apatton2
Posted: Tue Sep 11, 2018 8:52 pm Post subject: Yak-50 rust in air system / MLG actuator |
Hi List,
Awhile back I wrote the list mentioning that there was rust-colored dust coming out of my landing gear selector valve handle.
The (relative) good news is that we've located the rust in a rusty actuator. Which leads me to 2 questions:
1) Does anyone sell replacement parts for the Yak-50 MLG actuator? We believe the rusted part is repairable but if a spare were available that's probably an easier solution. I have pics of the parts that I can provide if needed.
2) As the rusty dust has traveled from the MLG actuator all the way through the selector valve, there's some level of dust contamination in the system. Are there any recommendations on what to use to clean the air system out? Or is this not recommended?
Many thanks for any wisdom,
Andrew
_________________ Andrew Patton
Yak-50
San Francisco, CA |
HawkerPilot2015
Posted: Wed Sep 12, 2018 7:48 am Post subject: Re: Yak-50 rust in air system / MLG actuator |
Mike at Superfinishers in AZ made the end caps for my 50's actuators...back in 2006 or so. They were a 1000 times better than the OEM parts. He also has/had a 50. He might be able to help you out for future needs.
http://superfinishersinc.com/
apatton2
Posted: Mon Sep 17, 2018 7:57 am Post subject: Re: Yak-50 rust in air system / MLG actuator |
Thanks! Yep, in touch with Mike now.
Also Doug Sapp recommended a "Final Filter" to be added in front of the landing gear selector valve to filter out any foreign matter that we're going to try installing.
Yak-50
San Francisco, CA |
pennington.construction.i Guest
Posted: Mon Sep 17, 2018 8:13 am Post subject: Yak-50 rust in air system / MLG actuator |
BIG Thumbs up on the final filter.
Doug educated me in this as well. Glad I did.
Mark
On Mon, Sep 17, 2018 at 12:05 PM apatton2 <apatton(at)alumni.princeton.edu (apatton(at)alumni.princeton.edu)> wrote:
Quote: | --> Yak-List message posted by: "apatton2" <apatton(at)alumni.princeton.edu (apatton(at)alumni.princeton.edu)>
Andrew Patton
Yak-50
San Francisco, CA
http://forums.matronics.com/viewtopic.php?p=483233#483233
List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Yak-List
FORUMS -
WIKI -
b Site -
-Matt Dralle, List Admin.
glipaz
Posted: Sat Jan 18, 2025 4:55 pm Post subject: Re: Yak-50 rust in air system / MLG actuator |
The final filter was a nice idea, but sadly not a solution as air enters the valve through all three ports; air comes in through the In port of course, but as the actuators move air up and down, air leaving the actuator also passes through the valve.
Gil
