post subject: How do you remove the flaps? |
Too bad the hinges aren’t made of titanium. Then you wouldn’t have to change them.
Al
On Jun 23, 2018, at 12:10 AM, <mike(at)vision499.com (mike(at)vision499.com)> <mike(at)vision499.com (mike(at)vision499.com)> wrote:
| Quote: | <![endif]--> <![endif]-->
Keep well
From: owner-kis-list-server(at)matronics.com (owner-kis-list-server(at)matronics.com) [mailto:owner-kis-list-server(at)matronics.com (owner-kis-list-server(at)matronics.com)] On Behalf Of Galin Hernandez
Bob Reed
GalinHdz
Posted: Sat Jun 23, 2018 2:56 pm Post subject: How do you remove the flaps? |
Bob, I followed your notes and it worked perfectly. The flap hinges are in such perfect shape I am not even going to replace them. But now I know how to do it. THANKS!
On Sat, Jun 23, 2018 at 8:08 AM, Alfred Rosa <fredorosa(at)gmail.com (fredorosa(at)gmail.com)> wrote:
Al
Keep well
Subject: Re: KIS-List: How do you remove the flaps?
Bob Reed
Virus-free. www.avast.com [url=#m_1148182270651327034_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2] [/url]
Robert Reed
Posted: Sat Jun 23, 2018 5:18 pm Post subject: How do you remove the flaps? |
Galin
Glad that I could be some help to you.
I am making progress and I think I see a glimmer of light at the end of the tunnel. I had the engine removed, torn down and inspected. After almost 15 years of storage the only problems found were dried seals and the preservation oil had gummed up. They are supposed to remount the engine next week. Following that I just have about 40 hours of wiring to finish.
Oh and I still have to purchase the Dynon Skyview system and all the com system but I have prepared everything for just dropping them in. I am guessing that about 100 hours work remain before DAR inspection and first flight.
Bob Reed
On Jun 23, 2018, at 5:54 PM, Galin Hernandez <galinhdz(at)gmail.com (galinhdz(at)gmail.com)> wrote:
| Quote: | Bob, I followed your notes and it worked perfectly. The flap hinges are in such perfect shape I am not even going to replace them. But now I know how to do it. THANKS!
Al
Keep well
Bob Reed
