CJ Jacks needed
Off2wildblue
PostPosted: Fri Nov 30, 2018 8:14 am    Post subject: CJ Jacks needed Reply with quote
New CJ-6, now I need the jacks. Any idea's or does anyone have any available?
Also, if you made some, could you send me pics please?
FYI, I checked and Doug Sapp doesn't have any right now.
You can contact me off list.
SAM
billaustin(at)blomand.net
PostPosted: Fri Nov 30, 2018 8:58 am    Post subject: CJ Jacks needed Reply with quote
I have a set. Call me 615-406-1055
available?
SAM
http://forums.matronics.com/viewtopic.php?p=486040#486040
marcusbates(at)att.net
PostPosted: Fri Nov 30, 2018 10:13 am    Post subject: CJ Jacks needed Reply with quote
I have a set for a Yak 52..........
> New CJ-6, now I need the jacks. Any idea's or does anyone have any available? Also, if you made some, could you send me pics please?
> Thanks,
> SAM
jbsoar(at)gmail.com
PostPosted: Fri Nov 30, 2018 12:59 pm    Post subject: CJ Jacks needed Reply with quote
What jacks are needed for a Yak 50?
On Fri, Nov 30, 2018 at 12:22 PM Marcus Bates <marcusbates(at)att.net (marcusbates(at)att.net)> wrote:
--> Yak-List message posted by: Marcus Bates <marcusbates(at)att.net (marcusbates(at)att.net)>
> On Nov 30, 2018, at 11:01 AM, Bill Austin <billaustin(at)blomand.net (billaustin(at)blomand.net)> wrote:
> --> Yak-List message posted by: "Bill Austin" <billaustin(at)blomand.net (billaustin(at)blomand.net)>
> "Off2wildblue" <Off2wildblue(at)me.com (Off2wildblue(at)me.com)> wrote:
>> --> Yak-List message posted by: "Off2wildblue" <Off2wildblue(at)me.com (Off2wildblue(at)me.com)>
>> Thanks,
>> SAM
br> fts!)
r> > e.com" rel="noreferrer" target="_blank">www.mypilotstore.com
mark.bitterlich(at)navy.m
PostPosted: Fri Nov 30, 2018 1:28 pm    Post subject: CJ Jacks needed Reply with quote
YAK-52 or Sukhoi jacks will work. You will need three 14mm lug nut studs (from an old Volkswagen for example), to screw into the three jack points. One on each wing and one in the NOSE (not the tail. The way the jack points on a 50 are setup, as you jack the wings, the aircraft's CG is forward, not aft, and the weight is then put on the nose jack. Unscrew any fittings from the top of the jack and then figure out a way for the 14mm lug nut studs to fit into the top of the jack and not bottom out. If you cycle the gear, be careful that you know exactly what you are doing if you choose to exercise the emergency blow down bottle. More than one YAK-50 has jumped right off the jacks when doing that, by those not aware of how careful to be, let alone knowing how to reset the shuttle valves afterwards. Dennis Savarese can guide you through that process, or you can check the archives.
Mark
Clouddog
PostPosted: Fri Nov 30, 2018 2:17 pm    Post subject: CJ Jacks needed Reply with quote
Here is what I have had fabricated over the last 2 years for CJ.
On Fri, Nov 30, 2018, 15:36 Bitterlich, Mark G CIV NAVAIR, WD <mark.bitterlich(at)navy.mil (mark.bitterlich(at)navy.mil) wrote:
[quote]--> Yak-List message posted by: "Bitterlich, Mark G CIV NAVAIR, WD" <mark.bitterlich(at)navy.mil (mark.bitterlich(at)navy.mil)>
Mark
 Filesize:  2.61 MB
 Viewed:  10123 Time(s)
Clouddog
PostPosted: Mon Dec 03, 2018 5:22 am    Post subject: CJ Jacks needed Reply with quote
Here is what I have had fabricated the past 4 years.
Greg
clouddog22(at)gmail.com (clouddog22(at)gmail.com)
On Fri, Nov 30, 2018, 10:21 Off2wildblue <Off2wildblue(at)me.com (Off2wildblue(at)me.com) wrote:
--> Yak-List message posted by: "Off2wildblue" <Off2wildblue(at)me.com>
SAM
br> fts!)
r> > www.mypilotstore.com
ics.com/contribution
ronics.com
nics.com
 Filesize:  2.61 MB
 Viewed:  10080 Time(s)
Off2wildblue
PostPosted: Fri Dec 21, 2018 4:04 pm    Post subject: Re: CJ Jacks needed Reply with quote
Got the main jacks from Bill Austin. Really appreciate that. Now does anyone have advice on nose and tail jacks? Measurements of yours might help. You can contact me off list.
Thanks again Bill!
SAM
available?
SAM
Off2wildblue
PostPosted: Sat Jan 19, 2019 7:33 am    Post subject: Re: CJ Jacks needed Reply with quote
Just letting you guys know that I fabricated my nose and tail Jack’s. Here’s how they turned out. In case you guys out there need a set. Maybe it will give you some ideas.
SAM
By the way, if anybody knows how to make the picture smaller one sent from your phone please let me know!
 Filesize:  2.73 MB
 Viewed:  9820 Time(s)
