				|  | Matronics Email Lists Web Forum Interface to the Matronics Email Lists
		| Author | Message |
		| jonboede(at)hotmail.com Guest
				|  Posted: Wed Aug 29, 2018 9:28 pm    Post subject: Intake tubage |   |
				| Swap the carb - easy peasy.
 Get the #5 intake tube to go back in - %#$&(at)!!
 Anybody have a trick they want to share? Does the tube go in first and you work the rubber ring in after, or is (supposedly) easier to start with the rubber ring at the top of the tube and slide the tube in through it?
 Jon
 | |  |  | - The Matronics Yak-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Yak-List
		| Back to top |  |
		| dsavarese0812(at)bellsout Guest
				|  Posted: Thu Aug 30, 2018 3:56 am    Post subject: Intake tubage |   |
				| Typically, I place the rubber seal on the tube and work it into the case.  You may try first coating the outside of the seal, after it is on the intake tube, with a very light coat of fuel lube to help it slide into place.  Or put a light coat of fuel lube on the inside of the hole in the case.  The difficulty (as you know) is getting the first threads on the collar to "bite" because the rubber seal is not seated deep enough into the hole.  A few times I have had to push the seal into position after the the tube is in place using a plastic tool, which I fabricated from the handle of an old tooth brush.
 Dennis
 To: "yak-list(at)matronics.com" <yak-list(at)matronics.com>
 Sent: Thursday, August 30, 2018 1:31 AM
 Subject: Intake tubage
 --> Yak-List message posted by: Jon Boede <jonboede(at)hotmail.com (jonboede(at)hotmail.com)>
 _-= the many List utilities such as List Un/Subscription,
 http://www.m=================
 http://wiki.matronics.com====================
 http://w======
		| Back to top |  |
		| apatton2
				|  Posted: Tue Sep 11, 2018 8:54 pm    Post subject: Re: Intake tubage |   |
				| If I understand you correctly... when I did this, it was really difficult to align the upper end of the tube into the core. What ended up working was connecting the bottom connection to the cylinder when we were close... that lined the top up and the glan nut spun on.
 Andrew Patton
 Yak-50
 San Francisco, CA
		| Back to top |  |
 | You cannot post new topics in this forum You cannot reply to topics in this forum
