Cleveland Brake Caliper Model Number
Jim Combs
PostPosted: Fri Nov 02, 2018 10:28 am    Post subject: Cleveland Brake Caliper Model Number Reply with quote
Does anyone have the Cleveland brake caliper model number used on the -10.  Vans delivered this a wheel set and does not have the brake caliper model number.  I need a rebuild kit and cannot read the label on the caliper.  I did not take a picture of it at install.
I believe it is a 30-59 but not sure.
Thanks, Jim C
40192 - N312F
RV-10 -> N312F - Flying as of 12/2008
Tim Olson
PostPosted: Fri Nov 02, 2018 10:42 am    Post subject: Cleveland Brake Caliper Model Number Reply with quote
Hi Jim,
I think it's a 30-59E. At least that's what my maintenance notes say:
https://www.skygeek.com/cleveland-30-59e-brake-assembly.html
Here's a whole Cleveland pdf on it:
https://www.parker.com/literature/WBtech.PDF
And a page I saved once for myself:
https://www.myrv10.com/tips/maintenance/Cleveland_Wheels_and_Brakes/Cleveland_RV10_Brakes.pdf
PS: You're reminding me why I sent in my 2018 Donation to Matronics
yesterday.
Because:
A) I like you guys, and
B) This is the fastest method to get this kind of information.
Thanks, Jim C
40192 - N312F
Jim Combs
PostPosted: Fri Nov 02, 2018 11:29 am    Post subject: Cleveland Brake Caliper Model Number Reply with quote
Great!  - Thanks
On Fri, Nov 2, 2018 at 2:46 PM Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote:
--> RV10-List message posted by: Tim Olson <Tim(at)MyRV10.com>
Hi Jim,
yesterday.
Because:
> Thanks, Jim C
> 40192 - N312F
br> fts!)
r> > e.com" rel="noreferrer" target="_blank">www.mypilotstore.com
Kelly McMullen
PostPosted: Fri Nov 02, 2018 1:58 pm    Post subject: Cleveland Brake Caliper Model Number Reply with quote
All you need to "overhaul" caliper is the correct O-ring, unless there are damaged parts. I suppose brake pads as well.
Sent from my IBM-360 main frame
On Fri, Nov 2, 2018 at 12:32 PM Jim Combs <jiminlexky(at)gmail.com (jiminlexky(at)gmail.com)> wrote:
Great!  - Thanks
Hi Jim,
yesterday.
Because:
> Thanks, Jim C
> 40192 - N312F
br> fts!)
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
Jim Combs
PostPosted: Fri Nov 02, 2018 2:43 pm    Post subject: Cleveland Brake Caliper Model Number Reply with quote
Where can I get a correct o-ring made from a material that is compatible with the fluid and will work at the brake temperatures?
Jim C
On Fri, Nov 2, 2018 at 6:02 PM Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)> wrote:
Great!  - Thanks
Hi Jim,
yesterday.
Because:
> Thanks, Jim C
> 40192 - N312F
br> fts!)
Jim Combs
PostPosted: Fri Nov 02, 2018 3:15 pm    Post subject: Cleveland Brake Caliper Model Number Reply with quote
So I did find on Aircraft Spruce web page a Cleveland Brake Applications PDF that listed Vans RV series aircraft including the -10.  It has a part breakdown of the 30-59E and listed the correct O-Ring.  The cleveland part is 101-05200 also known as a MS28775-224 military spec part.  Got them ordered.
Great list and support from fellow RV-10 people.
Thanks, Jim Combs
N312F
Great!  - Thanks
Hi Jim,
yesterday.
Because:
> Thanks, Jim C
> 40192 - N312F
br> fts!)
Tim Olson
PostPosted: Fri Nov 02, 2018 5:30 pm    Post subject: Cleveland Brake Caliper Model Number Reply with quote
I think I got some from a friend in a split order from McMaster Carr. We switched to Viton for I think higher temp resistance. It’s been a looooong time now. I use the synthetic version of aviation brake fluid.
On Nov 2, 2018, at 5:41 PM, Jim Combs <jiminlexky(at)gmail.com (jiminlexky(at)gmail.com)> wrote:
Jim C
Great! - Thanks
--> RV10-List message posted by: Tim Olson <Tim(at)MyRV10.com (Tim(at)MyRV10.com)>
Hi Jim,
yesterday.
Because:
> Thanks, Jim C
> 40192 - N312F
br> fts!)
aerosport1
PostPosted: Fri Nov 02, 2018 5:44 pm    Post subject: Cleveland Brake Caliper Model Number Reply with quote
Jim I think I have some that you could have. I can check tomorrow. These are the Viton that Tim is talking about. Also I used the Royco 756, Higher flash point.
I did get them at McMaster
Geoff
Sent from my iPhoneGeoff Combs
Aerosport Modeling & Design
On Nov 2, 2018, at 9:28 PM, Tim Olson <Tim(at)MyRV10.com (Tim(at)MyRV10.com)> wrote:
Jim C
Great! - Thanks
Hi Jim,
yesterday.
Because:
> Thanks, Jim C
> 40192 - N312F
br> fts!)
Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033
Jim Combs
PostPosted: Fri Nov 02, 2018 5:45 pm    Post subject: Cleveland Brake Caliper Model Number Reply with quote
I have several people that I know with -10s and i ordered extras as well.  I have spares now too.
Thanks, Jim C
On Fri, Nov 2, 2018 at 9:33 PM Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote:
Jim C
Great!  - Thanks
Hi Jim,
yesterday.
Because:
> Thanks, Jim C
> 40192 - N312F
br> fts!)
Jim Combs
PostPosted: Sat Nov 03, 2018 11:25 am    Post subject: Cleveland Brake Caliper Model Number Reply with quote
I have already ordered the parts.  I did have to buy 25 (Min Qnty) but I want spares and I have two other -10 owners that asked me to order some for them too.  So we will share as well.
Thanks, Jim C
On Fri, Nov 2, 2018 at 9:47 PM g.combs <g.combs(at)aerosportmodeling.com (g.combs(at)aerosportmodeling.com)> wrote:
Geoff
Jim C
Great!  - Thanks
Hi Jim,
yesterday.
Because:
> Thanks, Jim C
> 40192 - N312F
br> fts!)
