EarthX Battery Tester
cluros(at)gmail.com
PostPosted: Wed Nov 28, 2018 4:20 pm    Post subject: EarthX Battery Tester Reply with quote
https://earthxbatteries.com/shop/optimate-lithium-battery-charger-lifepo4
The chargers EarthX sell will wait 30 minutes after charging and then check the voltage to see if the voltage has been retained. If it passes, it will wait up to 12 hours and then check again to check for excessive self discharge.
Is this sufficient to confirm that the battery is healthy or would some sort of load test also be a good idea?
zwakie
PostPosted: Thu Nov 29, 2018 3:47 am    Post subject: Re: EarthX Battery Tester Reply with quote
Looking at the specs that "Lithium" model seems to be identical to the model I have for my Odyssey 545 battery, it also uses the same charging/testing strategy.
Having a different model, my experience does not necessarily apply to this one, but I'd like to share it anyway as I had a similar line of thinking when I bought the thing couple of years ago:
Mine does a good job of maintaining the voltage level the battery is at and can recover from small discharge levels, but not much more than that. Mine certainly is not capable of recovering from deep discharges.
Given those 'limited' capabilities, I do a load charge test one year after bought new (I do this in spring-time), and replace it with a new battery the next year.
I want to have a high level of confidence that my battery is capable to deal with a alternator-out situation and allows me to finish the flight as planned when this happens. FYI: I have a single alternator - single battery setup and do daytime VFR only)
Marcel Zwakenberg
Europa XS TG || 912ULS || PH-SBR
ashleysc(at)broadstripe.n
PostPosted: Thu Nov 29, 2018 7:11 am    Post subject: EarthX Battery Tester Reply with quote
Hi Marcel;
Hi All;
It is for that very reason that I have two (2) twenty amp, internally regulated, permanent magnet alternators installed.
Cheers! Stu.
kenryan
PostPosted: Thu Nov 29, 2018 7:45 am    Post subject: EarthX Battery Tester Reply with quote
Marcel, what do you use for your "load" when you do the load test?
Ken
On Thu, Nov 29, 2018 at 2:52 AM zwakie <mz(at)cariama.nl (mz(at)cariama.nl)> wrote:
--> AeroElectric-List message posted by: "zwakie" <mz(at)cariama.nl (mz(at)cariama.nl)>
Marcel Zwakenberg
http://forums.matronics.com/viewtopic.php?p=485865#485865
br> fts!)
r> > e.com" rel="noreferrer" target="_blank">www.mypilotstore.com
zwakie
PostPosted: Thu Nov 29, 2018 7:56 am    Post subject: Re: EarthX Battery Tester Reply with quote
One of these: http://www.westmountainradio.com/product_info.php?products_id=cba4
Marcel Zwakenberg
zwakie
PostPosted: Thu Nov 29, 2018 7:59 am    Post subject: Re: EarthX Battery Tester Reply with quote
ashleysc(at)broadstripe.n wrote:
Hi Marcel;
Hi All;
Cheers! Stu.
Yeah, I have that on my wishlist too for that same reason but it has a little lower priority than what I am working on right now (upgrading panel to glass) as with the new panel I can last over 2 hours on battery only according to load calculations and battery specs Wink
[edit] plus: getting rid of my vacuum pump needs to be done first on my 912ULS to create the option for 2nd alternator...
Marcel Zwakenberg
PostPosted: Thu Nov 29, 2018 10:59 am    Post subject: EarthX Battery Tester Reply with quote
CAPACITY equates to ENDURANCE. This is what the
e-bus is for. You can periodically shut off
the master switch, close the alternate feed
switch and then time how long your battery
will support the e-bus loads.
Not sure what a 'load charge' test would be.
The classic load test at the lead-acid battery
factory is to place so much load on the battery
that its terminal voltage drops by 1/2. This
means that the resistance of the load is equal
to internal resistance of the battery. Typical
test currents can be well over 1000 amps.
This condition is held for x seconds whereupon
voltages and currents observed must exceed
some minimum value.
A capacity test looks at useful energy available
in chemical storage. The battery is loaded with
y amps (endurance value) and time down to 11 volts
(in lead acid world) is noted. This measurement
speaks to sustaining battery only flight conditions
and is only loosely related to results of any
variation on a load test.
Lithium internal resistance is so low that the
classic Ipp (peak power load test) is impractical.
Hence, tests for x seconds at z amps (cranking
currents) are practical. Capacity testing
remains unchanged.
cluros(at)gmail.com
PostPosted: Thu Nov 29, 2018 11:15 am    Post subject: EarthX Battery Tester Reply with quote
Thank you Bob.
On Thu, Nov 29, 2018 at 11:07 AM Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
  some minimum value.
  remains unchanged.
zwakie
PostPosted: Thu Nov 29, 2018 1:38 pm    Post subject: Re: EarthX Battery Tester Reply with quote
[quote="nuckolls.bob(at)aeroelect"]
A capacity test looks at useful energy available in chemical storage. The battery is loaded with y amps (endurance value) and time down to 11 volts (in lead acid world) is noted.
Thanks for correcting me Bob, and apologies for carelessly writing down he wording "load testing". I indeed meant to write "capacity testing", and the method that you describe here is exactly what I do.
Marcel Zwakenberg
PostPosted: Thu Nov 29, 2018 3:29 pm    Post subject: EarthX Battery Tester Reply with quote
No problem. We're ALL interested in
precise speech for it is a fundamental
foundation of understanding.
