Posted: Tue Jul 17, 2018 7:56 pm Post subject: Battery independent power supply for Rotax 914 fuel pumps |
For sure....mine is like that because its a base model 912 and came like that.
That said i do like the fact that the engine is not electrically dependant.
William Daniell
LONGPORT
+57 310 295 0744
On Tue, Jul 17, 2018, 03:38 Roland <schmidtroland(at)web.de (schmidtroland(at)web.de)> wrote:
| Quote: | --> Europa-List message posted by: "Roland" <schmidtroland(at)web.de (schmidtroland(at)web.de)>
Hi Will,
yours is an interesting solution for sure, but I think, that the Silent Hektik product is an inexpensive, light and easy way if you have a standard Rotax 914 already.
Roland
PH-ZTI
XS TG 914
http://forums.matronics.com/viewtopic.php?p=481688#481688
pa-List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?Europa-List
Roland
Posted: Tue Jul 17, 2018 8:31 pm Post subject: Re: Battery independent power supply for Rotax 914 fuel pum |
Hello Will,
to be independent of electricity is indeed a big advantage. However there are few modern engines (Rotax iS, Continental CD 155 Diesel, car engines....) which aren't.
As far as I know there was only one (documented) electrical related accident in Switzerland with a Rotax 914 powered MCR01, which didn't have a standard setup if my memory serves.
That said, it's of course always better to have redundancy (other than just the battery), especially in a plane and that is why I'll go for the Silent Hektik product.
Roland
PH-ZTI
XS TG 914
Posted: Wed Jul 18, 2018 12:27 am Post subject: Battery independent power supply for Rotax 914 fuel pumps |
Wiliam/Roland,
I have suffered a rectifier failure part way across a long N Sea crossing but had plenty of battery to get me home. I have also demonstrated that it (ie a 914) works perfectly well if you switch off alternator and master switch in the standard wiring scheme. So personally I would go for the KISS and keep it light principles. Regards, David Joyce, GXSDJ
On 2018-07-17 22:23, William Daniell wrote: | Quote: | For sure....mine is like that because its a base model 912 and came like that.
That said i do like the fact that the engine is not electrically dependant. William DaniellLONGPORT+57 310 295 0744
| Quote: | | --> Europa-List message posted by: "Roland" <schmidtroland(at)web.de (schmidtroland(at)web.de)> Hi Will, yours is an interesting solution for sure, but I think, that the Silent Hektik product is an inexpensive, light and easy way if you have a standard Rotax 914 already. Regards Roland PH-ZTI XS TG 914 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=481688#481688 =========== pa-List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?Europa-List =========== FORUMS - eferrer noreferrer" target="_blank">http://forums.matronics.com =========== WIKI - errer noreferrer" target="_blank">http://wiki.matronics.com =========== b Site - -Matt Dralle, List Admin. rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/contribution =========== |
Roland
Posted: Wed Jul 18, 2018 12:44 am Post subject: Re: Battery independent power supply for Rotax 914 fuel pum |
David,
I'd always agree concerning the KISS - generally. But this is a safety feature with a weight penalty of just 0,2kg. You have a Smart Ass installed, right? You have a complex 914 instead of a much more simple 912....
With the standard wiring I switched off the alternator master on the ground and the engine started cauthing after some time, maybe due to the low RPM.
To each his own....
Roland
PH-ZTI
XS TG 914
Posted: Wed Jul 18, 2018 5:17 am Post subject: Battery independent power supply for Rotax 914 fuel pumps |
Actually I think we worry too much about this.
When was the last time you had a (modern) car stop once it was running? I cant remember this ever happening to me and I have some pretty ropy cars. I once had a BMW R75/6 stop because the capacitor failed but apart from that I cant think of a single instance of an internal combustion engine stopping once it was running - including a wide variety of tanks, motorbikes cars etc in nigh on 40 years of driving.
Come to think of it I cant remember any of my parents cars stopping once they were running - ah yes once when the fuel filter was almost blocked.
Normally if they start and you feed them they continue to run.
Will
William Daniell
LONGPORT
+57 310 295 0744
On Wed, Jul 18, 2018 at 12:31 AM, Roland <schmidtroland(at)web.de (schmidtroland(at)web.de)> wrote:
Hello Will,
As far as I know there was only one (documented) electrical related accident in Switzerland with a MCR01, which didn't have a standard setup if my memory serves.
Roland
PH-ZTI
XS TG 914
http://forums.matronics.com/viewtopic.php?p=481720#481720
Posted: Thu Jul 19, 2018 6:48 am Post subject: Battery independent power supply for Rotax 914 fuel pumps |
hahahahaha
good point. Do you remember the old Mike Hailwood 900SS desmo?
William Daniell
LONGPORT
+57 310 295 0744
On Thu, Jul 19, 2018 at 5:10 AM, ami-mcfadyean(at)talktalk.net (ami-mcfadyean(at)talktalk.net) <ami-mcfadyean(at)talktalk.net (ami-mcfadyean(at)talktalk.net)> wrote:
Did those cars/bikes have Ducatti electrics?
Duncan Mcf
do not archive.
----Original Message----
From: wdaniell.longport(at)gmail.com (wdaniell.longport(at)gmail.com)
Date: 18/07/2018 15:16
To: <europa-list(at)matronics.com (europa-list(at)matronics.com)>
Subj: Re: Re: Battery independent power supply for Rotax 914 fuel pumps
Will
William Daniell
LONGPORT
+57 310 295 0744
Hello Will,
Roland
PH-ZTI
XS TG 914
