Battery independent power supply for Rotax 914 fuel pumps
rlborger(at)mac.com
PostPosted: Sat Jul 14, 2018 7:03 am    Post subject: Battery independent power supply for Rotax 914 fuel pumps Reply with quote
Roland,
I will be very interested in your efforts to provide a backup power supply for the electric pump(s). The product looks quite interesting. Please keep us posed as to how it works and how well it works.
Blue skies & tailwinds,
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop (130 hrs).
Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP, Hercules Prop.
3705 Lynchburg Dr.
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com
On Jul 13, 2018, at 2:55 AM, Roland <schmidtroland(at)web.de> wrote:
There's a new product from Silent Hektik for a battery independent supply of electric power for the fuel pumps https://www.silent-hektik.de/UL_914_Pumpe.htm of the Rotax 914.
I'm planning to install that (weights only 200 grammes) to overcome the problem, that you lose the engine in the event of a battery or regulator failure. Also I have a LiFePo battery installed, which is great for cranking the starter but I'm not so sure, how long the electric fuel pump will run with it.
It's just a very clever backup I think.
Roland
PH-ZTI
XS TG 914
